#1: So I have a problem Google can't solve on my new to me 2006 jetta tdi. The heat only works in between modes having to do with the floor, or on the floor mode itself. When turned to face or defrost directly the heat goes cold. This vehicle has, as I understand it, manual climate controls. I was curious as to what could cause this?
#2: I also own and have owned multiple diesel trucks, all of which have had little or no blow by. This car seems to have an excessive amount of it through the oil filler cap as when removing it the cap almost dances. This caused the previous owner to believe the car needed a turbo due to oil collection in the charge air ducting and the ic itself. I however verified little shaft play side to side and none in/out. Also verified was 15.7 psi of boost. How much blow by/oil consumption should this vehicle realistically have and what could be causing it?
Any help offered is greatly appreciated.
