How to block your front grill with pipe insulation
Lensdude_com
Edmonton, AB
99.5 MK4 Jetta (ALH) "Betty" (sold), 2005 MK4 Jetta (BEW) "Stinky-Pete"
I keep 2/3 of my rad covered by coroplast when the temps are above 20C/70F and fully covered below 15C ...I cut 3 strips that are inserted one at a time through the lower center grille and fit directly against the radiator fins
  • Like
Reactions: Ton
mr_y82
Western NC
Used to have... '11 Golf, 6-spd, 2-door
nice timing on the revival... I started reading previous comments and thanks to the date it took me a minute... deja vu! guess I will slap the thing on this winter even though we will probably be selling it back next summer...
  • Like
Reactions: Ton
UhOh
PNW
2003 Golf GLS (2005 Mercedes E320 CDI)
Was working fine, until we got geese!:eek: Darn things, geese, have to peck and nibble at everything (I have a picture of our 1 1/2 dozen or so geese surrounding and pecking away at the daughter's wagon:D) After picking up the pieces of insulation, with divots, off the ground I gave up.:eek: Anyway, if you don't have geese, or other nibbling critters, I endorse this mod.
  • Like
Reactions: Ton
csstevej
north nj
2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,glutton for punishment got another tdi 2001NB,another yellow tdi NB , added an 06 NB DSG
Lol just installed mine yesterday........I'd shoot the geese
  • Like
Reactions: Ton
Mongler98
COLORADO (SE of Denver)
I took a bandit road sign and cut it to fit and slipped it between the AC and the RAD and held it in with a zip tie. ran fine all winder in -20 and 60*F no issues, they are free on the side of the road. dont feel bad for taking them, they are all illegal btw, you need a sign permit to put them up and no one ever does. i know, i have min taken down all the time and a phone call sent to the number that is on them all the time saying that i have to pay fines and stuff, lol
  • Like
Reactions: Ton
ranger pete
connecticut
2011 JSW 6MT
I am the new owner of an '11 JSW MT. I am considering doing some level of grill block, but am concerned with my temp gauge.
I read somewhere that this gauge is more or less an idiot light. That being the case, I am worried that I could overheat it before the idiot gauge told me what was going on.
Would like to hear from those with experience with this.
  • Like
Reactions: Ton
Fix_Until_Broke
03 Jetta
In general - you can block the front completely and in "normal driving" you'll be fine - actual coolant temps won't move at all.
Now if you're pulling a trailer, up a hill, in death valley with the A/C on, you'll probably run into some troubles, but as long as you're just driving around - nothing to worry about.
If you have a scangauge or any kind of OBDII monitor that you can watch on your phone, you can verify for yourself and/or keep an eye on it.
  • Like
Reactions: Ton
Judson
Cheyenne, WY
2001 Jetta
I cut cardboard into two “L” shaped pieces, then remove the grill (just need to pull out and maneuver out of the way).
Then I slip the pieces in, lower L part first, so they end up forward L and backwards L in front of the radiator.
You can use a measuring tape to determine width and height.
They essentially block most of the radiator and make a big difference and are reusable. They never get charred or burnt or damaged in any way.
  • Like
Reactions: Ton
John Wesley Hardin
Rockport Texas
It's that time of the year again, when plummeting temperatures send us scrambling to dose our fuel and crank our seat heaters to 11. Ever wanted to block off part of your radiator to help your engine warm up faster? It's very easy to do and can help you get better fuel economy, perhaps lower engine wear but most importantly get heat to the passenger cabin faster. This is very easy & cheap, but I thought some of the less imaginative or mechanically inclined may benefit from some pictures. This was done on my 2006 MkIV Golf TDI.
Go to your local hardware store and buy 3 meters (9') of foam pipe insulation for 13mm (1/2") copper pipe (or 10mm iron pipe - pipe sizing is weird, but pipe threading is even weirder). I found it at my local Menards for the whopping sum of $1.64. Menards is a midwestern chain of giant hardware stores, kinda like Home Depot or Lowes, but without all the suck. The pipe insulation usually comes in 2 meter lengths (6') but for some bizarre reason, it was in a bag of four (4) one meter lengths. Whatever. It costs less than $2 total and more than you need.
Note that this is dark grey, which blends in better. Sometimes it is brown or black. It will still work fine. Don't worry. Have a homebrew. Also notice the package is half French. That's because this stuff was hecho-en-Canadia.
Take out a piece of it and notice there's a slit down one side. That's how you would put it around a pipe. And that's how you're going to put it on your grille. Open up the slit by running a finger down it:
Then slide it in place over a slat in your upper grille, and trim to length with your pocketknife:
Repeat three times, and the upper grille is done.
Give it all a nice push to get it settled in there.
Now do the same thing on the lower grille slats. Don't bother with the bottom-most as it doesn't actually go through.
But before you slide those in place, I like to cut some slits to match up with the vertical grille bits, shown below.
Those help it sit nice and far back into the grille openings and block out that awful cold air.
Do that for both lower grille slats and you're done, honkey.
It may seem a little flimsy but I've never had a piece become dislodged for any of the past 3 winters.
Enjoy!
scurvy
Enjoy!
scurvy
  • Like
Reactions: Ton
John Wesley Hardin
Rockport Texas
Enjoy!
scurvy
  • Like
Reactions: Ton
John Wesley Hardin
Rockport Texas
Thats what happens to me. I have a 35 mile trip one way to work. In winter here it does get down into the 20's believe it or not.
So Im freezing my ass off for about 20 minutes then I get some heat. Just about the time I start getting nice and toasty Ive arrived at work and have to shut it down . I think I will try this. Besides no one will notice anyways, the preferred method of repair in S. Texas is duct tape so who will care anyways? " South Texas Third World Living At Its Finest "
  • Like
Reactions: Ton
P2B
Toronto & Muskoka, Canada
I tried it once and didn't notice a difference. If the engine hasn't reached operating temperature the thermostat hasn't opened and there's no coolant flowing through the radiator anyway.
  • Like
Reactions: Ton
Chrisperro
Vancouver, Canada
2013 Golf
Bump for this coming winter.
Just did mine with pipe isolation ,7$ at Rona for 12 ft , just the bottom grill
Will see if warms faster tomorrow and update.
Update.
Definitely this morning the car warmed up faster. I will say 25% faster than usual.
The only issue that I see is the insulation getting wet. Is pretty much like a sponge.
  • Like
Reactions: Ton
GP_RZ
Alliston, Ontario
2003 Jetta Wagon 5 speed
Going to get some pipe foam and try this out... I have 70 min commute each way, have been with low heat and was not fun in sub zero temps.
