flan
I had my 02J trans apart a couple months ago for diff bearings and ever since then if I try to shift quickly into 5th I get a slight grind. Another new issue is if I'm on the highway for a while when slowing down in 5th and try to go to neutral sometimes it will get stuck in 5th. I have new fluid in there, it's full also. I tried adjusting the cables and lubed them with white lithium grease also. I'm not so sure I got the adjustment on the 5th gear selector fork 100% correct, I'd like to try and adjust that but have had no luck finding a procedure online to do that therefore any help is appreciated.
