greengeeker
All in all, not a bad job. Very similar to a BRM job mixed in with some ALH bits. Special care needs to be taken since you crack the fuel system and need to completely bleed all the air out. Because of this I wrote a supplemental how-to at the end on how to run the output test as well as the basic settings test (is there already be one of these?).
I've also thrown in a little more information explaining the proper use of the BEW/BHW/BRM/CBEA/CJAA timing belt tensioner during the R&R of the belt. We took some video during the job and I'm working on getting those posted to youtube.
Please let me know if you find any errors or have any corrections.
Thanks to DanG144, Kriesel, Coalminer16 for the advice, help with pictures and just overall moral support.
To supplement the timing belt procedure I created a video showing the tensioner procedure (video is of a PD timing belt but the tensioners use the same pin feature): http://youtu.be/lM13IXokpuI
Discussion in the How-To: PD Timing belt video thread
