How to check total no. of regenerations using vcds?
amitsekhon
Langley,BC (Canada)
2015 Golf TDI,,,,,, 2010 X535D Diesel ,,,,,,,,,,,, 2002 Jetta manual TDI ALH (Sold)
How to check total no. of DPF regenerations using vcds?
Hi friends, Wondering if there is any way to check the total no. of regenerations done on the filter so far using VCDS on my 2015 Golf TDI with 2800 kms(1700 miles) on the odo?
I tried using advanced measurements on the ECU but couldn't figure it out.
These are the values i read.
Saturday,22,July,2017,18:40:36:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
www.Ross-Tech.com
VIN: 3VW License Plate:
Mileage: 2826 Repair Order:
Address 01: Engine (04L 906 021 D)
18:39:56
IDE00019 Voltage terminal 30 12.380 V
IDE00436 Particle filter: kilometers since last regeneration 176663 m
IDE05507-ENG104207 Current mem area of the diesel particulate filter statistics-Bit 0 9
IDE06059 Particle filter: oil ash volume 0.7 g
IDE06060 Particulate filter ash load limit 80.00 g
Any ideas please?Thanks
amitsekhon
Langley,BC (Canada)
I scanned it again after around 150kms and calculated that my car had regenerated after 300kms(~185miles) with a mix of city and hwy driving.Thats approx same distance my BMW X5 35D regenerates after.
How many kms are you guys getting between regenerations normally?
