TDEyes
I have a 2002 Jetta TDI with over 200K miles and have always filled to the brim after a guy showed me the vent release trick at 10K miles. This gets me 2.5 gallons more more fuel @ 40 MPG = an extra 100 miles before pump time. Never a problem.
So the paint gets worn and my windshield cracks so I went out and bought a new 2013 Jetta TDI last weekend. Well, on my first fill up I decide to try to top off knowing the misfuel adapter would make that a challenge. Sure enough I over fill and spill fuel. Now I'm pissed! The misfuel restrictor has to go NOW! I know it's a risk especially if you loan your diesel to someone who is used to gas.
I figured out how to remove the misfuel adapter and fortunately the process is reversible and repeatable so you can take it out and put it back in at will.
My inspiration for doing this is a procedure I found online for Audi. It is not the same but it gave me enough to figure out the removal process for the 2013 Jetta. It gives a good mental image:
http://audi.workshop-manuals.com/a4-mk3/index.php?id=1539
How I removed the misfuel adapter for my 2013 Jetta TDI:
Go here to see pictures in the photo album - http://pics.tdiclub.com/showphoto.p...removal2f-installation-2013-jetta-tdi&cat=516
Note the picture of the filler neck is after removal of the misfuel adapter assembly.
Make a small hook from coat hanger or stiff wire.
Find or make (from hacksaw blade maybe) a tool to insert in the 4 o'clock slot to push the retainer barb from its latching position in the filler neck. The tool I used is from a lock pick set and worked perfectly. Some twisting was necessary so the end of the tool pushed the barb from its latched position. Maybe if the tool was bent inward at the end that might work as well...
In my case I only had to release the latch at 4 o'clock but you may also have to do the one at 10 o'clock too. Use the hook to apply a gentle pulling force while releasing the latch(es). Lastly, after I felt the 4 o'clock latch release I used a small blade screwdriver at 12 o'clock to push the assembly slightly downward at which point the misfuel assembly came free and pulled straight out.
To re-install the misfuel adapter assembly just insert and push in until you hear the latches click. The assembly has asymmetrical features and cannot be installed incorrectly.
Now I have to wait to my next fill up to see if I can get the additional volume after the pump clicks off - no vent release though, appreciate your thoughts here. The fuel economy of the Jetta TDI's are great but I really cherish the range as I commute 80 miles 5 days a week and love infrequent visits to the pump.
