A question for those who have gotten a Kerma tune:
One thing that appeals to me is the ability to put the stock tune back in if you need to take the car to a dealer for warranty work. Obviously if I'm hoonig and break a con-rod, that's not on them. But if some part of the emissions system fails in a way unrelated to the tune, I think VW should fix it.
Since TDIs that have been diselgated have an emissions warranty that lasts through '26 (11 years from manufacture) this is significant.
However, as I understand it the dealers' scan tool can tell if the ECU is been modified, and if it has, it will permanently tag your VIN with the "TD1" code, which cannot be undone, ever.
I *think* the TD1 code is something only in VW's computers, and not in the *car's* computer.
When you get a Kerma tune, the first thing you do is email them a file that came out of your car. They use that to make a spiffed-up one and email that back. You then have two tunes in the dongle they send you: the original, and the modified one. (and presumably any subsequent tunes)
So that leads to the question about putting the original tune back in the car: Does it actually re-flash the whole ecu? Does it put the ECU in a state that makes it impossible for the dealer to know you've added and removed a tune?
In VCDS, this is what I see in my car:
Code:
Flash Status
Programming Attempts(application): 2/2/2/2/3
Successful Attempts(application): 2/2/2/2/3
Flash Date: 19.11.04
Nov. 11, 2019 is when the second stage of the dieselgate fix was installed (according to the sticker under the hood)
Does "restoring the original tune" reset the flash status to whatever it was, or is that somewhere else?
I'm assuming that if the flash status data doesn't match what's in VW's mothership computer, the TD1 flag gets set. (assuming, I don't know)
