How-To: Replace a MKIV ALH Diesel Injection Pump without Changing the Timing Belt
rocketeer928
Enfield, Connecticut
2003 Jetta GLS TDI 5-speed
Please note that Posts 1 - 8 of this thread are copyrighted via a Creative Commons 3.0 BY-NC-SA license.
I decided to exchange my 10‑mm injection pump for an 11‑mm injection pump to compliment the other modifications on my MKIV ALH engine (for details see 2003 Jetta GLS TDI). I noticed that there was not a “How-To” for swapping out an injection pump without also doing a full timing belt change, so I decided to write one. I hope someone finds this useful.
This “How-To” can be applied to the exchange or replacement of either the 10‑mm or 11‑mm injection pump on an ALH engine, though the instructions will be slanted toward a manual transmission TDI. There are a few small differences for the automatic transmission, and the Bentley manual should be consulted.
Disclaimer
Anything you do to your own car is AT YOUR OWN RISK! I deny any responsibility or liability for anything that you may do to your car, and for any errors in the “How-To”. I'm not a professional mechanic; I just like tinkering with my car. Do NOT do any of this if you aren't comfortable with modifying your engine, and be prepared to deal with the consequences if you do something wrong.
If you intend to use this document as a guide, READ THE WHOLE THING FIRST.
Now to the good stuff!
Parts
10-mm Injection Pump with four (4) new copper washers: VW Part Nr. 038-130-107-KX
or
11-mm injection Pump with four (4) new copper washers: VW Part Nr. 038-130-107-JX
Three (3) Injection Pump Sprocket Bolts: Part Nr. N903-285-04
Tools and Supplies
Metalnerd Part Nr. MNA4KIT7PC: A4 Timing Belt Tool Kit, or equivalent VW tools, which includes:
Part Nr. MN3036 - Universal Sprocket Buster™ Counter-Hold Tool
Part Nr. MN3418 - Universal Cam Locking Plate
Part Nr. MN3359 - Cam Sprocket Pin (also A4 TDI pump Pin)
Part Nr. MN3333 - Compact 3-way Tensioner Wrench
Part Nr. MN4001 - A4/NB Cam Sprocket Puller
Metric ⅜-inch drive and ½-inch drive socket set, including deep sockets; ¼-inch drive may also be useful
Metric Allen sockets; long
Hose pinch-off clamps
Metric open- and box-end wrenches
17‑mm Flare-nut wrench
10‑mm and 13‑mm offset box wrench
Torque ratchet
Hand operated vacuum pump (e.g., Mityvac Model 04000)
VCDS cable, PC with Windows, and VCDS software
Disposable shop towels
[FONT=&quot]Suggested: Painter’s tape to label bolts/parts[/FONT]
rocketeer928
Removing Injection Pump
Engage the parking brake and place the front of your car on jack stands. If anything, this will save your back from aching.
Remove any installed skid plate or belly pan. This is mainly in case you drop something through the engine compartment; it will be easier to retrieve.
Remove the upper engine cover with a 10-mm socket, or pull it off if you’ve retrofitted it like I did.
If you do not have a torque wrench that will accommodate the fuel lines, take a marker to indicate the current position of the nuts on both the injector nozzles and injection pump. Remove any alternative CCV [/COLOR]system (e.g., my Agricultural Strainer CCV system).
Clean the fuel line nuts with a little brake cleaner, doing your best to collect dirt particles among disposable shop towels. Remove the two metal/rubber clips that hold a pair of fuel lines together with a 10‑mm socket. The picture shows one of the clips removed, and you can see my fuel line nut marking better in this picture.
Remove the braided fuel return line between the injection pump and Injector Nr. 4, including taking it off the plastic clip attached to the vacuum reservoir bracket. A shop towel helped catch leaking diesel fuel.
Using a 17‑mm open-end wrench, loosen the fuel line nuts. A 17‑mm flare-nut wrench could also be used, but it’s not absolutely necessary.
Remove the fuel lines in the following order: Line Nr. 3, Line Nr. 4, Line Nr. 1 (hardest to remove from the injector; use the regular 17‑mm open-end wrench), and Line Nr. 2. While removing them, mark the fuel lines individually with their injector number and their position on the injection pump (e.g., Top Front, Bottom Back, etc.), respectively. Again, use shop towels to collect any leaking diesel fuel.
Here’s a picture of the fuel lines removed from Injectors 1 – 4, left to right.
Wrap the four injectors with plastic wrap to keep dirt from inadvertently entering the injectors, holding down with twist ties or elastic (rubber) bands.
Yes, my valve cover and intake manifold is now BLUE.
Pinch off the fuel supply and return lines with hose clamps near the fuel filter.
Pull back the spring clamps on the fuel supply and return lines (blue tape arrows).
rocketeer928
Removing Injection Pump Continued
Remove the fuel supply and return lines from the injection pump and keep them to the side, making sure you have shop towels handy to catch or clean up spilled diesel fuel.
Remove the banjo fuel return line cap with a 17‑mm socket, while counter-holding with a 17‑mm open‑end wrench.
Remove the fuel supply line connection from the top of the injection pump with a 17‑mm deep socket (e.g., impact socket).
Remove the bumper cover and the passenger side headlight. For step-by-step instructions go to these links:
http://forums.tdiclub.com/showpost.php?p=2585388&postcount=5
http://forums.tdiclub.com/showpost.php?p=2585391&postcount=6
http://forums.tdiclub.com/showpost.php?p=2585396&postcount=7
http://forums.tdiclub.com/showpost.php?p=2585449&postcount=23
Remove the upper intake pipe and hoses from the EGR valve or race pipe to the intercooler. You may also want to remove the EGR valve or race pipe.
Remove the upper timing belt guard, which is held in place with five (5) clips.
If you have a manual transmission, remove the three glow plug wires from in front of the vacuum pump, labeling the wires and glow plugs (e.g., Front, Center, and Back).
Remove the vacuum reservoir ball with an 8‑mm socket. [/COLOR]Remove the vacuum line underneath the vacuum pump, and its support bracket with a ¼-inch drive 10‑mm deep socket and 10‑mm offset box wrench, which has two bolts.
Remove the three vacuum pump bolts with a 13‑mm deep socket and/or 13‑mm offset box wrench (manual transmission cars). One of the bolts is normal, while two of the bolts have a threaded top for the vacuum line support bracket.
Remove the vacuum pump, and place it to the side. Don’t misplace the Vacuum Pump Seal, and you may want to replace it with a new seal.
rocketeer928
Remove the seven valve cover bolts with a long 5‑mm Allen socket. I have a Dieselgeek oil by-pass filter, so I had to first remove the connection on the valve cover from the line leading from the top of the filter.
NOTE: Due to an issue that I experienced and years of frustration, I no longer use the Dieselgeek by-pass filter system on my TDI. See Post #885 of my main TDI's thread for details.
Lift off the valve cover and set it aside; keep it clean.
Set the engine to top dead center (TDC). Both Nr. 1 cylinder cam lobes toward the passenger side are to be pointing upwards, the brake booster vacuum pump groove in the end of the camshaft where the vacuum pump resides is to be horizontal, and the flywheel should be at the TDC index mark. Engage the parking brake and put the transmission in neutral.
Using the Universal Sprocket Buster™ Counter hold Tool, rotate the camshaft sprocket clockwise until the Nr. 1 cylinder cam lobes are pointing upward and the groove in the end of the camshaft is horizontal. Do NOT turn the cam sprocket counter-clockwise. Be certain to place plenty of shop towels underneath the injection pump because it will expel diesel fuel while the camshaft sprocket is turned.
Note: I have since been corrected in that it's best to rotate using the crankshaft sprocket bolt using a 12-point 19-mm socket. See picture in subsequent post for the location of the crankshaft sprocket bolt.
Install the Universal Cam Locking Plate into the camshaft groove. The camshaft pulley may have to be moved one way or the other slightly to get the plate in place. Again, make sure the Nr. 1 cylinder cam lobes are pointing upward.
Remove the plug on top of the manual transmission, and check that the flywheel marking indicates TDC. For the automatic transmission, Bentley Page 23-15 indicates to align the mark on the torque converter with the lower edge of the opening on the transfer case.
To tell the truth, I can never see this mark on the flywheel; now or when I performed a previous timing belt change.
Note: When I performed a timing belt change in June 2017, I did indeed locate the yellowed marked on the flywheel.
Lock the injection pump sprocket with the A4 TDI Pump Pin. Note that the pin must be aligned with the center of the mark on the injection pump cover and the sprocket center bolt - double check it with a mirror. It might help to look for the hole that the pin is being inserted into with the mirror prior to installation. Insert the pin all the way. Again, the camshaft pulley may have to be slightly moved to insert the pin all the way. Ensure that the Universal Cam Locking Plate is still in its correct, horizontal position.
Remove the three injection pump sprocket bolts with a 13‑mm socket. These bolts should be replaced with new sprocket bolts upon reinstallation. Do NOT loosen the center sprocket nut.
Mark the position of the belt tensioner nut in relation to the tensioner’s setting. Loosen the nut on the timing belt tensioner with a 13‑mm boxed-end wrench. Do NOT remove.
rocketeer928
Relieve the tension on the timing belt using the Tensioner Wrench by rotating the wrench COUNTER-CLOCKWISE. According to the Bentley Page 23-18, it looks as though an Allen wrench is used on the tensioner for an automatic transmission.
Temporarily remove the A4 TDI Pump Pin, slip the timing belt off of the camshaft and injection pump sprockets, remove the injection pump sprocket, and then reinsert the A4 TDI Pump Pin.
Unclip the harness connector for the injection pump from its retaining bracket, which is located toward the back of the oil filter housing, and disconnect.
Remove the three (3) front injection pump mounting bolts with a 13‑mm socket.
Remove the rear injection pump mounting bolt from the support bracket with a 13‑mm socket. It’s the greenish bolts in the below picture.
Carefully slide the pump shaft out of the assembly bracket and lift the injection pump out of the engine compartment. Be sure to clean up any diesel fuel that may have spilled. There will be plenty of spilled fuel.
If you need to change your thermostat then now is a good time to do it. As can be seen in the above picture, the access to the thermostat and its housing is optimal when the injection pump is removed. I did change my thermostat and its housing using this How-To: http://forums.tdiclub.com/showthread.php?t=264619
Remove the A4 TDI Pump Pin from the injection pump because it’s no longer needed, but rather will be used to install the new injection pump. Here’s the removed 10‑mm injection pump.
rocketeer928
Installing Replacement Injection Pump
Remove all the packaging materials and plugs sealing the port openings from the replacement injection pump. You may choose to leave the plugs on the injection pump until the various fittings are going to be reinstalled to ensure that inadvertent dirt doesn’t make its way into the fuel connections; just be sure to remove them during the reinstallation.
Make certain that the injection pump came with four new copper washers. One is already in position behind the return line union. Two will go on either side of the banjo return line. The fourth is for the fuel supply line union (left side where black plug is located).
Install the injection pump onto the support bracket, hand tighten the rear mounting bolt, and place the connector wires into its wire clip/holder.
Position the injection pump in the bracket and tighten the front bolts with a 13‑mm socket to18 ft‑lb (25 Nm), and then tighten the rear bolt with a 13‑mm socket to18 ft‑lb (25 Nm).
Remount the injection pump sprocket onto the pump hub and loosely install the three (3) new injection pump sprocket bolts into the injection pump sprocket, positioning the sprocket so that the bolts are in the middle of the elongated holes. Do not tighten the bolts quite yet, but leave them loose.
Lock the injection pump sprocket using the A4 TDI Pump Pin, making certain that the pin enters the alignment hole toward the top of the injection pump and not to the side of the hole (common mistake). If you cannot find the proper alignment hole, temporarily remove the injection pump sprocket to locate the hole, and then reinstall as directed in the previous step. The pump hub may have to be moved slightly with a 22‑mm wrench to get the A4 TDI Pump Pin inserted completely.
Ensure that the crankshaft is still at TDC: Recheck that the Nr. 1 cylinder cam lobes are pointing upwards, the brake booster vacuum pump groove in the end of the camshaft where the vacuum pump resides is horizontal and the Universal Cam Locking Plate is still in place.
Using the Universal Sprocket Buster™ Counter-Hold Tool, hold the camshaft pulley still while loosening the bolt with a 19‑mm socket. Do NOT remove the bolt at this time, but only loosen.
Make certain that there is a gap between the washer and camshaft pulley. Re-check TDC.
Release the camshaft sprocket from the camshaft taper using the Cam Sprocket Puller. After installing the puller, use a 17‑mm boxed-end wrench to turn the puller bolt clockwise until the camshaft pulley snaps off of the tapered end of the camshaft.
Place the timing belt onto the injection pump sprocket and tensioning roller, and thread under the idler roller. The camshaft sprocket may need to be removed in order to get the timing belt to be installed.
rocketeer928
Installing Replacement Injection Pump Continued
Using a mirror and a light, be sure the tensioning roller retaining tab on the upper left is correctly seated in the hole in the timing belt guard.
Here is a picture of how the timing belt is routed. Picture is thanks to www.myturbodiesel.com:
Temporarily tighten one of the injection pump sprocket bolts modestly, but not too tight, while the bolt is in the middle of an elongated hole. It’s not being torqued yet, and will be re-loosened.
Using the Universal Sprocket Buster™ Counter-Hold Tool, hold the camshaft pulley still while reinstalling the camshaft sprocket bolt by hand, but not yet torqued.
Loosen the injection pump sprocket bolt that was tightened earlier, and make certain the A4 TDI Pump Pin is still in place and centered in its elongated hole.
Again, ensure that the crankshaft is still at TDC: Recheck that the Nr. 1 cylinder cam lobes are pointing upwards, the brake booster vacuum pump groove in the end of the camshaft where the vacuum pump resides is horizontal and the Universal Cam Locking Plate is still in place.
Ensure that the two holes on the tensioner are rotated to the bottom, and that the tensioning roller retaining lug is correctly seated in the hole in the timing belt guard. Hand-tighten the nut on the timing belt tensioner.
Picture from Bentley Manual Page 23-18
Using the Compact 3-way Tensioner Wrench in the center holes of the belt tensioner, tension the belt by turning clockwise until the notch and the raised mark are aligned. Cars with an automatic transmission use an Allen wrench on the belt tensioner, according to Bentley Page 23-18.
Tighten the tensioner lock nut with a 13‑mm boxed-end wrench to what feels like “Good-and-Tight”, while maintaining the tensioner position with the Compact 3-way Tensioner Wrench. With the engine mount bracket in the way, it is impossible to get a socket and ratchet on the tensioner bolt. This is likely why the Metalnerd Compact 3‑way Tensioner Wrench comes with a separate 13‑mm wrench. It is also why it is recommended to mark the tensioner nut in the Removing Injection Pump Section.
Using a mirror, ensure that the notch and the raised mark are alighned on the tensioner.
Ensure that everything is still at TDC and that the A4 TDI Pump Pin is still in place.
Using the Universal Sprocket Buster™ Counter-Hold Tool, hold the camshaft pulley still while reinstalling the camshaft sprocket bolt with a 19‑mm socket to 33 ft‑lb (45 Nm). Some have recommended increasing the torque by about 20%, which means 40 ft-lb (54 Nm). It's up to your comfort level.
Tighten the three (3) bolts on the injection pump sprocket bolts with a 13‑mm socket just enough to hold the sprocket. Then tighten them to 18 ft‑lb (25 Nm).
Remove the Universal Cam Locking Plate.
Using the Universal Sprocket Buster™ Counter-Hold Tool, rotate the camshaft CLOCKWISE for two complete rotations (Alternatively, rotate using the crankshaft sprocket bolts; See note in previous post). Compression should be felt during the rotation, which will go away if everything is timed correctly. If the compression does not go away and/or it feels like a valve is being hit then carefully turn it back and re-check all the TDC setting and bolts for correct torque setting. If for some reason the transmission was placed into gear, place the shifter into neutral.
Once the two manual rotations are completed, the Cylinder Nr. 1 should be at TDC with the lobes in the up position.
Reconnect the harness connector for the injection pump wiring, and slip the connector into its retaining bracket.
Reinstall the three (3) bolts for the vacuum pump with a 13‑mm deep socket and/or 13‑mm offset box wrench to 15 ft‑lb (20 Nm). Remember to include the vacuum pump seal.
Reinstall the valve cover with a long 5‑mm Allen socket to 7 ft-lb (10 Nm). In my case, I had to reconnect the Oil By-Pass filter line to the valve cover.
Reinstall the vacuum line support bracket with a ¼-inch drive 10‑mm deep socket or 10‑mm offset box wrench underneath the vacuum pump, and then the vacuum line.
Reinstall the three glow plug wires in front of the vacuum pump.
Reinstall the upper timing belt guard, which is held in place with five (5) clips.
Reinstall the EGR or race pipe, if removed.
Reinstall the upper intake pipe and hoses to the EGR valve or race pipe and to the intercooler.
Reinstall the passenger side headlight and the bumper cover in reverse order of disassembly.
Reinstall the fuel lines (2, 1, 4, 3) by tightening to the lines marked at the beginning of this modification with a 17‑mm open-end wrench, making sure they are adequately tight.
Pull the rubber plug from the injection pump fuel supply inlet. Install the fuel supply line connector on the top of the injection pump with a 17‑mm deep socket to 18 ft‑lb (25 Nm), using one of the new copper washers.
Install the banjo return fuel line and cap nut onto the injection pump with a 17‑mm socket to 18 ft‑lb (25 Nm), using three (3) new copper washers; one between the injection pump and the union, and one each on both sides of the banjo return fuel line.
Reinstall the braided return fuel line from Injector Nr. 4 to the injection pump, including placing it back on the plastic clip attached to the vacuum reservoir bracket.
Reinstall the two fuel line clips with a 10‑mm socket.
Reinstall the vacuum reservoir ball and CCV system.
Reinstall the fuel supply line and remove its hose clamp.
Prime the injection pump by drawing diesel fuel using a hand operated vacuum pump (e.g., Mityvac Model 04000). At first, there will not be much vacuum pressure, but keep pumping. Air bubbles will be seen in the clear fuel supply line, but then they will go away. As soon as the vacuum pump holds pressure, you should see a little diesel fuel exiting the return line.
Reinstall the fuel return line and remove its hose clamp.
Crack loose the nut on top of Injector Nr. 3, wrapped a shop towel around it, cranked the engine a few seconds until some fuel comes out, and then retightened the nut. Repeated on Injector Nr. 2. This will additionally center the timing belt on the pulleys and allow the tensioner to remove any slack.
Start the engine. It should take only a few seconds of cranking the engine before it starts. The engine will likely cough and shudder a little, but then quickly settled to a nice idle.
If the engine will not start, even after priming the fuel line, recheck TDC and check if you missed something.
Check to make sure there are no fuel leaks. Also, if the thermostat was changed then be sure there are no coolant leaks and the level of coolant is correct.
Reinstall the skid plate or belly pan, and lower the car off of the jack stands. Re-check the coolant level if the thermostat was changed.
rocketeer928
Fine Tuning the Injection Timing with VCDS
Assuming the car is running OK, rev the engine at about 2,500 rpm until the coolant temperature gauge is sitting straight up (ideally at least 85°C or 185°F). Alternatively, go for a drive until the engine is heated up.
Keep the car running at idle.
Connect the VCDS cable to the car’s OBD2 port and to your Windows PC. Start up the VCDS software.
Click the “Select” button under Select Control Module.
Click the “01-Engine” button.
After VCDS has established a connection with the ECU, click “Meas. Blocks – 08”.
Select Engine Measuring Block 000 and click “Go!”.
Click the “Switch to Basic Settings” button.
Click the “TDI Timing” button, and a graph like this will appear, and the glowplug light on the instrument panel will flash.
From the drop down menu in the lower right corner, select either “1.9l R4 TDI AGR/AHF/AHL Golf/Jetta (pre 04/1999)” or “1.9l R4 TDI AGR/AHF/AHL/ASV Golf/Jetta (post 03/1999)”, depending on the year of your car.
The horizontal and vertical yellow lines apex is where the timing is set, and should be between the upper green diagonal line and the bottom red diagonal line. If there are no yellow lines, the timing is very retarded, and if there is only a vertical yellow line, the timing is very advanced. An adjustment to the injection pump sprocket will need to be made.
Here’s a link to an excellent discussion about advanced vs. retarded timing, exhaust gas temperature (EGT), and fuel economy: http://forums.tdiclub.com/showthread.php?t=240450 .
Edit 2010-09-20: Here's another good guide on the pros and cons of advanced vs. retarded timing: http://forums.tdiclub.com/showthread.php?t=139762
You will need to decide if you want your timing advanced, retarded, or right in the middle. Slightly advanced timing above the center blue diagonal line will likely cause slightly higher EGTs, engine stress, and higher power. As seen in the picture, my timing was nearly dead on without making any adjustments (was not planned that way).
I tend to advance my timing just a little.
If you need to adjust the timing, shut off the engine.
Remove the upper timing belt cover.
Loosen the three injection pump sprocket bolts with a 13‑mm socket.
Slightly rotate (and I do mean slightly) the injection pump center hub (shaft) using a wrench carefully on the center nut on the injection pump shaft. Rotating the center hub (shaft) counter-clockwise will retard the timing, and rotating the center hub (shaft) clockwise will advance the timing.
Retighten the three (3) bolts on the injection pump sprocket bolts with a 13‑mm socket just enough to hold the sprocket. Then tighten them to 18 ft‑lb (25 Nm).
Recheck the timing using Steps 1 – 11
In this picture, I advanced my timing too much and had to adjust again.
It took me three adjustments to get the timing slightly advanced, as I like it.
Reinstall the upper timing belt cover.
Reinstall the upper engine cover with a 10-mm socket, or push it back on if you’ve retrofitted it like I did.
You may need to clear some engine and other fault codes with VCDS after all is finished. Make certain that any fault codes were created while replacing the injection pump, and that you don’t some unrelated problem.
That’s it. Drive and enjoy!
manual_tranny
Smyth Performance- Intern
New Bedford, MA
2001 Golf @182K; 2000 Jetta @290K
Spectacular DIY, so much detail! I'm very impressed with the language/picture quality. Thanks for adding so much to the forum!
03PlatinumTDI
Mooresville, NC.
Diesel Free after 14 years
Rocketeer928 - Thank you so much for writing this up. I've used your write ups numerous times to mod my car myself and couldn't have done it without it. You should start teaching classes on how to modify a TDI. Your a real asset to the TDI community.
ymz
Between Toronto & Montreal
2003 Jetta TDI Wagon, 2003 Jetta TDI Wagon
Good work - with two nits to pick...
When you describe the final timing adjustment, you use the word "sprocket" when you mean "hub" (or "shaft")... One turns the center hub (shaft) actually attached to the pump mechanism forward to advance the timing, not the outer sprocket...
The other nit is the long-debated preference of many here to not use the camshaft sprocket to turn over the engine, as that places too much strain on the tensioner... Many here use a 12 point 19 mm socket on the bolt holding the crankshaft sprocket (and harmonic balancer)... of course, that often means that you need a helper...
As well, why did you need to remove the passenger side headlight and the bumper cover??
Yuri
rocketeer928
Thanks Yuri. I don't mind some constructive criticism (nit picking). On your first point, I think folks will generally get the point, but I made the change for accuracy. On the second point, I did not have a "helper" and I suspect most other will not either.
I didn't need to remove the passenger side headlight and the bumper cover for this particular job. But, I did so for other unrelated reasons beyond changing out the IP. Killing two birds with one stone.
BleachedBora
Gresham, Oregon
'81 Caddy CBEA 250 hp/450 tq, '05 E320 CDI, '81 DMC-12, '15 Q7 TDI, '98 Land Rover Defender RHD TDI
Excellent writeup! Thanks for the contribution!
-BB
runonbeer
Maintenance EnthusiastVendor
Austin, TX/Chapel Hill, NC
'00 Golf 02M, '10 Golf 02E, '02 UTE 02M
I have some nits to pick too.
-why did you take off the two clamps that hold the two sets of lines together? They go back in a lot easier if they are grouped.
-vacuum res. ball is held in with 6mm (not 8mm) bolts.
-you're better off clamping off the fuel pump supply lines closer to where you pulled them off the pump. Otherwise, all the fuel in the length of line will drip out.
-Re: valve cover bolts. No need to pull the EGR valve, just use a 5mm long ball end socket bit.
-Re: timing belt removal. loosen pump pulley bolts while belt is fully installed and tensioned. THEN, relieve tension. loosen cam sprocket bolt. pop cam sprocket off. move the belt out of the way. remove pump pulley bolts. You don't even need to pull the pump pin out of the tool box until you're ready to put the belt back on the new pump.
The write up has the belt removed before the cam sprocket is popped and the pin is used unnecessarily (even after the pulley is removed from the old pump???). You fully removed the IP pulley bolts with the belt installed and tensioned????
That's scary. Find the mark.
  • Using the Compact 3-way Tensioner Wrench in the center holes of the belt tensioner, tension the belt by turning clockwise until the notch and the raised mark are aligned. Cars with an automatic transmission use an Allen wrench on the belt tensioner, according to Bentley Page 23-18.
All TDI engine/trans use the 2-pin spanner tensioner tool. Not sure why the bently would say otherwise.
+1 Yuri's nits.
As I've always said, if you're changing a pump there is no need to do the timing belt "while you're in there" because (as you can see) you are not "in there"
-rob
ymz
You're probably too young to remember the really-old-style tensioners with the Allen head used on the automatic transmission cars back then...
Yuri
rocketeer928
This is just the way I did it, period. It was "easier" for me.
It might be a 6-mm bolt, but it takes an 8-mm socket to remove. Duh!
Insignificant point, really.
This is really insignificant too. I pulled my race pipe for a secondary reason unrelated to the IP change. You can see in the picture that I am using a 5-mm long ball-end socket bit.
Pretty much followed the Bentley and another timing belt "How-To" that I had. I guess there is more than one way to do things.
You don't have to follow my "How-To" if your such a professional genius (sarcasm intended). However, I'm sure other garage mechanics will find this "How-To" helpful.
Not so scary when you've got three other TDC indicators under control.
runonbeer said:
+1 Yuri's nits.
I already took care of Yuri's Point Nr. 1. His second point is well taken, but I did not have a helper. Besides, it's too late now; the job is done.
TDIJetta99 said:
pretty decent write-up, I'm sure a LOT of people will find it helpful.
My personal record for changeout time is 1 hour, done at HO5G, haha...
Thanks Jason. At least one mechanic/vendor finds my write-up decent and helpful. It probably could have taken me less time, but I was taking pictures and writing down notes for this "How-To" write-up.
Looking forward to the GTG next Saturday.
TDIJetta99
Port Jervis, New York, USA
03... Faster than yours =]
Hehe, the vacuum reservoir bolts are 8mmX1.25 thread, and use a 6mm allen to remove them, unles you're talking about the little screws that go into the plastic reservoir, they use an 8mm socket.
eddie_1
Hannover, Germany formerly Toronto & NY
Jetta Wagon 2003 TDI tuned to 170HP, A6 Wagon 2008 TDI 2.7L tuned to 340HP
Absolutely phenomenal Chris! Very timely for me since I am contemplating this as my next mod if i can find a decent used one that i can afford. Couple questions I had was 1) Why did u need to pin the old IP that was on its way out? 2)Do you have to prime the pump if you have the Lift Pump? thanks! ~ed
rocketeer928
I suppose that I didn't absolutely need to pin the old IP. However, it is what the Bentley manual recommends, so I did so to be on the safe side. I'm not sure if the PD Lift Pump would prime the IP; didn't try that.
MrErlo
Omaha, NE
2003 Golf 4dr 5sp
Herere's a PDF version for people to download
Great write up, I'm currently working on replacing my 10mm with an 11mm and someone pointed me over to this thread. I like to have things available offline, so I took the time to copy and re-format the entire write up to PDF.
If anyone has any comments about formatting or corrections you'd like to see included let me know and I'll update the file.
EDIT: I removed the part about the bumper and headlight from the PDF, since it's not really necessary for the normal job. I made some other formatting changes that I missed the first time. This dropped it back to 20 pages total, so a perfect fit for 10 double sided pages.
eddie_1
I did this last weekend while doing a TB job. To be honest most of the steps are to do with the TB job. The steps associated with the IP pump change are trivial. All it requires is remove/replace the pump 4 bolts, transfer the IP sprocket 3bolts, reconnect the fuel lines and connect the electrical connector. Here is the condensed version: :D
You need to lock down the engine in TDC (Need some TB tools), relieve TB tensioner, remove cam sprocket to release belt. Then remove ip sprocket 3 bolts, change out IP only four bolts and reattach IP sprocket. Then mount belt (trick here is to use cam sprocket with belt on). Retension belt with ip pin in and loose ip sprocket and loose cam sprocket. Tigheten up sprockets. Then 2 revs to check tdc. Finally retime with Vagcom small adjustments of ip sprocket position.
ymz
You forgot to add: when one of the pump mounting tabs strips its threads as you're torquing down the new pump: "Run down to the local hardware store and buy a suitable bolt, washer, lockwasher, and two nuts to hold the pump in place"...
Yuri
Duster408
Scranton, PA
1998 Jetta
Yuri
You're kidding, right?? Heli-Coil
rocketeer928
Nice job on the PDF. I would have done the same, but I don't know how to upload PDFs on the internet without cost to me.
MyTurboDiesel.com also wrote up most of my How-To, which can be found with these two links:
1. http://www.myturbodiesel.com/1000q/a4/IP-removal-TDI-engine.htm
2. http://www.myturbodiesel.com/1000q/a4/Injection-pump-removal-ALH-2.htm
I guess I'm starting to be immortalized in the TDI world. That certainly wasn't my intention. I'm just glad folks are finding my write-up useful.
Yuri
There's always got to be a pessimist in the crowd, eh? Must be those cold Canadian winters. Yuri, you always make me chuckle.
ymz
I'm afraid not... On a Sunday afternoon of a long weekend, there's no hope in #3!! of finding a proper Heli-Coil kit... in this case, the bad mounting hole was the one on the front edge of the pump (ALH motor)... access to the nuts is wide open... repair is far stronger than the original...
Yuri
