Qui-Gon_Gene
Head plug question...
Hi y'all! The TDIClub community has saved me yet again with this thread.
My IP has started leaking fuel like crazy from one or both of the QA seals, so I've watched the video, and I'm about to order the seals and triangular socket. I think I'm pretty clear on almost everything, but I could use a little clarification on the part not covered in the video.
I don't think that my head plug is leaking, but I can't be 100% sure about it because of all the fuel coming from the bad QA seal. If I go ahead and replace the 2 QA seals and the head seal (just like in the video), can I just ignore the head plug and seal for now and replace them separately, later on? Does the pump need to be on-cam to replace the head plug? Basically, I just want to know if I should do the head plug and seal at the same time as the rest, even though I don't know that it's leaking, or if I can wait to see if it's okay, and replace them later if necessary? I don't want to fix what's not broken, but I don't want to make more work for myself down the road either, and I don't want to take the QA loose more than once! lol
Meanwhile, I know just enough about fixing vehicles to be dangerous, and that video is priceless to people such as myself. Thanks a bunch to the guys that made it, because I would probably be hauling my Jetta to a local TDI mechanic right now without it!
