HOW TO and do-it-yourself threads
spooner55
las vegas nv
'06 jetta tdi
does anybody know how to work on the Airbag censer on passenger seat? our 2006 jetta TDI has put up the airbag light and now says passenger airbag "OFF"
thanks for any help, john
TonyJetta
Tucson, Az
'15 Jetta TDI SE / '06 Jetta TDI DSG Pkg0 / '96 Passat TDI
Do a search to confirm this is the fix; I am going by memory from 4 years ago.
If it's the typical problem with the airbag in the passengers' seat, the fix:
  1. Remove the passenger seat
  2. Disconnect the airbag and seatbelt cables
  3. Using either solder and heatshrink tubing or crimp butt splices, cut out the 3 pin connector for the airbag, in the bottom of the seat. This is the connector that is causing the airbag code.
  4. Reconnect airbag & seatbelt cable
  5. Install the passenger seat.
Tony
RGC
England UK
3.0 V6 TDI
I had this problem and solved it by using a zip tie on the wire under the seat, this stopped movment on the connector thus stopping the airbag light. :D
see picture below:
Charlie2tight
plantersville, texas
2011 golf TDI 4 door hatchback
I am trying to change the dsg fluid in my 2011 golf tdi. I have the filter and dsg fluid already, Is there a vidoe on this. I have a 10,000ibs lift at home and i looked under the car and see the drain allen bolt. I think the filter is under the battery box? I have a pressure bleeder,filler but it has a hook type nozzle on it. I would like to know tips, tricks on this. I got all my materials form idparts. :confused:
loganbmx4gt
Jackson, TN
97' Passat (1Z), 02' Golf
DSG How-To
deltatech
Jefferson NJ
2004 Jetta TDI
I have a 2004 Jetta w/PD BEW engine. My key fob stopped working. It won't open the doors remotely-it will lock the doors and pop the trunk. I guess I have to replace the remote part of it. I know how to get it apart and I have a key fob that I found at the bottom of a box at a rummage sale. Can I just use the remote from my found fob?
apcopatech
Maize Kansas
2013 Golf Base TDI DSG Reflex Silver Metallic
amp and sub add
where do I put the speaker taps?
behind the head unit or is there another place where I should put them?
is there a video on how to add an amp and sub?
how hard is it to remove the head unit's face plate?
or how easy is it to break it? lol!
I have a 2013 gulf 4 door with DSG!
and is there a way to find out what the watt per channel is on the base hd radio?
swampmarine
Kansas City, MO
1998 Jetta TDI, 2003 Jetta TDI, 2006 Jetta TDI
Changing the turn signal bulb in the mirror
Does anyone know how to change the turn signal bulb in the mirror of my 2006 Jetta?
I got the replacement bulb, but can't figure out how to take the old one out. I don't want to damage the mirror; the bulb was $60 so I would hate to guess what an electric mirror would cost.:eek:
Thanks in advance!
aznav
"The Valley", Virginia
2012 Jetta Sedan
Wow!
Whoa! Wingnut, good on you for an incredible thread. You put a lot of work into this. Many thanks from a newbie to the forum and TDI's!
baby
new york
2003 vw jetta wagon
03 vw jetta wagon tdi only 84,500 with warranty for sale!
hi i am new here, how do i post an ad here?
SkiWell
MN
2017 golf Alltrack S manual Gey/Brown
Cabin filter change
Hello,
Can anybody help me on how to change the cabin filter on 2013 Jetta sportwagen(manual, tdi) Thanks!!
nj1266
Long Beach, CA
Golf
Can someone please tell me how I can remove the plastic mirror cover off the mirror assembly. It is the charcoal colored part in the picture. All i know is that it clips into the turn signal in the mirror. TIA
Sent from my iPhone 7
Kalkaska Mi.
Jetta, 2006, Campanella White, Anthracite Int. DSG, Pkg. 1; New Beetle, 1998, Yellow, black leather Int., 2013 Passat TDI SEL Night blue, grey Int. given back to VW (well, not given... ;) ) 2018 Tiguan; first gasser in years
nj1266, bobent et al. I believe you would get more help if you posted your questions to the TDI 101 forum or possibly to the appropriate forum for your vehicle model/year. This thread in the TDI 101 forum is for solutions and/or how to solve problems in these vehicles. Once you find the solution to your problem(s) feel free to post them here with as many pictures and descriptions as you can. Those of us searching this thread for "How-tos" will thank you, especially if the thread doesn't get so big with posts unrelated to the original intent of the thread that searchers give up. Now that I've contributed to the problem also...:eek: :p I'll shut up.
Ondrej
Maryland
Passat SEL Premium TDI
2013 Passat SEL TDI
Hi, I purchased new 2013 VW Passat SEL TDI in April of this year. I am definitely happier with mileage per gallon compared to Nissan Maxima 2010 that I leased. On average I get around 35 mpg in city and highway combined.
I am still finding the most comfortable sitting and left arm position when I am driving. I like to rest my left arm on the window panel and control the wheel with the same hand only at the joint point of the wheel spokes. I can't seem to find permanent comfortable spot. I welcome any suggestions.
I need to buy a new bike rack and would like to instal a hitch for multiple use, but primarily for a bike rack. I don't like the trunk mountable racks as they scratched my car in the past. Would consider top racks for bikes, skis, etc. Occassinaly I may haul a small trailer for a short distance.
Please give me some ideas, suggestions, cautions about a hitch. Thank you very much!
Ondrej
Burtonsville, MD
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Ondrej
Burtonsville, MD
Use Google Advanced search to find things, use keywords and specify tdiclub.com as the domain
TonyTM2
Upton, MA
2006 Jetta
Power lock electric connector
I just changed the drivers door wire harness in my 2006 Jetta TDI. Everthing is done except the power lock. I can't figure out where the release is on the connector. Does anybody know?
RGC
England UK
3.0 V6 TDI
take a picture and show us :)
motopsycho85
Surrey bc
ahu
how to build a mtdi
I recently wae given a ahu tdi engine and I would like to convert it to mtdi for the pure simplicity. I have no idea of the parts I will need to aquire but was hoping someone could help me make a list. What pump? 300 tdi rover pump? What injectors and injector lines do I use? do I need to make custom lines or will stock fit? I have the money to build it and am mechanicaly inclined. Please help me make a complete list. Thanks in advance
TonyJetta
Tucson, Az
I would start a thread in the performance or cinversion section. You'll get the right attention, there!
Tony
Sent from my e-diesel fleet
brussell
syracuse,ny
2003 jetta
i am a newbie. I own a 2003 jetta tdi with a bad transmission and bad rear brakes. All else is in good shape. I want to sell it. I can get $250 for scrap.I can get $400 from a junk yard. I think it should be useful to someone for parts for $800 to $ 1000. Is that reasonable. If so; I would like to advertise it here. How do I go about doing that? Thanks, Brian
jsrmonster
Red Lion, PA
15 Golf SW DSG, RC3 piped, 99.5 Jetta Rocket PD150 6spd 4motion, 2000 ASV110 RC6 "Silverbullet" 5spd Race Car, 2003.5 Cummins QCLB 4x4 "Blue Monster" Jeep CRD juiced, MB Sprinter van juiced up
I will be glad to come get it. I will be up north next weekend in your neck of the woods. I can PayPal you or send check or bring cash.
Thx
Jeff ;-))
Cha2ga
Easley, SC
'11 JSW
Lots of good info in this thread. I especially like the info on silicon hoses for vacuum and the viton for fuel.
