david_594
YES. Salt drives the rain sensor insane! Thats why you need to make sure to keep the windshield washer tank full, all 5.5Liters of it.
yea i know that ...just thought that maybe it's not normal...it's a tiny bit annoying because i get in and out allot..tongsli said:If you want them to start again after getting out of the car, no need to move the stalk,
Just move the lever on top of the stalk that controls the speed of the intermittent feature.
This will activate them once again.
L
I've no problems with skipping/chattering with the "aero" blades, if that's what you mean. My beef is that in salty (road spray) winter driving conditions, no matter the sensitivity of the rain sensor, they will wipe prematurely, and very ineffectively. The windshield isn't really that "wet", so it just gets it totally streaked and, unless I use the spray washers immediately, completely opaque.BoosTDIt said:Fitzsky i think you need to adjust the wiper blade arms to resolve the skipping....Lito posted some time ago how even a dealer bulletin exists for that for the pre-delivery inspections....you're supposed to bend them slightly somehow towards the glass...i mostly hear the Passat people to have this complaint...maybe the curve of the Passat windshields???
That's a pretty good answer.compu_85 said:The reason they have the wipers deactivate after a restart is this: In the winter, if you park the car with the switch on auto, then start it again, the wipers would try to move a large ammount of snow.
That's the best answer I can come up with.
-Jason
Is the 192 control module used in the W8 as well?fitzski said:That's a pretty good answer.
Or if they are frozen, too.
[edit]Although... if that were the reason, wouldn't it/shouldn't it work the same in all models and in all modes - what if I leave my standard Jetta on wiper speed 1, or even the intermittent mode? It'll still wipe when I next get in the car... same with the W8 (with the rain sensor), if I leave it on one of the speed settings... [/edit]
No. At least, not if I understand/read Bentley correctly. It lists it as Wiper/Washer Intermittent Relay (377), as per the diagram below, for rainsensor equipped vehicles from October 2000.tongsli said:Is the 192 control module used in the W8 as well?
Yes, 192 is used in the Passat with rain sensor. Otherwise, like all the other A4s and B5s now, 603 relay is used (supercedes 377, 378). A5 is different.tongsli said:Is the 192 control module used in the W8 as well?
My guess is that the 192 has more smarts than the relay it replaces (I forget the number). I've opened them up, and there is quite a difference between the two. Cost savings on the one without the rain sensor. You would need some piece of active logic in there and that costs...fitzski said:Although... if that were the reason, wouldn't it/shouldn't it work the same in all models and in all modes - what if I leave my standard Jetta on wiper speed 1, or even the intermittent mode? It'll still wipe when I next get in the car... same with the W8 (with the rain sensor), if I leave it on one of the speed settings...
Not sure I follow... 192 is used with the rain sensor cars, and 603 is used in the non-rain sensor cars. Further, 603 supercedes 377 and 378. IOW... 377 should not be in a rain sensor car, contrary to what Bentley says (not that they're always right)?MOGolf said:Yes, 192 is used in the Passat with rain sensor. Otherwise, like all the other A4s and B5s now, 603 relay is used (supercedes 377, 378). A5 is different.
Looks like I'll have to add wipers to the list of stuff I need to get. I just bought a rainsensing / autodim mirrow. I need to find a good price on the relay (1J0 955 531). Maybe, I'll see if someone on the passat forum will want to swap + $ for a non-sensing relay. Hopefully, I won't have a problem with insurance to upgrade to the GLX windshield. My stock windshield caught a rock the other day and is ready to go....compu_85 said:Just a note to those doing this: Your wiper blades must be fresh for the sensor to work properly.
-Jason
lito (tongsli) had an extra 192 a couple of months ago, check with him too.dieselgti said:Maybe, I'll see if someone on the passat forum will want to swap + $ for a non-sensing relay.
No kidding! I'm really worried about that. I was reading through the thread that was linked ealier. Talk about a nightmare!!!! I really didn't want to replace the glass, but the crack kinda forced it.compu_85 said:Be sure the new glass is installed properly.......
Great, I'll shoot him a PM!volmaniac said:lito (tongsli) had an extra 192 a couple of months ago, check with him too.
I already did - he sold it awhile back!dieselgti said:Great, I'll shoot him a PM!
UndergroundVWParts.david_594 said:whoever the other big wrecker is on vortex
Thanks! It looks like BVAMotorsports might have one! This should be a fun mod!Nihilator said:UndergroundVWParts.
--Chris
edit: yeah, re-read your post. Those two are the biggest. For new parts, I'd recommend World Impex; I don't know their screen name on the vortex, though.
