Andyinchville1
Hi All,
I do a lot of courier driving and have even been to the corona virus capitol NYC recently.
While I take all safety precautions while outside the vehicle , I sometimes have to drive into and from corona hot spots.
Assuming good weather striping and windows up, how safe are we inside our cars ? I know the cabin air filter is not a HEPA filter but maybe because it is thick and pleated it is better than we think?
I thought about taking a home furnace HEPA filter from lowes and modding it as a pre filter to the stock cabin filter ....being that there are a lot of modders / tinkerers on here has anybody already done that ? If so, I'd be interested in hearing what you did and how you did it ... Also, would the added restriction some how mess up the motor by making it work harder to suck in air ?
I thought about putting a light coating of lube on the weather stripping to be sticky to catch small particles that may try to squeeze in but that would be (or could be messy) and I would have to make sure it didn't harm rubber or paint).
Admittedly, I did not wear a mask inside the car when inside NYC but thinking maybe I should have ?
FWIW - I am ordering a half face respirator (I figure better than surgical masks because I still feel air exiting in areas around the edges so I am assuming air out means air in during inhaling and since they may be better than N95 masks also due to potentially better sealing).
I am researching full face masks also in case the virus mutates and becomes even deadlier ... Goog luck all .... stay safe!
Andrew
Andrew
