Use the right head gasket. the "thickest head gasket" approach is really lame.
The simple way: Part of your head gasket protrudes from between the head and block. There are some holes in that part. The oblong hole means nothing. If you find BB-sized holes, one, two or three, then that relates to the head gasket you need.
The exacting and precise method: Pull out your Bentley book and turn to page 13a-17.
There is a diagram that shows a rather obtuse way of measuring the piston projection and a chart for the piston projection. Basically, I use a flat plate with a dial indicator sticking through it, but you can use a variety of measuring methods; vernier caliper, depth mike, shims... measure in line with the wrist pin on both sides of the piston.
The dial indicator is easiest as you zero the dial on top of the piston and look for the highest reading as you roll the engine over. Otherwise, find TDC and use one of the other measurement methods.
For an ALH, a measure of:
.91-1.00mm (.0358"-.0394")is a one-hole head gasket
1.01-1.10mm (.0398"-.0433") is a two-hole
1.11-1.20mm (.0437"-.0472") is three-hole
If you measure front or back on the piston skirt sides of the piston, you will get a false reading, as the piston can rock in the bore. Readings should be taken in line with the wrist pin.
