4loops
I thought I'd post here to show my recent experience in replacing my Mk4's headliner. Since the other threads out there have had their pictures broken by photobucket and images being removed from other sites, I thought I'd create another how-to. My Jetta was a sedan, but most of this will apply to the wagon, too. Only- the wagon's headliner should be easier to remove!
So, I'll start then.
My headliner was becoming detached over the past couple years. It was getting annoying to sit in the back with baby on longer trips as the headliner would keep brushing on our heads. Then came the foam the blew about in the cabin. Then a big rush of wind pulled the fabric completely from the headliner, only holding by the handles and sunroof. So, it was time to go ahead with it. Also annoying over the years: realizing you've been lied to by the previous owner who said "oh, no, I never smoked in it..", only to find a cigarrette burn in the headliner by the drivers window. Live and learn. Take your time and don't get overly excited about a car-purchase that your vision is clouded.
Here it was before I started:
DSC_3238
DSC_3349
I cut a section out in the above and took that to an auto interior place in town to match it to a similar color. I simply removed the fabric and wire-brushed all the glue off the headliner and pillar covers to save some labor charge. Probably should've cut the whole middle section out though. It was difficult/more challenging to drive with my rear view obstructed. I figured I would pay a professional to apply the new fabric, as the fabric is expensive, and is really an art to get to stretch and stick. Especially with the VAG products the guy tells me: Volks/Audi really have some large recesses where stretching the fabric so that it sticks and doesn't wrinkle is challenging. I really didn't want to try doing this myslef because I know I really don't want to remove the headliner again to redo it. It took me a good 4.5 hours to remove the headliner and pillar covers, and about the same to install. I don't think I was working slow, just carefully.
My first trick was to pull off the a-pillar covers. The MK4s have side curtain airbags, so it's a good idea to just go ahead and disconnect the battery (negative). I know they will only go off if the ignition is on, but extra safety that costs 10 seconds is worth it.
DSC_3222
Pulling back the door seal/side trim will allow a bit more visual access in this location.
DSC_3221
Since the car is equipped with side-curtain airbags, the A and D pillar covers are designed to bend to allow the airbag to exit its space. Because of that crease, it makes it easier to bend the pillar cover without damaging it.
My pictures are alternating between the right and left A-pillars, but you get the idea.
Pull the bottom of the pillar cover out to gain access to the clip holding on the pillar at the top. It is easier to gently push the airbag a bit away from the pillar frame to see the clip better.
This is the clip you're trying to get to:
DSC_3227
DSC_3213
