TdiRacing
After all of the questions, I feel that it may be helpful for many others to have some pictures on hand on what to look for when inspection your PD cam and lifter for wear. I would advise that this should be done every so ofter to avoid any failures. Use this info at your own risk.
First off, remove the valve cover. If you are confused already, please seek the help of someone who knows what they are doing.
Look at the cam lobes and see if there is an discoloration or if there are radial score marks on any of the lifter lobes.
This is an indication of some damage. Discoloration and scoring.
This is normal. See the nice mirror like polished look. No scoring here. This had a good lifter under it. Notice also the slight chamfer on the edge of the lobes. ie rounded edge. This is important. If you run your fingers along that edge, you should not feel a lip there.
When the cam gets damaged, it peens the metal over and the chamfer is gone and you can feel a sharp edge there. NOT GOOD. Like it this above picture. See the chamfer is gone! Metal is rolled over.
Here is a lifter comparison. Left is normal wear. Right is the damaged lifter. This went with the discolored lobe above. Notice also the wear pattern and damage on that lifter. You can visually see this with a mirror when inspecting them. You may have to rotate the cam/engine over to see each one well. If the lobes are not really perfect and shinny, then you need to look closer for other signs. I hope this pics help clearify what you are looking for.
Here is what new lifters look like. The right ones are VW ones and have a high tech coating on them. This is what I used in my engine. along with a NEW cam, bearings and all the necessary seals and hardware.
