runonbeer
Maintenance EnthusiastVendor
Did you also replace the head plug seal discussed earlier in this thread?Oh no! After a week my pump head seal is leaking again.... glad I have two more seals.... I cry ever time
No, maybe thats my issue?Did you also replace the head plug seal discussed earlier in this thread?
Thanks for the link runonbeer, if this reseal job doesn't work I will call him about replacing my current IP. I'm crossing my fingers that is not necessary.
The car is a 2001 Golf TDI.
So I replaced the QA seal 2 days ago and went back to replace the head seal today. My top seal was replaced a year ago and has been fine since. Everything seems fine with the reseal I did recently but I still seem to have a weep on the front (radiator side). I don't think that it is coming from the QA seal which like I said I just replaced. I checked the junction with a mirror and also by squashing my finger against the transition and my finger comes away dry unlike when the QA was definitely leaking before.
All I know for sure is that the area below the QA on the front of the pump down to the cover circled in the bottom of the photo keeps wetting up dramatically. There is a lot of grime on my pump that makes it really easy to tell which places are wet and even after I dry off that cover it become wet again quickly. I changed the head seal hoping that it was fuel percolating sideways through the grime but it does not seem to have knocked it out.
I'm thinking that the weep could be coming from one of the 2 areas circled if that is even possible (i.e. if those areas even have seals and are physically able to leak fuel).
So my question is can those areas also develop leaks and if so can they also be replaced? If there are seals to be replaced, is it an easy or hard fix compared with the common 3 that I have already replaced?
I have the dieselgeek seal kit so maybe that has what I need in it. I just don't dare proceed without info from someone who knows what will happen if that stuff is unbolted.
Sorry that I don't know that these components are called and feel free to let me know what they are. I tried to look them up but didn't find them marked on any diagram.
Thanks for the help.
Are you sure? A lot of people have mistakenly concluded that those seals are leaking only to discover that it was actually the top or middle seals (like it always is).
The wiring box seals are not available from Bosch (or anyone) and not at all easy to change. Practically impossible.
The lower gasket shown, for the timing piston is Bosch # 1461074328 and it is not contained in the general bosch IP seal kit that you linked to.
I am sitting here looking at a stack of 3 of these that I have had for years and years and years and years because they are just never needed.
Incidentally, the gasket for the seal plate on the opposite end of the timing piston is Bosch # 1461038319. Same deal. Have a bunch. Have never needed them.
Unless they are removed there is no reason that they would suddenly begin leaking. They're like the paper coated MLS gaskets for the EGR and other places.
If indeed the wiring junction box seals are leaking then it would be impossible to conclude that the timing piston gasket is also leaking since it is directly beneath the junction box.
When you call and order those seals you should spark up a conversation with Jim about his i-MiEV. He loves talking about EVs.EV's: 2014 Zero S 11.4 moto ! 2012 Mitsubishi i-MiEV
I'm not surprised a lot of tdi'ers are going to EV's. I ordered over the web, no chance to talk EV's yet. I so much prefer riding the E-moto in LA than a car, but CHP seems to target bike's more, sucks!When you call and order those seals you should spark up a conversation with Jim about his i-MiEV. He loves talking about EVs.
I pretty much only drive EV now. Either our Leaf or my ebike. Mostly the bike.
Thanks runonbeer!Did you disconnect the 10 pin? Cut-off solenoid nut tight? How about the QA marks? Lined up? Sometimes if the marks are way off and the QA is too far to the right then it takes a heck of a lot of cranking to start.
I believe that you hammered to the LEFT or away from the timing belt, yes?relative change I measured 1.1mm (from 18.2 to 17.1mm) after hammering to the right to get the IQ from ~30-40 down to 3.4.
I just finished my seal using this video and it was a lot of help. Their step by step instructions is awesome. The only thing I have to add is that the green seal on the kit is not designed to be stretched. I ended up having to order a Viton seal from Dieselgeeks. Other than having to wait for the seal, the repair was a success.
Thanks TDIClub for being there with easy to follow instructions in all related to our beloved TDIs.
Torque sped aren’t published by Bosch. All of your questions are discussed here in this threadRunonbeer, I watched the videos and have replaced the seal. My VAGCOM has me at 3.0, but it’s only “Good-n-tight”. Do you have torque specs for the block to pump body? Also, my replacement seal is green as opposed to black. It’s right out of the BOSCH kit. Is this a reason for concern? I can PM pics...
Did you replace the head plug seal discussed earlier in this thread?I watched the YouTube videos and bought the special socket, VAGCOM and even a dedicated vacuum pump for the job. Ordered a BOSCH seal kit and performed the repair. My problem now is that it’s leaking just as badly and appears to be coming from the “Head” bolt at the 7 o’clock position. I’m frustrated by this apparent failure. Any help and advice is desperately sought and will be eagerly awaited!
Thanks in advance!
Tank
Runonbeer,Did you replace the head plug seal discussed earlier in this thread?
Thanks in advance!
Tank
The plug seal is mentioned and discussed many times throughout this very discussion thread. Here is one instance but it comes up again and againRunonbeer,
I did not replace that seal. I see that someone else had a leak there and modified a standard 12pt socket to remove the plug. Are there any additional precautions? Is there anything else in there that might spring out or fall and be lost forever?
Thanks in Advance,
Tank
