vwman2
Hello all,
Wife car 2010 golf tdi dsg with 160k now on original brakes are needing replacment. To my knowledge the brake fluid is still original so definitely over do for change. I have been reading various posts about doing the job but I'm confused about the abs system, on my turbo diesel it says you need a vcds to run the abs pump but other threads I have been reading don't mention it all. I don't have vcds at this time. Also as how to get all the fluid out I'm not clear on best way to go at this. I know the turkey Baster method to empty the resiiviour but do you drain/bleed each caliper or empty them all first.
Thank you everyone
Jamie
Thank you everyone
Jamie
