This whole procedure is best with two people, your having an issue with something an extra pair of hands helps.
I just did the LCA Bushings and Ball Joints this is what I found out to work best.
You need impact, if you dont, pay someone to do this job.
When reinstalling the A Arm back on the car make sure to have the ball joint installed on the A-arm. First get the rear bushing in place First with the bolt and nut just a few threads, then do the front bushing bolt just a few threads, turn the steering wheel to which ever side that makes it easier to get the Ball Joint into the knuckle. Just pull on the rotor and you'll get it. If you do try to do the ball joint first you will not get the Rear bushing in place to bolt.
Use the bearing press that is mentioned in previous posts to REMOVE the LCA rear bushing but DO NOT use it to Re-install; instead use the vice and wood method. Instead what I did was use one of the spacers/adapters from the ball joint press kit; in combination with the bench vice and a drilled out piece of wood for the back side of the A-Arm. Make sure to have the vice jaw in the middle of the spacer otherwise when the pressure takes over the bushing will go in crooked; this is also why it is good to have an extra pair of hands as you may have to hold every in place rather than rest it on the vice. Take your time, and always pull it out to check the distance and evenness. The reason I say do not use the bearing press to install is that it goes too fast and its too hard to keep straight if using a impact or ratchet, the whole tool starts to move about and it will not supply pressure evenly.
I did not see it mentioned but the Rear Bushing needs to be flush with the metal lip that is welded onto the back side of the A-Arm, if it is not, then you installed it wrong.
I started putting in the bushing it was going in wrong, it was half way, I got it out and no damage, no need to freeze, just use a bit of grease of the outside of the bushing.
To get the Ball Joint off the car (providing you are installing a new set) you do not need to put the rotors off the axle. This is what you do, maybe it was already mentioned. Turn the nut until it butts into the axle, and continue until it "pops", then get a cheap blue bottle propane torch and put it on the nut until the nylon in the nut fries, you will see it smoking and making a burning sounds. Now you can get the nut off other wise the ball joint shaft will turn along with the nut. -- Upon installation you will run into a similar problem, but my new ball joint did not have a locknut so I turned it until the ball joint shaft was turning, assemble the rest of the car, take it off the jacks, turn the steering wheel all the way left than right, then you should still be able to turn the ball joint nut with the car on the ground, but I only get about 2 or 3 threads protruding until the ball joint shaft started to turn, I assume it will not back out as they are spinning together now.
