kurtzl
My '98 AHU has been missing the T-bolt and nut for the lower timing belt cover for as long as I can remember. When I replaced the timing belt most recently, I discovered evidence that the serpentine belt had been rubbing on the cover so decided I should at least try to replace the bolt and nut.
It turns out that replacing the bolt and nut was far easier than I expected, so I thought I'd post my method for anyone else who wants/needs to attempt replacement. As you'll see in the pictures, I was replacing my water pump at the same time (just the impeller, not then entire housing). I believe this method will work without having to mess with the water pump at all.
