I have an '02 Jetta Auto with 137,xxx miles. Yesterday driving home from work I got a MIL. I went to Autozone after work today and read the codes with their OBD-II scanner. It read the P0740 TCC Circuit Malfunction code twice.
I haven't noticed any problems with shifting or excessive reving. In researching on the forums, there doesn't seem to be a definite answer to what is required to "fix" this code. I reset the code and will see if it comes back. One note I picked up from searching threads is to check my rpms at 75 mph (should be less than 3k).
http://forums.tdiclub.com/showthread.php?t=168981&highlight=P0740
I have had some transmission problems with my car, most recently a cracked tranny cooler at 123k (Jan 07). The tranny was serviced (filter/fluid) following the replacement of the cooler.
So, is there something I need to fix or replace? Do I just monitor the shifting and rpms and wait to see if it happens again?
Thanks,
Steve
Thanks,
Steve
