[ QUOTE ]
Drivbiwire said:
[ QUOTE ]
ruking said:
So with a design life of 10,000 hrs that ranges from 500-560k.
[/ QUOTE ]
I have no doubt that the TDI is closer to a 25,000 hour engine with normal daily use based on what I am seeing with my TDI at 3,500+ hours. I realize that things will need to be replaced but also a 25,000 hour engine does not mean it goes 25,000 without maintenance. The block, head and pistons and rings will go the distance everything else is pretty much a wear item and will more than likely need to be replaced if not once several times.
FYI: My car with 163,381 miles has 3,540.9 hours since it drove off the lot. Lifetime avarage speed...46.141 miles per hour.
Last compression check shows 550psi on all four cylinders zero differential between them, new TDI's start off at 475psi and rise to 550 once broken in and remain there till who knows when.
Will my car make it to 300,000 miles you bet your A$$ it will. Will it make it to 600,000 miles at this rate? You bet your A$$ it will... /images/graemlins/laugh.gif
The best advice to keep a high mileage TDI going:
-Follow the book regarding all maintenance recomendations
-Use a 5w40 Group IV synthetic oil like Delvac 1 or Amsoil 10w40
-Don't baby the motor
-Don't beat the motor
-Best advice of all, Enjoy the view along the way with the TDI leading the way /images/graemlins/laugh.gif
DB
[/ QUOTE ]
For your sake and mine and also the TDI community in general, I hope that you are correct. It eludes me, at this writing where I read the 10,000 hr design life parameter or I would provide the link. Also, if your average speed is 46 mph, a 25,000 hr design life, again I do not know if your figure is the middle point of the bell shaped curve, the motor life is closer to 1.15 M miles. So in effect lasting EVEN longer is a additional surprise benefit. So I will be coming to YOU with 12 TB and water pump changes instead of the projected 6. /images/graemlins/grin.gif
