stanz
Okay I think we all got the extended warranty on the HPFP up to 120K miles for the 09' to whatever, I have an 09. I have had a problem on cold start with engine up slope angle for some time. If the engine[front] of the car is lower usually no problem. Lately on startup getting the 000135 [PO87] "fuel rail system pressure too low". Fuel filter changed regularly no noticeable metal at all. I have 7K left till I hit 120K then out of warranty. Question; If I were to take it to the dealer and they find out it is the N290 fuel metering valve, and they do not supply that as a separate part in the US would that not entitle me to a new HPFP under warranty? Will they warranty the HPFP on a running vehicle, or only total failure where everything goes down the crapper. What say you guys. Thanks for any input.
