Squarehead
Hi All
I have a 2011 Jetta Comfortline, and I'm having issues with my HVAC (heat/AC).
When I select med on the temp setting it will blow lower than med heat.
But if I crank it up to HOT it's HOT (good).
So when I want to dial it back to say MED heat it's still HOT.
If I move it to cold it gets cold and then back to MED it's still cold.
It feels like the turn dial moves but doesn’t engage anything till it's at one extreme or the other.
Another issue is with the selector for where to blow (defrost, face....)
If you try to put it in between the face and feet you just get fan noise and very little air movement.
Anyone have similar issue?
