Fix_Until_Broke
And it appears that I'm wrong again - I just had to run another errand and left the pump unplugged, started 2 more times just fine and noticed a bit of stumbling coming away from one stoplight and a couple miles later I tried killing it with my dash switch (I was close to home) and it died, but I couldn't re-start it by either bump or starter method - so I plugged it back in and after a bit of cranking, it re-started just fine.
Will this instantly leave you stranded if it fails? I guess I'm testing it failing electrically, not mechanically, so if the pump/motor locks up or something then maybe it could, but if it fails electrically, I don't think so. You might get stuck at the next place you shut it off though?
Just testing the operation here
