How many miles are you seeing between regenerations?
Diesl
Chicago
'78 Golf Diesel (long gone); 2012 Jetta Sportwagen TDI w/ DSG
I'd be interested in what other people are seeing for their TDIs.
My DPF seems to regenerate about every 180 miles. I'm doing 40 mile (one way) commutes, 2/3 of it highway, 1/3 city. The car has 48,000 miles on it. Ash load was normal at 40k miles.
sarahspins
TX
2014 JSW 6MT
240's fairly consistently.. I watch for them worth my PolarFIS. If I'm doing a lot of city driving (and a lot of idleing at lights) I'll see them sooner, more in the 180 range, and on my last road trip I had two in the 400+ range with 100% highway driving.
Most of my driving is highway - I live rural and my JSW really seems to love the lower speed limit driving out here. I get better mileage just making a trip into town (10 miles) than any other kind of driving.
30Bones
Cedar Rapids, Ia
2013 Touareg TDI
77k miles and all sorts of driving conditions and I've never noticed a regen yet. :shrug:
Sent from my iPad using Tapatalk
Face76
Long Island
12 JSW TDI
Have only noticed one since I had the dealer update my software...before that it was sometimes 70 miles between.
meerschm
Fairfax county VA
2009 Jetta wagon DSG 08/08 205k buyback 1/8/18; replaced with 2017 Golf Wagon 4mo 1.8l CXBB
It really is easy not to notice a DPF regeneration unless you look closely and using some form of OBD data monitoring.
my 2009 has over 150k miles on it, 159 ml ash, and I see active regenerations using my pf03 every 120 miles if I only drive to work and back. (ten miles, mixed surface and freeway, which may or may not be moving)
on a road trip this weekend, closer to 300 miles.
JSWTDI09
Las Vegas, Nevada
First, it varies a lot. The type of driving makes a big difference and it also matters how "complete" a regeneration is. I also monitor with a Polar FIS+. DPF regenerations (in my car) usually occur about every 150-200 miles when I am just doing city driving. On highway cruises (75-80 mph) regens can be as far as 500 miles apart. Also, I have noticed that when an active regeneration occurs when you are stuck in traffic, it is also a shorter regeneration. A "full" regen will lower calculated soot load to under 3gm (usually about 2.7), however when stuck in traffic a regen might stop sooner with a soot load of around 6 or 7gm. When this "partial" regen occurs, the next one will occur sooner. In my car regens always occur as soon as the calculated soot load hits 16.8g.
Have Fun!
Don
sarahspins
TX
2014 JSW 6MT
I haven't noticed this unless I've had to interrupt a regen - under a certain point they won't restart, then I end up having a higher soot load leftover and the next regen is sooner because of that.
My car also seems to do a kind of "longer" regen with a different code every 2-3 weeks (after 4-5 regular regens - that's just an estimate though, I don't really keep count). Instead of FF02 on the display I get FF20, and those not only take longer (a good 15-20 minutes vs the 5 for a regular regen) but they also run much much hotter. I'm also not mistaking the NOx regens (FF10) for a normal regen, since those only last a few seconds.
meerschm
Fairfax county VA
pretty sure that FF20 is the DeSOX process that cleans the NOX cat (sulfur)
always just after a FF02, and it can run 20 miles or so at speed.
no idea what exactly a FF40 code is, do you? I see it sometimes a start cycle or two after the FF20.
DubFamily
Swan Point, MD
2014 BMW 328D xDrive
~250 miles give or take. But I drive 125 miles a day round-trip for my commute; so I think it gets a lot more passive regen from the drive as well.
Diesl
Chicago
Thanks a lot to everybody for all the info!
For the longest time I assumed my car was getting away with mostly passive regens due to the extended highway driving; but at some point I realized that I was missing a lot of regenerations. The apparent 350-400 mile intervals were really 180-200 miles with an unobserved regen in between.
> Luke <
West Los Angeles
Golf 2011 TDi DSG
From my memory of the operating manual, the 'regenerations' are 650 > 750 miles. Which has been the case for my exact same driving every day.
sarahspins
TX
2014 JSW 6MT
I've never seen the FF20 happen immediately after FF02, it usually happens after a series of short FF10 and FF04 (same that leads up to a FF02).
I've also never seen FF40... but I don't always have my display on that "screen" while driving though, so it's possible I've just missed it.
BTW, I should add, that until I got my PolarFIS I wouldn't have assumed my car was doing as many regens as it really does - I have a 38 mile commute to work and a lot of them happen during that drive, with no indication or change in drivability that they're happening. I'd get caught in traffic maybe once a month, and that was the only time I'd ever notice (due to higher idle, and suggested shift points are at higher RPM's)... but now that I can not only see them happen, but see the miles since the last one, on average with the mileage I put on my car I typically go through 2 regens a week.
Palladin
Yorba Linda, CA
2011 TDI w DSG
Somebody else mentioned that it seemed like their TDI was always doing a regen when they were shutting it off, even after a longish drive cycle. That has been my experience as well and when the outside temps are 100° I'm not inclined to let it sit there running nor am I too happy about it doing an engine off regen in my garage. But if you re-start it to back it out the regen is interrupted and then you start all over again the next time out. I guess if I had ONE gripe it would be the whole regen process. Not a deal breaker mind you, just something you have to live with as best you can.
sarahspins
TX
2014 JSW 6MT
Agreed - there IMO should be a better indication, like a light on the dash when one is happening too, my husband's diesel truck tells him when it's doing a regen, and he was baffled that my car doesn't.
iamatt
Rosharon, Texas
2014 Jetta 6 Speed manual
Exactly. My car seemed like it was doing regen every time I shut it off. I'd park in garage with door closed and the fans would keep running and stink up the garage. DPF delete took care of that nonsense with less than 10K miles on the new car. Highly suggest the dpf remove also take care of so much other problems you will have sooner than later and also have a cooler running engine.
Palladin
Yorba Linda, CA
2011 TDI w DSG
In view of the current diesel emissions uproar I'd be more than a little hesitant to go ripping out anything associated with the emissions system, especially in a place like California. At least until this current mess is sorted out.
meerschm
Fairfax county VA
over the various years the engine computers are different (software is different anyway).
I never see an FF04., and like you, I have the polar FIS + (PF03), and notice way more activity than I did before.
a couple days ago, i noticed i was near a DPF regen, and decided to log the trip with the VCDS. more details than I usually notice. (have to drive, you know)
ATR
Baltimore
2011 Golf TDI 6MT
What parameters did you log?
meerschm
Fairfax county VA
see below I cut out a few boring rows, but after a single blank line the whole DPF regen is shown.
Engine Speed - (G28)
Coolant - Temperature (G62)
Temperature prior - Turbo Charger
Temperature prior - Particle Filter
Particle Filter - Different. Pressure
Particle Filter Offset - Different. Pressure
0xFF02=Done,STAMP,Requested - Regenerations
Mileage - Since last Regen
Particle Filter - Oil Ash Volume
Soot Load(g) - Calculated
Soot Load(g) - Measured
you can select all, copy and past to a notepad file and save as .csv, then open in a spreadsheet.
Code:
 Wednesday,7,October,2015,07:30:46:51928-VCID:3FA390536EB764C664-806A,VCDS Version: Release 15.7.1 (x64),Data version: 20150904,,,,,,,,,,,,,,,,,,,
03L 997 016 P,ADVMB,R4 2.0L EDC G000AG  8681,,,,,,,,,,,,,,,,,,,,,,,
,,G002,F0,G002,F3,G099,F1,G100,F1,G100,F2,G100,F3,G104,F0,G105,F1,G240,F2,G241,F0,G241,F1,G241,F2
Marker,TIME,Group 2 - Field 0,TIME,Group 2 - Field 3,TIME,Group 99 - Field 1,TIME,Group 100 - Field 1,TIME,Group 100 - Field 2,TIME,Group 100 - Field 3,TIME,Group 104 - Field 0,TIME,Group 105 - Field 1,TIME,Group 240 - Field 2,TIME,Group 241 - Field 0,TIME,Group 241 - Field 1,TIME,Group 241 - Field 2,
,STAMP,Engine Speed - (G28),STAMP,Coolant - Temperature (G62),STAMP,Temperature prior - Turbo Charger,STAMP,Temperature prior - Particle Filter,STAMP,Particle Filter - Different. Pressure,STAMP,Particle Filter Offset - Different. Pressure,STAMP,0xFF02=Done,STAMP,Requested - Regenerations,STAMP,Mileage - Since last Regen,STAMP,Particle Filter - Oil Ash Volume,STAMP,Soot Load(g) - Calculated,STAMP,Soot Load(g) - Measured,
,, /min,,°C,,°C,,°C,, mbar,, mbar,,,,,, km,, ml,,,,,
,32.72,1587,32.72,87.3,31.93,318,32.08,234,32.08,33,32.08,0,32.19,0xFF01,32.32,5,32.44,400,32.6,159,32.6,16.8,32.6,6.6,
,33.64,1610,33.64,87.3,32.85,354,32.98,234,32.98,41,32.98,0,33.12,0xFF01,33.24,5,33.37,400,33.49,159,33.49,16.8,33.49,6.6,
,34.54,1840,34.54,87.3,33.76,384,33.88,240,33.88,46,33.88,0,34.01,0xFF01,34.16,5,34.29,400,34.41,159,34.41,16.8,34.41,6.6,
,35.44,2070,35.44,87.3,34.68,408,34.8,240,34.8,54,34.8,0,34.93,0xFF01,35.05,5,35.2,400,35.31,159,35.31,16.8,35.31,6.6,
,36.36,1610,36.36,87.3,35.56,420,35.72,240,35.72,64,35.72,0,35.85,0xFF01,35.97,5,36.1,400,36.24,159,36.24,16.8,36.24,6.6,
,37.28,1472,37.28,87.3,36.49,414,36.61,240,36.61,51,36.61,0,36.76,0xFF01,36.88,5,37,400,37.13,159,37.13,16.8,37.13,6.6,
,38.17,1541,38.17,87.3,37.41,396,37.53,240,37.53,41,37.53,0,37.65,0xFF01,37.8,5,37.92,400,38.05,159,38.05,16.8,38.05,6.6,
,39.09,1587,39.09,88.2,38.32,384,38.44,240,38.44,36,38.44,0,38.56,0xFF01,38.69,5,38.84,400,38.97,159,38.97,16.8,38.97,6.6,
,40.01,1679,40.01,88.2,39.21,384,39.36,240,39.36,38,39.36,0,39.48,0xFF01,39.61,5,39.73,400,39.88,159,39.88,16.8,39.88,6.6,
,40.92,1748,40.92,88.2,40.14,390,40.26,240,40.26,41,40.26,0,40.4,0xFF01,40.53,5,40.65,400,40.77,159,40.77,16.8,40.77,6.6,
,41.81,1817,41.81,88.2,41.04,396,41.17,240,41.17,46,41.17,0,41.29,0xFF10,41.44,5,41.55,400,41.68,159,41.68,16.8,41.68,6.6,
,42.73,1955,42.73,88.2,41.96,402,42.09,240,42.09,51,42.09,0,42.21,0xFF10,42.34,5,42.48,400,42.6,159,42.6,16.8,42.6,6.6,
,43.65,2001,43.65,88.2,42.85,420,43,240,43,64,43,0,43.11,0xFF10,43.24,5,43.37,400,43.52,159,43.52,16.8,43.52,6.6,
,44.56,1587,44.56,88.2,43.77,474,43.9,240,43.9,64,43.9,0,44.04,0xFF01,44.16,5,44.29,400,44.41,159,44.41,16.8,44.41,6.6,
,45.46,1495,45.46,88.2,44.68,576,44.8,240,44.8,44,44.8,0,44.93,0xFF01,45.08,5,45.21,400,45.33,159,45.33,16.8,45.33,6.6,
,46.36,1541,46.36,88.2,45.6,528,45.72,240,45.72,38,45.72,0,45.85,0xFF10,45.97,5,46.11,400,46.24,159,46.24,16.8,46.24,6.6,
,47.28,1587,47.28,88.2,46.49,516,46.64,240,46.64,38,46.64,0,46.77,0xFF10,46.89,5,47.02,400,47.16,159,47.16,16.8,47.16,6.6,
,48.2,1610,48.2,88.2,47.41,510,47.53,240,47.53,41,47.53,0,47.67,0xFF10,47.8,5,47.92,400,48.05,159,48.05,16.8,48.05,6.6,
,49.09,1633,49.09,88.2,48.33,540,48.45,240,48.45,38,48.45,0,48.58,0xFF10,48.72,5,48.84,400,48.97,159,48.97,16.8,48.97,6.6,
,50.01,1564,50.01,88.2,49.23,594,49.36,240,49.36,33,49.36,0,49.48,0xFF10,49.61,5,49.76,400,49.89,159,49.89,16.8,49.89,6.6,
,50.92,1587,50.92,88.2,50.14,630,50.28,240,50.28,23,50.28,0,50.4,0xFF01,50.53,5,50.65,400,50.79,159,50.79,16.8,50.79,6.6,
,51.84,1564,51.84,88.2,51.04,528,51.17,240,51.17,26,51.17,0,51.32,0xFF01,51.45,5,51.57,400,51.7,159,51.7,16.8,51.7,6.6,
,52.73,1564,52.73,88.2,51.96,462,52.09,240,52.09,26,52.09,0,52.21,0xFF01,52.35,5,52.48,400,52.6,159,52.6,16.8,52.6,6.6,
,53.65,1564,53.65,88.2,52.88,420,53.01,240,53.01,28,53.01,0,53.13,0xFF01,53.26,5,53.4,400,53.52,159,53.52,16.8,53.52,6.6,
,54.57,1564,54.57,88.2,53.77,390,53.91,240,53.91,31,53.91,0,54.04,0xFF10,54.16,5,54.29,400,54.44,159,54.44,16.8,54.44,6.6,
,55.47,1564,55.47,88.2,54.69,384,54.82,240,54.82,36,54.82,0,54.96,0xFF10,55.08,5,55.21,400,55.33,159,55.33,16.8,55.33,6.6,
,56.38,1587,56.38,88.2,55.6,390,55.72,240,55.72,41,55.72,0,55.85,0xFF10,56,5,56.13,400,56.25,159,56.25,16.8,56.25,6.6,
,57.28,1587,57.28,88.2,56.52,414,56.64,240,56.64,41,56.64,0,56.76,0xFF10,56.89,5,57.03,400,57.15,159,57.15,16.8,57.15,6.6,
,58.2,1587,58.2,88.2,57.41,462,57.56,240,57.56,38,57.56,0,57.69,0xFF10,57.81,5,57.94,400,58.08,159,58.08,16.8,58.08,6.6,
,59.12,1564,59.12,88.2,58.32,504,58.45,240,58.45,36,58.45,0,58.59,0xFF10,58.71,5,58.84,400,58.97,159,58.97,16.8,58.97,6.6,
,60.01,1541,60.01,88.2,59.25,576,59.37,234,59.37,36,59.37,0,59.49,0xFF10,59.64,5,59.76,400,59.89,159,59.89,16.8,59.89,6.6,
,60.93,1541,60.93,88.2,60.15,624,60.27,234,60.27,36,60.27,0,60.4,0xFF10,60.52,5,60.68,400,60.81,159,60.81,16.8,60.81,6.6,
,61.84,1518,61.84,89.1,61.05,648,61.2,234,61.2,38,61.2,0,61.32,0xFF10,61.44,5,61.57,400,61.71,159,61.71,16.8,61.71,6.6,
,62.76,1541,62.76,89.1,61.96,666,62.09,234,62.09,41,62.09,0,62.24,0xFF10,62.37,5,62.49,400,62.61,159,62.61,16.8,62.61,6.6,
,63.64,1541,63.64,89.1,62.88,660,63,234,63,41,63,0,63.13,0xFF10,63.27,5,63.39,400,63.52,159,63.52,16.8,63.52,6.6,
,64.57,1564,64.57,89.1,63.8,654,63.92,234,63.92,44,63.92,0,64.05,0xFF10,64.17,5,64.32,400,64.44,159,64.44,16.8,64.44,6.6,
,65.49,1587,65.49,89.1,64.69,654,64.83,234,64.83,44,64.83,0,64.95,0xFF10,65.08,5,65.21,400,65.36,159,65.36,16.8,65.36,6.6,
,66.39,1633,66.39,89.1,65.61,648,65.74,240,65.74,46,65.74,0,65.88,0xFF10,66,5,66.12,400,66.25,159,66.25,16.8,66.25,6.6,
,67.29,1679,67.29,89.1,66.51,648,66.64,240,66.64,46,66.64,0,66.77,0xFF10,66.92,5,67.05,400,67.17,159,67.17,16.8,67.17,6.6,
,68.2,1702,68.2,89.1,67.44,642,67.56,240,67.56,49,67.56,0,67.69,0xFF01,67.81,5,67.95,400,68.07,159,68.07,16.8,68.07,6.6,
,69.12,1679,69.12,89.1,68.32,576,68.48,240,68.48,44,68.48,0,68.61,0xFF01,68.73,5,68.85,400,69,159,69,16.8,69,6.6,
,70.04,1656,70.04,89.1,69.24,498,69.37,240,69.37,31,69.37,0,69.51,0xFF01,69.64,5,69.76,400,69.89,159,69.89,16.8,69.89,6.6,
,371.82,1265,371.82,92.7,371.06,204,371.18,258,371.18,26,371.18,0,371.3,0xFF01,371.44,5,371.57,400,371.69,159,371.69,16.8,371.69,5.7,
,372.72,1380,372.72,92.7,371.96,186,372.09,258,372.09,26,372.09,0,372.21,0xFF01,372.34,5,372.47,400,372.6,159,372.6,16.8,372.6,5.7,
,373.64,1472,373.64,92.7,372.86,174,372.99,258,372.99,26,372.99,0,373.13,0xFF01,373.26,5,373.38,400,373.52,159,373.52,16.8,373.52,5.7,
,374.56,1449,374.56,92.7,373.77,162,373.91,258,373.91,31,373.91,0,374.05,0xFF01,374.18,5,374.3,400,374.42,159,374.42,16.8,374.42,5.7,
,375.46,1472,375.46,92.7,374.69,156,374.81,258,374.81,28,374.81,0,374.94,0xFF01,375.08,5,375.21,400,375.33,159,375.33,16.8,375.33,5.7,
,376.37,2047,376.37,92.7,375.61,150,375.73,258,375.73,36,375.73,0,375.86,0xFF01,375.99,5,376.12,400,376.25,159,376.25,16.8,376.25,5.7,
,377.28,2208,377.28,92.7,376.5,240,376.64,258,376.64,69,376.64,0,376.77,0xFF01,376.89,5,377.02,400,377.15,159,377.15,16.8,377.15,5.7,
,378.2,2415,378.2,92.7,377.41,396,377.54,258,377.54,118,377.54,0,377.67,0xFF01,377.81,5,377.94,400,378.06,159,378.06,16.8,378.06,5.7,
,379.1,2576,379.1,92.7,378.32,528,378.45,264,378.45,144,378.45,0,378.59,0xFF01,378.73,5,378.86,400,378.98,159,378.98,16.8,378.98,5.7,
,380.01,2323,380.01,92.7,379.24,594,379.37,270,379.37,156,379.37,0,379.5,0xFF02,379.62,5,379.76,400,379.88,159,379.88,16.8,379.88,5.7,
,380.92,2116,380.92,91.8,380.14,624,380.27,270,380.27,144,380.27,0,380.4,0xFF02,380.52,5,380.66,400,380.79,159,380.79,16.8,380.79,5.7,
,381.85,2162,381.85,91.8,381.03,624,381.17,270,381.17,121,381.17,0,381.32,0xFF02,381.45,5,381.57,400,381.71,159,381.71,16.8,381.71,5.7,
,382.74,1909,382.74,91.8,381.97,648,382.1,276,382.1,110,382.1,0,382.22,0xFF02,382.36,5,382.49,400,382.62,159,382.62,16.8,382.62,5.7,
,383.66,1886,383.66,91.8,382.88,630,383,276,383,69,383,0,383.13,0xFF02,383.26,5,383.41,400,383.54,159,383.54,16.8,383.54,6,
,384.57,1863,384.57,91.8,383.79,624,383.92,276,383.92,64,383.92,0,384.05,0xFF02,384.17,5,384.3,400,384.44,159,384.44,16.8,384.44,6,
,385.47,1863,385.47,91.8,384.69,642,384.82,276,384.82,72,384.82,0,384.95,0xFF02,385.08,5,385.2,400,385.34,159,385.34,16.8,385.34,6,
,386.39,1886,386.39,91.8,385.61,666,385.73,276,385.73,67,385.73,0,385.86,0xFF02,386,5,386.12,400,386.25,159,386.25,16.8,386.25,6,
,387.3,1886,387.3,91.8,386.53,654,386.66,276,386.66,51,386.66,0,386.78,0xFF02,386.9,5,387.04,400,387.17,159,387.17,16.8,387.17,6,
,388.2,1886,388.2,91.8,387.42,654,387.56,276,387.56,51,387.56,0,387.68,0xFF02,387.81,5,387.94,400,388.07,159,388.07,16.8,388.07,6,
,389.12,1909,389.12,91.8,388.33,660,388.46,276,388.46,64,388.46,0,388.59,0xFF02,388.71,5,388.83,400,388.97,159,388.97,16.8,388.97,6,
,390.02,1909,390.02,91.8,389.25,672,389.37,276,389.37,77,389.37,0,389.5,0xFF02,389.64,5,389.76,400,389.88,159,389.88,16.8,389.88,6,
,390.92,1932,390.92,91.8,390.15,666,390.28,276,390.28,72,390.28,0,390.4,0xFF02,390.54,5,390.68,400,390.8,159,390.8,16.8,390.8,6,
,391.83,1955,391.83,91.8,391.05,660,391.2,276,391.2,64,391.2,0,391.32,0xFF02,391.44,5,391.58,400,391.71,159,391.71,16.8,391.71,6,
,392.75,1955,392.75,91.8,391.95,660,392.09,276,392.09,77,392.09,0,392.24,0xFF02,392.37,5,392.49,400,392.62,159,392.62,16.8,392.62,6,
,393.65,1978,393.65,91.8,392.88,678,393.01,276,393.01,82,393.01,0,393.14,0xFF02,393.27,5,393.4,400,393.52,159,393.52,16.8,393.52,6,
,394.57,1955,394.57,91.8,393.78,648,393.92,282,393.92,56,393.92,0,394.03,0xFF02,394.17,5,394.3,400,394.44,159,394.44,16.8,394.44,6,
,395.49,1909,395.49,91.8,394.7,606,394.83,282,394.83,41,394.83,0,394.95,0xFF02,395.08,5,395.22,400,395.36,159,395.36,16.8,395.36,6,
,396.39,1886,396.39,91.8,395.61,534,395.73,282,395.73,31,395.73,0,395.87,0xFF02,396,5,396.13,400,396.26,159,396.26,16.8,396.26,6,
,397.3,1863,397.3,92.7,396.52,468,396.64,276,396.64,28,396.64,0,396.77,0xFF02,396.92,5,397.04,400,397.17,159,397.17,16.8,397.17,6,
,398.19,1909,398.19,92.7,397.44,414,397.56,276,397.56,26,397.56,0,397.69,0xFF02,397.82,5,397.95,400,398.07,159,398.07,16.8,398.07,6,
,399.12,1863,399.12,92.7,398.34,384,398.48,276,398.48,33,398.48,0,398.61,0xFF02,398.73,5,398.85,400,398.99,159,398.99,16.8,398.99,6,
,400.02,1863,400.02,92.7,399.24,396,399.38,276,399.38,46,399.38,0,399.51,0xFF02,399.64,5,399.75,400,399.89,159,399.89,16.8,399.89,6,
,400.94,1863,400.94,92.7,400.16,486,400.27,276,400.27,54,400.27,0,400.41,0xFF02,400.54,5,400.68,400,400.8,159,400.8,16.8,400.8,6,
,401.85,1863,401.85,92.7,401.07,552,401.19,276,401.19,54,401.19,0,401.32,0xFF02,401.46,5,401.6,400,401.73,159,401.73,16.8,401.73,6,
,402.75,1886,402.75,92.7,401.97,606,402.12,282,402.12,59,402.12,0,402.24,0xFF01,402.37,5,402.5,400,402.63,159,402.63,16.8,402.63,6,
,403.68,1863,403.68,93.6,402.87,606,403.01,282,403.01,67,403.01,0,403.16,0xFF10,403.29,5,403.41,400,403.54,159,403.54,16.8,403.54,6,
,404.58,1863,404.58,93.6,403.8,564,403.92,282,403.92,54,403.92,0,404.06,0xFF10,404.19,5,404.32,400,404.44,159,404.44,16.8,404.44,6,
,405.49,1886,405.49,93.6,404.72,564,404.84,282,404.84,49,404.84,0,404.97,0xFF10,405.09,5,405.24,400,405.36,159,405.36,16.8,405.36,6,
,406.41,1886,406.41,93.6,405.62,600,405.75,282,405.75,46,405.75,0,405.87,0xFF10,405.99,5,406.14,400,406.28,159,406.28,16.8,406.28,6,
,407.31,1886,407.31,93.6,406.53,648,406.65,282,406.65,49,406.65,0,406.79,0xFF10,406.92,5,407.04,400,407.18,159,407.18,16.8,407.18,6,
,408.21,1886,408.21,93.6,407.44,678,407.56,282,407.56,46,407.56,0,407.69,0xFF10,407.82,5,407.96,400,408.08,159,408.08,16.8,408.08,6,
,409.12,1886,409.12,93.6,408.34,696,408.47,288,408.47,46,408.47,0,408.6,0xFF10,408.74,5,408.87,400,409,159,409,16.8,409,6,
,410.04,1886,410.04,93.6,409.26,708,409.4,288,409.4,38,409.4,0,409.52,0xFF10,409.65,5,409.77,400,409.92,159,409.92,16.8,409.92,6,
,410.96,1886,410.96,93.6,410.17,732,410.3,288,410.3,36,410.3,0,410.43,0xFF10,410.55,5,410.67,400,410.81,159,410.81,16.8,410.81,6,
,411.86,1886,411.86,93.6,411.09,750,411.21,288,411.21,36,411.21,0,411.33,0xFF10,411.47,5,411.6,400,411.72,159,411.72,16.8,411.72,6,
,412.77,1886,412.77,93.6,411.99,750,412.12,288,412.12,49,412.12,0,412.24,0xFF10,412.37,5,412.5,400,412.65,159,412.65,16.8,412.65,6,
,413.69,1909,413.69,93.6,412.91,738,413.05,288,413.05,54,413.05,0,413.18,0xFF01,413.3,5,413.43,400,413.56,159,413.56,16.8,413.56,6,
,414.59,1909,414.59,93.6,413.82,720,413.95,288,413.95,67,413.95,0,414.08,0xFF02,414.21,5,414.33,400,414.46,159,414.46,16.8,414.46,5.7,
,415.49,1932,415.49,93.6,414.73,666,414.85,294,414.85,85,414.85,0,414.98,0xFF02,415.11,5,415.24,400,415.35,159,415.35,16.8,415.35,5.7,
,416.38,1932,416.38,93.6,415.62,624,415.76,294,415.76,92,415.76,0,415.88,0xFF02,416,5,416.14,400,416.27,159,416.27,16.8,416.27,6,
,417.29,1932,417.29,94.5,416.51,624,416.65,300,416.65,74,416.65,0,416.78,0xFF02,416.9,5,417.04,400,417.16,159,417.16,16.8,417.16,6,
,418.19,1932,418.19,94.5,417.41,624,417.54,300,417.54,62,417.54,0,417.69,0xFF02,417.82,5,417.93,400,418.06,159,418.06,16.8,418.06,6,
,419.08,1932,419.08,94.5,418.32,642,418.44,306,418.44,69,418.44,0,418.57,0xFF02,418.72,5,418.84,400,418.96,159,418.96,16.8,418.96,6,
,419.99,1932,419.99,94.5,419.22,678,419.35,306,419.35,82,419.35,0,419.47,0xFF02,419.6,5,419.74,400,419.87,159,419.87,16.8,419.87,6,
,420.9,1932,420.9,94.5,420.12,684,420.25,306,420.25,82,420.25,0,420.38,0xFF02,420.5,5,420.63,400,420.78,159,420.78,16.8,420.78,6,
,421.8,1932,421.8,94.5,421.02,666,421.14,312,421.14,69,421.14,0,421.28,0xFF02,421.41,5,421.53,400,421.66,159,421.66,16.8,421.66,6,
,422.69,1932,422.69,94.5,421.93,654,422.05,312,422.05,64,422.05,0,422.17,0xFF02,422.31,5,422.44,400,422.57,159,422.57,16.8,422.57,6,
,423.6,1932,423.6,94.5,422.83,648,422.95,312,422.95,74,422.95,0,423.08,0xFF02,423.2,5,423.34,400,423.47,159,423.47,17.1,423.47,6,
,424.5,1955,424.5,94.5,423.72,666,423.86,318,423.86,85,423.86,0,423.98,0xFF02,424.11,5,424.23,400,424.37,159,424.37,17.1,424.37,6,
,425.41,1955,425.41,94.5,424.63,666,424.75,318,424.75,90,424.75,0,424.89,0xFF02,425.01,5,425.14,410,425.26,159,425.26,17.1,425.26,6,
,426.29,1955,426.29,94.5,425.53,666,425.66,324,425.66,92,425.66,0,425.78,0xFF02,425.92,5,426.04,410,426.17,159,426.17,17.1,426.17,6,
,427.21,1978,427.21,95.4,426.45,660,426.58,324,426.58,77,426.58,0,426.7,0xFF02,426.82,5,426.96,410,427.09,159,427.09,17.1,427.09,6,
,428.12,1978,428.12,95.4,427.34,648,427.48,330,427.48,72,427.48,0,427.61,0xFF02,427.73,5,427.85,410,428,159,428,17.1,428,6,
,429.03,1978,429.03,95.4,428.24,654,428.37,330,428.37,87,428.37,0,428.52,0xFF02,428.64,5,428.77,410,428.88,159,428.88,17.1,428.88,6,
,429.94,1978,429.94,95.4,429.15,672,429.28,330,429.28,92,429.28,0,429.42,0xFF02,429.57,5,429.7,410,429.82,159,429.82,17.1,429.82,6,
,430.85,2001,430.85,95.4,430.08,672,430.21,336,430.21,95,430.21,0,430.33,0xFF02,430.46,5,430.6,410,430.73,159,430.73,17.1,430.73,6,
,431.76,2001,431.76,95.4,430.97,666,431.12,342,431.12,97,431.12,0,431.24,0xFF02,431.36,5,431.49,410,431.64,159,431.64,17.1,431.64,6,
,432.69,2001,432.69,95.4,431.89,666,432,342,432,90,432,0,432.15,0xFF02,432.26,5,432.4,410,432.54,159,432.54,17.1,432.54,6,
,433.58,2001,433.58,95.4,432.82,642,432.94,348,432.94,72,432.94,0,433.06,0xFF02,433.2,5,433.33,410,433.45,159,433.45,17.1,433.45,6,
,434.48,2001,434.48,95.4,433.72,630,433.85,348,433.85,72,433.85,0,433.97,0xFF02,434.09,5,434.24,410,434.36,159,434.36,17.1,434.36,6,
,435.38,2001,435.38,95.4,434.61,642,434.76,348,434.76,87,434.76,0,434.88,0xFF02,435.01,5,435.12,410,435.27,159,435.27,17.1,435.27,6,
,436.32,1978,436.32,95.4,435.52,672,435.66,354,435.66,92,435.66,0,435.81,0xFF02,435.94,5,436.06,410,436.18,159,436.18,17.1,436.18,6,
,437.21,1955,437.21,96.3,436.45,648,436.58,354,436.58,69,436.58,0,436.7,0xFF02,436.84,5,436.97,410,437.09,159,437.09,17.1,437.09,6,
,438.13,1932,438.13,96.3,437.36,606,437.48,354,437.48,54,437.48,0,437.6,0xFF02,437.73,5,437.88,410,438.01,159,438.01,17.1,438.01,6,
,439.06,1909,439.06,96.3,438.26,588,438.4,354,438.4,51,438.4,0,438.52,0xFF02,438.65,5,438.77,410,438.93,159,438.93,17.1,438.93,6,
,439.96,1886,439.96,96.3,439.18,588,439.3,354,439.3,56,439.3,0,439.44,0xFF02,439.57,5,439.69,410,439.82,159,439.82,17.1,439.82,5.7,
,440.85,1863,440.85,96.3,440.08,600,440.21,354,440.21,54,440.21,0,440.33,0xFF02,440.48,5,440.6,410,440.73,159,440.73,17.1,440.73,5.7,
,441.77,1840,441.77,96.3,441,612,441.11,360,441.11,54,441.11,0,441.25,0xFF02,441.36,5,441.51,410,441.63,159,441.63,17.1,441.63,5.7,
,442.69,1817,442.69,96.3,441.9,618,442.05,360,442.05,49,442.05,0,442.17,0xFF02,442.3,5,442.42,410,442.56,159,442.56,17.1,442.56,5.7,
,443.6,1771,443.6,96.3,442.82,582,442.94,360,442.94,36,442.94,0,443.08,0xFF02,443.2,5,443.33,410,443.45,159,443.45,17.1,443.45,5.7,
,444.48,1748,444.48,96.3,443.72,516,443.85,360,443.85,31,443.85,0,443.96,0xFF02,444.12,5,444.23,410,444.37,159,444.37,17.1,444.37,5.7,
,445.4,1748,445.4,96.3,444.64,456,444.77,354,444.77,31,444.77,0,444.89,0xFF02,445.01,5,445.16,410,445.28,159,445.28,17.1,445.28,5.7,
,446.31,1725,446.31,96.3,445.53,450,445.68,354,445.68,46,445.68,0,445.8,0xFF02,445.93,5,446.04,410,446.19,159,446.19,17.1,446.19,5.7,
,447.24,1725,447.24,96.3,446.44,528,446.57,360,446.57,59,446.57,0,446.72,0xFF02,446.86,5,446.98,410,447.1,159,447.1,17.1,447.1,5.7,
,448.13,1702,448.13,96.3,447.37,642,447.49,360,447.49,56,447.49,0,447.62,0xFF02,447.76,5,447.88,410,448.01,159,448.01,17.1,448.01,5.7,
,449.05,1679,449.05,96.3,448.28,660,448.4,360,448.4,41,448.4,0,448.52,0xFF02,448.65,5,448.8,410,448.92,159,448.92,17.1,448.92,5.7,
,449.97,1633,449.97,96.3,449.16,606,449.31,360,449.31,33,449.31,0,449.42,0xFF02,449.56,5,449.7,410,449.85,159,449.85,17.1,449.85,5.7,
,450.88,1610,450.88,96.3,450.1,564,450.22,360,450.22,31,450.22,0,450.36,0xFF02,450.49,5,450.62,410,450.74,159,450.74,17.1,450.74,5.7,
,451.77,1610,451.77,96.3,451,528,451.13,360,451.13,28,451.13,0,451.25,0xFF02,451.4,5,451.52,410,451.65,159,451.65,17.1,451.65,5.7,
,452.69,1610,452.69,96.3,451.92,504,452.03,360,452.03,28,452.03,0,452.15,0xFF02,452.28,5,452.43,410,452.57,159,452.57,17.1,452.57,5.4,
,453.59,1610,453.59,96.3,452.81,498,452.95,360,452.95,41,452.95,0,453.08,0xFF02,453.2,5,453.33,410,453.48,159,453.48,17.1,453.48,5.4,
,454.51,1587,454.51,96.3,453.72,528,453.84,360,453.84,54,453.84,0,453.99,0xFF02,454.1,5,454.24,410,454.37,159,454.37,17.1,454.37,5.4,
,455.41,1564,455.41,96.3,454.64,618,454.77,366,454.77,44,454.77,0,454.89,0xFF02,455.04,5,455.15,410,455.28,159,455.28,17.1,455.28,5.4,
,456.32,1564,456.32,96.3,455.55,594,455.68,366,455.68,33,455.68,0,455.81,0xFF02,455.93,5,456.07,410,456.2,159,456.2,17.1,456.2,5.4,
,457.24,1564,457.24,96.3,456.45,564,456.6,366,456.6,36,456.6,0,456.72,0xFF02,456.84,5,456.96,410,457.11,159,457.11,17.1,457.11,5.4,
,458.16,1541,458.16,96.3,457.37,570,457.5,366,457.5,46,457.5,0,457.64,0xFF02,457.76,5,457.88,410,458.01,159,458.01,17.1,458.01,5.4,
,459.05,1518,459.05,96.3,458.27,618,458.4,366,458.4,41,458.4,0,458.52,0xFF02,458.68,5,458.81,410,458.93,159,458.93,17.1,458.93,5.4,
,459.95,1518,459.95,96.3,459.19,594,459.32,366,459.32,36,459.32,0,459.44,0xFF02,459.57,5,459.72,410,459.84,159,459.84,17.1,459.84,5.4,
,460.88,1495,460.88,96.3,460.08,582,460.23,372,460.23,33,460.23,0,460.35,0xFF02,460.48,5,460.61,410,460.76,159,460.76,17.1,460.76,5.4,
,461.79,1495,461.79,96.3,461,582,461.12,372,461.12,33,461.12,0,461.28,0xFF02,461.39,5,461.52,410,461.64,159,461.64,17.1,461.64,5.4,
,462.68,1495,462.68,96.3,461.9,582,462.04,372,462.04,41,462.04,0,462.17,0xFF02,462.31,5,462.44,410,462.56,159,462.56,17.1,462.56,5.1,
,463.61,1518,463.61,96.3,462.84,612,462.95,372,462.95,51,462.95,0,463.08,0xFF02,463.2,5,463.35,410,463.48,159,463.48,17.1,463.48,5.1,
,464.52,1541,464.52,96.3,463.73,660,463.87,372,463.87,64,463.87,0,464,0xFF02,464.12,5,464.25,410,464.4,159,464.4,17.1,464.4,5.1,
,465.44,1564,465.44,96.3,464.63,684,464.76,378,464.76,69,464.76,0,464.91,0xFF02,465.04,5,465.17,410,465.3,159,465.3,17.1,465.3,5.1,
,466.33,1587,466.33,96.3,465.56,684,465.68,378,465.68,74,465.68,0,465.8,0xFF02,465.96,5,466.07,410,466.2,159,466.2,17.1,466.2,5.1,
,467.25,1587,467.25,96.3,466.48,684,466.6,384,466.6,74,466.6,0,466.73,0xFF02,466.85,5,466.99,410,467.12,159,467.12,17.1,467.12,5.1,
,468.16,1587,468.16,97.2,467.37,672,467.52,384,467.52,67,467.52,0,467.63,0xFF02,467.76,5,467.88,410,468.03,159,468.03,17.1,468.03,5.1,
,469.08,1587,469.08,96.3,468.29,648,468.41,384,468.41,54,468.41,0,468.55,0xFF02,468.68,5,468.8,410,468.92,159,468.92,17.1,468.92,5.1,
,469.97,1564,469.97,96.3,469.19,642,469.31,390,469.31,54,469.32,0,469.44,0xFF02,469.59,5,469.7,410,469.84,159,469.84,17.1,469.84,5.1,
,470.88,1587,470.88,96.3,470.11,642,470.24,390,470.24,56,470.24,0,470.36,0xFF02,470.48,5,470.64,410,470.75,159,470.75,17.1,470.75,5.1,
,471.8,1587,471.8,96.3,471.01,648,471.15,390,471.15,64,471.15,0,471.28,0xFF02,471.41,5,471.53,410,471.67,159,471.67,17.1,471.67,5.1,
,472.71,1610,472.71,96.3,471.93,660,472.05,390,472.05,72,472.05,0,472.2,0xFF02,472.31,5,472.44,410,472.56,159,472.56,17.1,472.56,5.1,
,473.6,1633,473.6,96.3,472.84,666,472.97,390,472.97,79,472.97,0,473.1,0xFF02,473.24,5,473.36,410,473.48,159,473.48,17.1,473.48,5.1,
,474.52,1656,474.52,96.3,473.76,678,473.88,390,473.88,82,473.88,0,474,0xFF02,474.13,5,474.27,410,474.38,159,474.38,17.1,474.38,5.1,
,475.45,1679,475.45,96.3,474.65,666,474.79,396,474.79,85,474.79,0,474.92,0xFF02,475.04,5,475.17,410,475.32,159,475.32,17.1,475.32,5.1,
,476.36,1748,476.36,96.3,475.57,666,475.7,396,475.7,97,475.7,0,475.84,0xFF02,475.96,5,476.09,410,476.21,159,476.21,17.1,476.21,4.8,
,477.24,1771,477.24,96.3,476.48,696,476.6,402,476.6,110,476.6,0,476.73,0xFF02,476.88,5,476.99,410,477.12,159,477.12,17.1,477.12,4.8,
,478.16,1771,478.16,96.3,477.39,696,477.5,402,477.5,105,477.5,0,477.64,0xFF02,477.77,5,477.91,410,478.03,159,478.03,17.1,478.03,5.1,
,479.08,1771,479.08,96.3,478.28,666,478.44,408,478.44,85,478.44,0,478.55,0xFF02,478.68,5,478.8,410,478.95,159,478.95,17.1,478.95,5.1,
,480,1771,480,96.3,479.21,630,479.33,408,479.33,67,479.33,0,479.47,0xFF02,479.6,5,479.72,410,479.84,159,479.84,17.1,479.84,4.8,
,480.9,1748,480.9,97.2,480.12,618,480.24,408,480.24,62,480.24,0,480.37,0xFF02,480.51,5,480.62,410,480.76,159,480.76,17.1,480.76,4.8,
,481.8,1748,481.8,97.2,481.04,618,481.16,408,481.16,59,481.16,0,481.28,0xFF02,481.41,5,481.56,410,481.67,159,481.67,17.1,481.67,4.8,
,482.72,1748,482.72,97.2,481.93,618,482.08,402,482.08,64,482.08,0,482.2,0xFF02,482.33,5,482.45,410,482.59,159,482.59,17.1,482.59,4.8,
,483.63,1748,483.63,97.2,482.85,624,482.97,408,482.97,77,482.97,0,483.11,0xFF02,483.23,5,483.36,410,483.48,159,483.48,17.1,483.48,4.8,
,484.51,1725,484.51,97.2,483.74,648,483.87,408,483.87,79,483.87,0,484,0xFF02,484.15,5,484.26,410,484.4,159,484.4,17.1,484.4,4.8,
,485.43,1725,485.43,97.2,484.66,636,484.79,408,484.79,64,484.79,0,484.91,0xFF02,485.04,5,485.19,410,485.3,159,485.3,17.1,485.3,4.8,
,486.34,1702,486.34,97.2,485.56,630,485.71,408,485.71,59,485.71,0,485.83,0xFF02,485.96,5,486.07,410,486.22,159,486.22,17.1,486.22,4.8,
,487.27,1702,487.27,98.1,486.47,630,486.6,408,486.6,56,486.6,0,486.75,0xFF02,486.88,5,487.01,410,487.14,159,487.14,17.1,487.14,4.8,
,488.16,1702,488.16,98.1,487.4,630,487.52,408,487.52,67,487.52,0,487.65,0xFF02,487.79,5,487.92,410,488.03,159,488.03,17.1,488.03,4.8,
,489.08,1702,489.08,98.1,488.31,648,488.42,408,488.42,74,488.42,0,488.55,0xFF02,488.68,5,488.83,410,488.95,159,488.95,17.1,488.95,4.8,
,490.01,1702,490.01,98.1,489.19,654,489.34,408,489.34,74,489.34,0,489.45,0xFF02,489.59,5,489.73,410,489.88,159,489.88,17.1,489.88,4.8,
,490.91,1702,490.91,98.1,490.13,648,490.25,408,490.25,69,490.25,0,490.39,0xFF02,490.52,5,490.64,410,490.77,159,490.77,17.1,490.77,4.8,
,491.8,1702,491.8,98.1,491.03,642,491.16,408,491.16,62,491.16,0,491.28,0xFF02,491.43,5,491.54,410,491.67,159,491.67,17.1,491.67,4.8,
,492.72,1702,492.72,98.1,491.95,642,492.06,408,492.06,59,492.06,0,492.19,0xFF02,492.31,5,492.46,410,492.59,159,492.59,17.1,492.59,4.8,
,493.64,1702,493.64,98.1,492.84,642,492.99,408,492.99,59,492.99,0,493.12,0xFF02,493.25,5,493.37,410,493.51,159,493.51,17.1,493.51,4.8,
,494.55,1702,494.55,98.1,493.76,642,493.89,408,493.89,59,493.89,0,494.02,0xFF02,494.15,5,494.28,410,494.4,159,494.4,17.1,494.4,4.5,
,495.45,1725,495.45,98.1,494.68,642,494.81,408,494.81,59,494.81,0,494.93,0xFF02,495.07,5,495.2,410,495.32,159,495.32,17.1,495.32,4.5,
,496.37,1725,496.37,99,495.59,642,495.72,408,495.72,69,495.72,0,495.83,0xFF02,495.96,5,496.11,410,496.24,159,496.24,17.1,496.24,4.5,
,497.27,1748,497.27,99,496.5,648,496.64,408,496.64,74,496.64,0,496.76,0xFF02,496.88,5,497,410,497.15,159,497.15,17.1,497.15,4.5,
,498.19,1748,498.19,99,497.4,654,497.53,408,497.53,74,497.53,0,497.68,0xFF02,497.8,5,497.93,410,498.05,159,498.05,17.1,498.05,4.5,
,499.08,1771,499.08,99,498.32,648,498.44,408,498.44,67,498.44,0,498.56,0xFF02,498.71,5,498.83,410,498.95,159,498.95,17.1,498.95,4.5,
,500,1771,500,99,499.23,642,499.34,408,499.34,59,499.34,0,499.47,0xFF02,499.59,5,499.75,410,499.86,159,499.86,17.1,499.86,4.5,
,500.92,1771,500.92,99,500.11,642,500.26,408,500.26,54,500.26,0,500.39,0xFF02,500.51,5,500.64,410,500.79,159,500.79,17.1,500.79,4.5,
,501.83,1748,501.83,99,501.05,636,501.17,408,501.17,54,501.17,0,501.31,0xFF02,501.44,5,501.56,410,501.68,159,501.68,17.1,501.68,4.5,
,502.73,1771,502.73,99,501.95,642,502.08,408,502.08,54,502.08,0,502.21,0xFF02,502.35,5,502.48,410,502.61,159,502.61,17.1,502.61,4.5,
,503.63,1771,503.63,99,502.87,642,503,408,503,59,503,0,503.12,0xFF02,503.25,5,503.39,410,503.51,159,503.51,17.1,503.51,4.5,
,504.54,1771,504.54,99,503.76,648,503.91,408,503.91,59,503.91,0,504.02,0xFF02,504.15,5,504.28,410,504.43,159,504.43,17.1,504.43,4.5,
,505.47,1771,505.47,99,504.68,648,504.79,408,504.79,62,504.79,0,504.94,0xFF02,505.07,5,505.2,410,505.32,159,505.32,17.1,505.32,4.5,
,506.35,1771,506.35,99,505.58,648,505.71,408,505.71,62,505.71,0,505.83,0xFF02,505.99,5,506.1,410,506.23,159,506.23,17.1,506.23,4.5,
,507.29,1771,507.29,99,506.5,648,506.63,408,506.63,62,506.63,0,506.75,0xFF02,506.88,5,507.03,410,507.16,159,507.16,17.1,507.16,4.5,
,508.19,1771,508.19,99,507.41,648,507.55,408,507.55,62,507.55,0,507.68,0xFF02,507.8,5,507.93,410,508.07,159,508.07,17.1,508.07,4.2,
,509.11,1771,509.11,99,508.31,648,508.44,408,508.44,62,508.44,0,508.59,0xFF02,508.72,5,508.85,410,508.97,159,508.97,17.1,508.97,4.2,
,510,1771,510,99,509.24,648,509.36,414,509.36,64,509.36,0,509.49,0xFF02,509.63,5,509.75,410,509.88,159,509.88,17.1,509.88,4.2,
,510.92,1794,510.92,99,510.15,648,510.28,414,510.28,64,510.28,0,510.41,0xFF02,510.53,5,510.67,410,510.8,159,510.8,17.1,510.8,4.2,
,511.82,1794,511.82,99,511.05,648,511.19,414,511.19,64,511.19,0,511.31,0xFF02,511.44,5,511.56,410,511.71,159,511.71,17.1,511.71,4.2,
,512.74,1794,512.74,99,511.95,648,512.08,414,512.08,64,512.08,0,512.23,0xFF02,512.34,5,512.48,410,512.59,159,512.59,17.1,512.59,4.2,
,513.63,1794,513.63,99,512.87,648,512.99,414,512.99,67,512.99,0,513.12,0xFF02,513.27,5,513.39,410,513.51,159,513.51,17.1,513.51,4.2,
,514.55,1771,514.55,99,513.79,648,513.9,414,513.9,64,513.9,0,514.02,0xFF02,514.15,5,514.3,410,514.44,159,514.44,17.1,514.44,4.2,
,515.46,1748,515.46,99,514.68,618,514.82,414,514.82,44,514.82,0,514.94,0xFF02,515.07,5,515.19,410,515.35,159,515.35,17.1,515.35,4.2,
,516.38,1725,516.38,99,515.59,546,515.71,414,515.71,36,515.71,0,515.86,0xFF02,515.99,5,516.11,410,516.24,159,516.24,17.1,516.24,4.2,
,517.27,1725,517.27,99,516.5,474,516.63,414,516.63,33,516.63,0,516.75,0xFF02,516.91,5,517.02,410,517.14,159,517.14,17.1,517.14,4.2,
,518.19,1748,518.19,99,517.42,468,517.55,408,517.55,44,517.55,0,517.68,0xFF02,517.8,5,517.94,410,518.06,159,518.06,17.1,518.06,4.2,
,519.11,1725,519.11,99,518.32,498,518.47,408,518.47,54,518.47,0,518.58,0xFF02,518.7,5,518.83,410,518.98,159,518.98,17.1,518.98,4.2,
,520.03,1725,520.03,99,519.24,612,519.36,414,519.36,59,519.36,0,519.5,0xFF02,519.62,5,519.75,410,519.88,159,519.88,17.1,519.88,4.2,
,520.92,1725,520.92,99,520.14,684,520.27,414,520.27,59,520.27,0,520.39,0xFF02,520.54,5,520.67,410,520.79,159,520.79,17.1,520.79,4.2,
,521.83,1748,521.83,99,521.06,684,521.19,414,521.19,59,521.19,0,521.31,0xFF02,521.44,5,521.59,410,521.7,159,521.7,17.1,521.7,4.2,
,522.74,1748,522.74,99,521.95,660,522.1,414,522.1,59,522.1,0,522.23,0xFF02,522.35,5,522.48,410,522.62,159,522.62,17.1,522.62,4.2,
,523.66,1725,523.66,99,522.87,648,522.99,414,522.99,59,522.99,0,523.15,0xFF02,523.26,5,523.38,410,523.51,159,523.51,17.1,523.51,4.2,
,524.55,1702,524.55,99,523.79,624,523.91,414,523.91,49,523.91,0,524.04,0xFF02,524.18,5,524.3,410,524.43,159,524.43,17.1,524.43,4.2,
,525.48,1679,525.48,99,524.71,582,524.82,414,524.82,38,524.82,0,524.94,0xFF02,525.07,5,525.22,410,525.35,159,525.35,17.1,525.35,4.2,
,526.38,1679,526.38,99,525.6,516,525.74,414,525.74,31,525.74,0,525.86,0xFF02,525.99,5,526.12,410,526.27,159,526.27,17.1,526.27,3.9,
,527.3,1679,527.3,99,526.51,462,526.63,414,526.63,36,526.63,0,526.78,0xFF02,526.89,5,527.03,410,527.16,159,527.16,17.1,527.16,3.9,
,528.18,1679,528.18,99,527.43,462,527.55,414,527.55,49,527.55,0,527.66,0xFF02,527.8,5,527.93,410,528.06,159,528.06,17.1,528.06,3.9,
,529.09,1702,529.09,99,528.31,534,528.45,414,528.45,62,528.45,0,528.57,0xFF02,528.69,5,528.82,410,528.95,159,528.95,17.1,528.95,3.9,
,529.99,1725,529.99,99,529.21,642,529.33,414,529.33,72,529.33,0,529.48,0xFF02,529.6,5,529.72,410,529.85,159,529.85,17.1,529.85,3.9,
,530.87,1725,530.87,99,530.11,702,530.23,420,530.23,85,530.23,0,530.36,0xFF02,530.5,5,530.63,410,530.75,159,530.75,17.1,530.75,3.9,
,531.78,1748,531.78,98.1,531.01,696,531.14,420,531.14,77,531.14,0,531.26,0xFF02,531.39,5,531.53,410,531.65,159,531.65,17.1,531.65,3.9,
,532.68,1771,532.68,98.1,531.9,684,532.04,420,532.04,85,532.04,0,532.17,0xFF02,532.29,5,532.42,410,532.56,159,532.56,17.1,532.56,3.9,
,533.59,1771,533.59,98.1,532.81,684,532.93,426,532.93,95,532.93,0,533.08,0xFF02,533.2,5,533.33,410,533.45,159,533.45,17.1,533.45,3.9,
,534.48,1794,534.48,98.1,533.71,678,533.84,426,533.84,95,533.84,0,533.96,0xFF02,534.1,5,534.23,410,534.35,159,534.35,17.1,534.35,3.9,
,535.39,1748,535.39,98.1,534.62,648,534.74,438,534.74,74,534.74,0,534.87,0xFF02,535,5,535.13,410,535.26,159,535.26,17.1,535.26,3.9,
,536.29,1725,536.29,98.1,535.51,600,535.65,438,535.65,46,535.65,0,535.77,0xFF02,535.9,5,536.02,410,536.16,159,536.16,17.1,536.16,3.9,
,537.2,1725,537.2,98.1,536.41,558,536.53,438,536.53,41,536.53,0,536.68,0xFF02,536.8,5,536.93,410,537.05,159,537.05,17.1,537.05,3.9,
,538.08,1679,538.08,98.1,537.32,534,537.44,432,537.44,36,537.44,0,537.56,0xFF02,537.71,5,537.83,410,537.95,159,537.95,17.1,537.95,3.9,
,538.99,1656,538.99,98.1,538.22,516,538.35,426,538.35,36,538.35,0,538.47,0xFF02,538.59,5,538.75,410,538.86,159,538.86,17.1,538.86,3.9,
,539.91,1656,539.91,98.1,539.11,492,539.26,426,539.26,33,539.26,0,539.39,0xFF02,539.52,5,539.64,410,539.78,159,539.78,16.8,539.78,3.9,
,540.82,1679,540.82,98.1,540.03,486,540.15,426,540.15,44,540.15,0,540.31,0xFF02,540.42,5,540.54,410,540.67,159,540.67,16.8,540.67,3.9,
,541.71,1679,541.71,98.1,540.95,504,541.08,426,541.08,67,541.08,0,541.2,0xFF02,541.34,5,541.46,410,541.59,159,541.59,16.8,541.59,3.9,
,542.63,1679,542.63,98.1,541.87,600,541.98,432,541.98,79,541.98,0,542.1,0xFF02,542.23,5,542.38,410,542.51,159,542.51,16.8,542.51,3.9,
,543.54,1656,543.54,98.1,542.76,666,542.9,438,542.9,69,542.9,0,543.02,0xFF02,543.16,5,543.28,410,543.43,159,543.43,16.8,543.43,3.9,
,544.47,1633,544.47,98.1,543.66,636,543.79,444,543.79,41,543.79,0,543.94,0xFF02,544.07,5,544.2,410,544.32,159,544.32,16.8,544.32,3.9,
,545.35,1610,545.35,98.1,544.58,564,544.71,438,544.71,33,544.71,0,544.83,0xFF02,544.97,5,545.1,410,545.22,159,545.22,16.8,545.22,3.6,
,546.26,1587,546.26,98.1,545.49,504,545.61,438,545.61,31,545.61,0,545.74,0xFF02,545.86,5,546.02,410,546.13,159,546.13,16.8,546.13,3.6,
,547.19,1587,547.19,98.1,546.38,462,546.53,438,546.53,31,546.53,0,546.66,0xFF02,546.78,5,546.91,410,547.06,159,547.06,16.8,547.06,3.6,
,548.1,1587,548.1,98.1,547.31,450,547.44,438,547.44,49,547.44,0,547.58,0xFF02,547.7,5,547.83,410,547.95,159,547.95,16.8,547.95,3.6,
,549,1610,549,97.2,548.22,522,548.34,438,548.34,64,548.34,0,548.47,0xFF02,548.62,5,548.75,410,548.87,159,548.87,16.8,548.87,3.6,
,549.9,1610,549.9,97.2,549.14,624,549.26,444,549.26,74,549.26,0,549.39,0xFF02,549.51,5,549.66,410,549.78,159,549.78,16.8,549.78,3.6,
,550.82,1610,550.82,97.2,550.03,678,550.18,450,550.18,74,550.18,0,550.32,0xFF02,550.43,5,550.56,410,550.7,159,550.7,16.8,550.7,3.6,
,551.74,1587,551.74,97.2,550.95,666,551.08,450,551.08,64,551.08,0,551.22,0xFF02,551.34,5,551.46,410,551.59,159,551.59,16.8,551.59,3.6,
,552.63,1587,552.63,97.2,551.87,630,552,456,552,49,552,0,552.12,0xFF02,552.26,5,552.38,410,552.51,159,552.51,16.8,552.51,3.6,
,553.55,1587,553.55,97.2,552.78,600,552.9,456,552.9,49,552.9,0,553.02,0xFF02,553.15,5,553.3,410,553.43,159,553.43,16.8,553.43,3.6,
,554.46,1587,554.46,97.2,553.68,600,553.82,456,553.82,59,553.82,0,553.94,0xFF02,554.07,5,554.19,410,554.34,159,554.34,16.8,554.34,3.6,
,555.38,1587,555.38,97.2,554.58,618,554.71,462,554.71,64,554.71,0,554.86,0xFF02,554.99,5,555.11,410,555.24,159,555.24,16.8,555.24,3.6,
,556.27,1610,556.27,97.2,555.5,648,555.63,462,555.63,64,555.63,0,555.75,0xFF02,555.9,5,556.02,410,556.14,159,556.14,16.8,556.14,3.6,
,557.19,1564,557.19,97.2,556.42,642,556.55,468,556.55,56,556.55,0,556.67,0xFF02,556.8,5,556.94,410,557.06,159,557.06,16.8,557.06,3.6,
,558.11,1541,558.11,97.2,557.31,606,557.46,468,557.46,44,557.46,0,557.58,0xFF02,557.71,5,557.83,410,557.98,159,557.98,16.8,557.98,3.6,
,559.02,1564,559.02,97.2,558.23,564,558.36,468,558.36,36,558.36,0,558.5,0xFF02,558.62,5,558.75,410,558.88,159,558.88,16.5,558.88,3.3,
,559.92,1564,559.92,97.2,559.14,546,559.26,468,559.26,44,559.26,0,559.39,0xFF02,559.54,5,559.67,410,559.79,159,559.79,16.5,559.79,3.3,
,560.82,1541,560.82,97.2,560.07,552,560.18,468,560.18,54,560.18,0,560.31,0xFF02,560.43,5,560.58,410,560.7,159,560.7,16.5,560.7,3.3,
,561.74,1541,561.74,97.2,560.95,594,561.1,474,561.1,56,561.1,0,561.23,0xFF02,561.35,5,561.48,410,561.62,159,561.62,16.5,561.62,3.3,
,562.66,1518,562.66,97.2,561.87,606,561.99,474,561.99,44,561.99,0,562.14,0xFF02,562.26,5,562.38,410,562.51,159,562.51,16.5,562.51,3.3,
,563.55,1518,563.55,97.2,562.79,570,562.92,474,562.92,36,562.92,0,563.04,0xFF02,563.18,5,563.3,410,563.43,159,563.43,16.5,563.43,3.3,
,564.47,1518,564.47,97.2,563.7,552,563.82,474,563.82,38,563.82,0,563.94,0xFF02,564.07,5,564.22,410,564.35,159,564.35,16.5,564.35,3.3,
,565.38,1518,565.38,97.2,564.6,558,564.74,474,564.74,51,564.74,0,564.86,0xFF02,564.99,5,565.11,410,565.25,159,565.25,16.5,565.25,3.3,
,566.3,1541,566.3,97.2,565.5,612,565.63,480,565.63,59,565.63,0,565.78,0xFF02,565.91,5,566.03,410,566.16,159,566.16,16.5,566.16,3.3,
,567.19,1541,567.19,97.2,566.42,648,566.55,486,566.55,62,566.55,0,566.67,0xFF02,566.82,5,566.94,410,567.06,159,567.06,16.5,567.06,3.3,
,568.11,1541,568.11,97.2,567.34,666,567.47,492,567.47,62,567.47,0,567.59,0xFF02,567.72,5,567.87,410,567.98,159,567.98,16.5,567.98,3,
,569.03,1564,569.03,97.2,568.23,666,568.38,492,568.38,67,568.38,0,568.5,0xFF02,568.62,5,568.75,410,568.9,159,568.91,16.5,568.91,3,
,569.93,1587,569.93,97.2,569.15,666,569.28,498,569.28,69,569.28,0,569.42,0xFF02,569.54,5,569.67,410,569.79,159,569.79,16.2,569.79,3,
,570.84,1587,570.84,97.2,570.06,660,570.18,504,570.18,69,570.18,0,570.31,0xFF02,570.46,5,570.59,410,570.71,159,570.71,16.2,570.71,3,
,571.74,1587,571.74,96.3,570.98,660,571.1,516,571.1,69,571.1,0,571.23,0xFF02,571.35,5,571.5,410,571.62,159,571.62,16.2,571.62,3,
,572.66,1610,572.66,97.2,571.87,654,572.02,516,572.02,67,572.02,0,572.15,0xFF02,572.27,5,572.4,410,572.54,159,572.54,16.2,572.54,3,
,573.58,1587,573.58,96.3,572.79,648,572.91,522,572.91,64,572.91,0,573.05,0xFF02,573.18,5,573.31,410,573.43,159,573.43,16.2,573.43,3,
,574.48,1587,574.48,97.2,573.71,642,573.83,522,573.83,59,573.83,0,573.96,0xFF02,574.1,4,574.23,410,574.36,159,574.36,16.2,574.36,3,
,575.39,1587,575.39,97.2,574.62,618,574.74,522,574.74,54,574.74,0,574.86,0xFF02,574.99,4,575.14,410,575.27,159,575.27,16.2,575.27,3,
,576.3,1564,576.3,97.2,575.53,594,575.67,528,575.67,44,575.67,0,575.78,0xFF02,575.91,4,576.03,410,576.18,159,576.18,16.2,576.18,3,
,577.22,1564,577.22,97.2,576.42,564,576.56,528,576.56,36,576.56,0,576.69,0xFF02,576.81,4,576.94,410,577.06,159,577.06,16.2,577.06,3,
,578.11,1541,578.11,97.2,577.33,546,577.45,522,577.45,33,577.45,0,577.58,0xFF02,577.73,4,577.86,410,577.98,159,577.98,15.9,577.98,3,
,579.01,1495,579.01,97.2,578.25,516,578.37,522,578.37,26,578.37,0,578.5,0xFF02,578.62,4,578.77,410,578.89,159,578.89,15.9,578.89,3,
,579.93,1495,579.93,97.2,579.14,462,579.29,522,579.29,26,579.29,0,579.42,0xFF02,579.54,4,579.67,410,579.81,159,579.81,15.9,579.81,2.7,
,580.85,1472,580.85,97.2,580.06,420,580.18,522,580.18,31,580.18,0,580.34,0xFF02,580.45,4,580.57,410,580.7,159,580.7,15.9,580.7,2.7,
,581.74,1449,581.74,97.2,580.98,396,581.1,522,581.1,26,581.1,0,581.23,0xFF02,581.37,4,581.49,410,581.62,159,581.62,15.9,581.62,2.7,
,582.67,1426,582.67,97.2,581.89,360,582.01,522,582.01,23,582.01,0,582.13,0xFF02,582.26,4,582.41,410,582.54,159,582.54,15.9,582.54,2.7,
,583.57,1426,583.57,97.2,582.79,330,582.93,516,582.93,23,582.93,0,583.05,0xFF02,583.18,4,583.3,410,583.46,159,583.46,15.9,583.46,2.7,
,584.49,1426,584.49,97.2,583.69,312,583.82,516,583.82,28,583.82,0,583.97,0xFF02,584.1,4,584.22,410,584.35,159,584.35,15.9,584.35,2.7,
,585.38,1426,585.38,97.2,584.61,312,584.74,516,584.74,31,584.74,0,584.86,0xFF02,585.02,4,585.13,410,585.25,159,585.25,15.6,585.25,2.7,
,586.3,1449,586.3,97.2,585.53,354,585.66,522,585.66,28,585.66,0,585.78,0xFF02,585.91,4,586.05,410,586.17,159,586.17,15.6,586.17,2.7,
,587.22,1403,587.22,97.2,586.42,378,586.58,522,586.58,41,586.58,0,586.69,0xFF02,586.81,4,586.94,410,587.09,159,587.09,15.6,587.09,2.4,
,588.13,1449,588.13,97.2,587.34,438,587.47,522,587.47,33,587.47,0,587.61,0xFF02,587.73,4,587.86,410,587.98,159,587.98,15.6,587.98,2.4,
,589.03,1403,589.03,97.2,588.25,426,588.37,528,588.37,23,588.37,0,588.5,0xFF02,588.65,4,588.78,410,588.9,159,588.9,15.6,588.9,2.4,
,589.93,1219,589.93,97.2,589.17,384,589.29,528,589.29,23,589.29,0,589.42,0xFF02,589.54,4,589.7,410,589.81,159,589.81,15.6,589.81,2.4,
,590.85,1288,590.85,97.2,590.06,348,590.21,528,590.21,21,590.21,0,590.34,0xFF02,590.46,4,590.59,410,590.73,159,590.73,15.6,590.73,2.4,
,591.77,1265,591.77,97.2,590.98,318,591.1,528,591.1,18,591.1,0,591.26,0xFF02,591.37,4,591.49,410,591.62,159,591.62,15.6,591.62,2.4,
,592.66,1242,592.66,96.3,591.9,294,592.02,528,592.02,21,592.02,0,592.15,0xFF02,592.29,4,592.41,410,592.54,159,592.54,15.3,592.54,2.4,
,593.58,1219,593.58,96.3,592.82,276,592.93,528,592.93,18,592.93,0,593.05,0xFF02,593.18,4,593.33,410,593.46,159,593.46,15.3,593.46,2.4,
,594.49,1196,594.49,96.3,593.71,258,593.85,528,593.85,18,593.85,0,593.97,0xFF02,594.1,4,594.22,410,594.38,159,594.38,15.3,594.38,2.4,
,595.41,1127,595.41,96.3,594.61,246,594.74,528,594.74,18,594.74,0,594.89,0xFF02,595.02,4,595.14,410,595.27,159,595.27,15.3,595.27,2.1,
,596.3,1403,596.3,96.3,595.53,240,595.66,528,595.66,18,595.66,0,595.78,0xFF02,595.93,4,596.05,410,596.17,159,596.17,15.3,596.17,2.1,
,597.22,1357,597.22,96.3,596.45,234,596.58,528,596.58,21,596.58,0,596.7,0xFF02,596.83,4,596.97,410,597.09,159,597.09,15.3,597.09,2.1,
,598.14,1334,598.14,96.3,597.34,228,597.5,528,597.5,21,597.5,0,597.61,0xFF02,597.73,4,597.86,410,598.01,159,598.01,15.3,598.01,2.1,
,599.06,1219,599.06,96.3,598.26,216,598.39,534,598.39,21,598.39,0,598.53,0xFF02,598.65,4,598.78,410,598.9,159,598.9,15.3,598.9,2.1,
,599.93,1058,599.93,96.3,599.17,210,599.29,534,599.29,18,599.29,0,599.42,0xFF02,599.57,4,599.68,410,599.82,159,599.82,15,599.82,2.1,
,600.85,1150,600.85,96.3,600.09,210,600.2,534,600.2,15,600.2,0,600.33,0xFF02,600.45,4,600.59,410,600.71,159,600.71,15,600.71,2.1,
,601.74,1173,601.74,96.3,600.96,210,601.11,534,601.11,15,601.11,0,601.23,0xFF02,601.37,4,601.48,410,601.62,159,601.62,15,601.62,2.1,
,602.65,943,602.65,96.3,601.87,204,601.99,534,601.99,15,601.99,0,602.13,0xFF02,602.26,4,602.39,410,602.51,159,602.51,15,602.51,1.8,
,603.54,897,603.54,96.3,602.77,204,602.9,534,602.9,15,602.9,0,603.02,0xFF02,603.16,4,603.29,410,603.42,159,603.42,15,603.42,1.8,
,604.44,851,604.44,96.3,603.68,204,603.8,534,603.8,13,603.8,0,603.92,0xFF02,604.05,4,604.19,410,604.32,159,604.32,15,604.32,1.8,
,605.35,851,605.35,96.3,604.57,204,604.7,534,604.7,13,604.7,0,604.83,0xFF02,604.95,4,605.08,410,605.22,159,605.22,15,605.22,1.8,
,606.25,1081,606.25,96.3,605.47,204,605.59,528,605.59,13,605.59,0,605.73,0xFF02,605.86,4,605.99,410,606.11,159,606.11,15,606.11,1.8,
,607.14,1104,607.14,95.4,606.38,210,606.5,528,606.5,15,606.5,0,606.63,0xFF02,606.76,4,606.89,410,607.02,159,607.02,14.7,607.02,1.8,
,608.04,1081,608.04,95.4,607.28,216,607.41,528,607.41,15,607.41,0,607.53,0xFF02,607.65,4,607.8,410,607.92,159,607.92,14.7,607.92,1.8,
,608.95,1104,608.95,95.4,608.17,258,608.31,528,608.31,15,608.31,0,608.43,0xFF02,608.56,4,608.68,410,608.83,159,608.83,14.7,608.83,1.8,
,609.86,1150,609.86,95.4,609.08,270,609.2,534,609.2,15,609.2,0,609.34,0xFF02,609.46,4,609.59,410,609.71,159,609.71,14.7,609.71,1.8,
,610.74,1196,610.74,95.4,609.98,294,610.1,534,610.1,15,610.1,0,610.23,0xFF02,610.38,4,610.49,410,610.62,159,610.62,14.7,610.62,1.8,
,611.65,1288,611.65,95.4,610.88,318,611.01,534,611.01,21,611.01,0,611.13,0xFF02,611.26,4,611.4,410,611.52,159,611.52,14.7,611.52,1.8,
,612.55,1357,612.55,95.4,611.77,348,611.91,534,611.91,23,611.91,0,612.04,0xFF02,612.16,4,612.29,410,612.43,159,612.43,14.7,612.43,1.5,
,613.46,1403,613.46,95.4,612.68,390,612.81,534,612.81,23,612.81,0,612.94,0xFF02,613.07,4,613.19,410,613.33,159,613.33,14.7,613.33,1.5,
,614.35,1449,614.36,95.4,613.59,426,613.71,540,613.71,23,613.71,0,613.84,0xFF02,613.97,4,614.11,410,614.22,159,614.22,14.7,614.22,1.5,
,615.25,1449,615.25,95.4,614.49,444,614.62,546,614.62,23,614.62,0,614.74,0xFF02,614.87,4,615,410,615.14,159,615.14,14.7,615.14,1.5,
,616.16,1679,616.16,95.4,615.38,444,615.52,546,615.52,23,615.52,0,615.65,0xFF02,615.77,4,615.9,410,616.03,159,616.03,14.4,616.03,1.5,
,617.06,2024,617.06,94.5,616.28,444,616.41,546,616.41,44,616.41,0,616.55,0xFF02,616.68,4,616.8,410,616.93,159,616.93,14.4,616.93,1.5,
,617.95,2277,617.95,94.5,617.19,534,617.31,546,617.31,74,617.31,0,617.44,0xFF02,617.58,4,617.71,410,617.83,159,617.83,14.4,617.83,1.2,
,618.86,1564,618.86,94.5,618.09,666,618.22,558,618.22,85,618.22,0,618.34,0xFF02,618.46,4,618.61,410,618.73,159,618.73,14.4,618.73,1.2,
,619.76,1541,619.76,94.5,618.98,648,619.12,558,619.12,54,619.12,0,619.25,0xFF02,619.37,4,619.5,410,619.64,159,619.64,14.4,619.64,1.2,
,620.67,1472,620.67,94.5,619.89,582,620.01,558,620.01,26,620.01,0,620.15,0xFF02,620.27,4,620.4,410,620.52,159,620.52,14.4,620.52,1.2,
,621.55,1449,621.55,94.5,620.79,492,620.91,558,620.91,21,620.91,0,621.04,0xFF02,621.18,4,621.3,410,621.43,159,621.43,14.4,621.43,1.2,
,622.46,1449,622.46,94.5,621.7,426,621.82,558,621.82,21,621.82,0,621.94,0xFF02,622.07,4,622.21,410,622.33,159,622.33,14.4,622.33,1.2,
,623.36,1426,623.36,94.5,622.58,384,622.73,558,622.73,23,622.73,0,622.85,0xFF02,622.98,4,623.1,410,623.24,159,623.24,14.4,623.24,1.2,
,624.27,1426,624.27,94.5,623.49,360,623.61,552,623.61,23,623.61,0,623.76,0xFF02,623.88,3,624,410,624.13,159,624.13,14.1,624.13,1.2,
,625.16,1380,625.16,94.5,624.39,336,624.52,552,624.52,21,624.52,0,624.64,0xFF02,624.78,3,624.91,410,625.03,159,625.03,14.1,625.03,1.2,
,626.08,1357,626.08,94.5,625.31,324,625.44,546,625.44,18,625.44,0,625.57,0xFF02,625.69,3,625.83,410,625.95,159,625.95,14.1,625.95,1.2,
,627,1311,627,94.5,626.2,300,626.34,546,626.34,18,626.34,0,626.47,0xFF02,626.59,3,626.72,410,626.87,159,626.87,14.1,626.87,0.9,
,627.9,1288,627.9,94.5,627.12,276,627.25,546,627.25,18,627.25,0,627.39,0xFF02,627.51,3,627.64,410,627.76,159,627.76,14.1,627.76,0.9,
,628.81,1265,628.81,94.5,628.03,258,628.15,546,628.15,18,628.15,0,628.28,0xFF02,628.43,3,628.56,410,628.68,159,628.68,14.1,628.68,0.9,
,629.71,1219,629.71,94.5,628.95,246,629.07,540,629.07,15,629.07,0,629.2,0xFF02,629.32,3,629.47,410,629.59,159,629.59,14.1,629.59,0.9,
,630.63,1173,630.63,93.6,629.84,234,629.99,534,629.99,15,629.99,0,630.12,0xFF02,630.24,3,630.37,410,630.51,159,630.51,14.1,630.51,0.9,
,631.55,1150,631.55,93.6,630.76,228,630.88,534,630.88,15,630.88,0,631.02,0xFF02,631.15,3,631.27,410,631.4,159,631.4,14.1,631.4,0.9,
,632.44,1058,632.44,93.6,631.68,216,631.8,534,631.8,13,631.8,0,631.93,0xFF02,632.07,3,632.19,410,632.32,159,632.32,14.1,632.32,0.9,
,633.36,920,633.36,93.6,632.58,210,632.71,534,632.71,13,632.71,0,632.83,0xFF02,632.96,3,633.11,410,633.24,159,633.24,13.8,633.24,0.9,
,634.27,805,634.27,93.6,633.49,210,633.63,534,633.63,10,633.63,0,633.75,0xFF02,633.88,3,634,410,634.14,159,634.14,13.8,634.14,0.9,
,635.19,851,635.19,93.6,634.39,204,634.52,528,634.52,10,634.52,0,634.67,0xFF02,634.8,3,634.92,410,635.05,159,635.05,13.8,635.05,0.9,
,636.08,851,636.08,93.6,635.31,210,635.44,528,635.44,10,635.44,0,635.56,0xFF02,635.7,3,635.83,410,635.95,159,635.95,13.8,635.95,0.9,
,637,805,637,93.6,636.23,228,636.36,522,636.36,10,636.36,0,636.48,0xFF02,636.61,3,636.75,410,636.87,159,636.87,13.8,636.87,0.9,
,637.92,828,637.92,93.6,637.12,246,637.26,522,637.26,10,637.26,0,637.39,0xFF02,637.51,3,637.64,410,637.79,159,637.79,13.8,637.79,0.9,
,638.83,851,638.83,93.6,638.04,270,638.17,522,638.17,10,638.17,0,638.31,0xFF02,638.43,3,638.56,410,638.68,159,638.68,13.8,638.68,0.9,
,639.71,851,639.71,93.6,638.95,300,639.07,522,639.07,10,639.07,0,639.2,0xFF02,639.34,3,639.46,410,639.59,159,639.59,13.8,639.59,0.9,
,640.63,851,640.63,93.6,639.86,336,639.98,516,639.98,10,639.98,0,640.1,0xFF02,640.23,3,640.38,410,640.49,159,640.49,13.8,640.49,0.9,
,641.52,828,641.52,93.6,640.74,360,640.89,516,640.89,10,640.89,0,641.01,0xFF02,641.14,3,641.26,410,641.4,159,641.4,13.8,641.4,0.9,
,642.43,851,642.43,93.6,641.66,384,641.77,516,641.77,10,641.77,0,641.92,0xFF02,642.04,3,642.17,410,642.29,159,642.29,13.8,642.29,0.9,
,643.32,851,643.32,93.6,642.55,402,642.68,516,642.68,10,642.68,0,642.8,0xFF02,642.94,3,643.07,410,643.2,159,643.2,13.8,643.2,0.9,
,644.23,851,644.23,93.6,643.46,414,643.58,516,643.58,10,643.58,0,643.71,0xFF02,643.83,3,643.97,410,644.1,159,644.1,13.8,644.1,0.9,
,645.12,851,645.12,93.6,644.35,432,644.49,516,644.49,10,644.49,0,644.61,0xFF02,644.74,3,644.86,410,645,159,645,13.8,645,0.9,
,646.03,851,646.03,93.6,645.25,444,645.38,516,645.38,10,645.38,0,645.52,0xFF02,645.64,3,645.77,410,645.89,159,645.89,13.8,645.89,0.9,
,646.92,805,646.92,93.6,646.15,456,646.28,510,646.28,10,646.28,0,646.41,0xFF02,646.55,3,646.67,410,646.8,159,646.8,13.8,646.8,0.9,
,647.82,828,647.82,93.6,647.06,468,647.19,510,647.19,8,647.19,0,647.31,0xFF02,647.43,3,647.58,410,647.7,159,647.7,13.8,647.7,0.9,
,648.73,851,648.73,93.6,647.95,474,648.09,510,648.09,8,648.09,0,648.21,0xFF02,648.34,3,648.46,410,648.61,159,648.61,13.8,648.61,0.9,
,649.64,805,649.64,93.6,648.85,474,648.98,504,648.98,8,648.98,0,649.12,0xFF02,649.24,3,649.37,410,649.49,159,649.49,13.8,649.49,0.9,
,650.52,828,650.52,93.6,649.76,486,649.88,504,649.88,8,649.88,0,650.01,0xFF02,650.15,3,650.27,410,650.4,159,650.4,13.8,650.4,0.9,
,651.43,828,651.43,93.6,650.66,486,650.79,504,650.79,8,650.79,0,650.91,0xFF02,651.04,3,651.18,410,651.3,159,651.3,13.8,651.3,0.9,
,652.33,828,652.33,93.6,651.55,486,651.69,504,651.69,8,651.69,0,651.82,0xFF02,651.94,3,652.07,410,652.21,159,652.21,13.8,652.21,0.9,
,653.24,828,653.24,93.6,652.46,492,652.58,504,652.58,8,652.58,0,652.72,0xFF02,652.85,3,652.97,410,653.11,159,653.11,13.8,653.11,0.9,
,654.14,828,654.14,93.6,653.36,492,653.49,504,653.49,8,653.49,0,653.62,0xFF02,653.75,3,653.89,410,654,159,654,13.8,654,0.9,
,655.03,828,655.03,93.6,654.27,492,654.4,504,654.4,8,654.4,0,654.52,0xFF02,654.65,3,654.78,410,654.92,159,654.92,13.8,654.92,0.9,
,655.94,828,655.94,93.6,655.16,492,655.3,498,655.3,8,655.3,0,655.43,0xFF02,655.55,3,655.68,410,655.81,159,655.81,13.8,655.81,0.9,
,656.84,828,656.84,93.6,656.06,492,656.19,498,656.19,8,656.19,0,656.33,0xFF02,656.46,3,656.58,410,656.71,159,656.71,13.8,656.71,0.9,
,657.73,828,657.73,93.6,656.97,498,657.09,498,657.09,8,657.09,0,657.22,0xFF02,657.36,3,657.49,410,657.61,159,657.61,13.8,657.61,0.9,
,658.64,828,658.64,93.6,657.87,498,658,498,658,8,658,0,658.12,0xFF02,658.25,3,658.39,410,658.51,159,658.51,13.5,658.51,0.9,
,659.54,828,659.54,93.6,658.76,498,658.9,498,658.9,8,658.9,0,659.03,0xFF02,659.15,3,659.28,410,659.42,159,659.42,13.5,659.42,0.9,
,660.45,828,660.45,93.6,659.67,504,659.79,492,659.79,8,659.79,0,659.93,0xFF02,660.06,3,660.18,410,660.3,159,660.3,13.5,660.3,0.9,
,661.33,828,661.33,93.6,660.57,504,660.69,492,660.69,8,660.69,0,660.82,0xFF02,660.96,3,661.08,410,661.21,159,661.21,13.5,661.21,0.9,
,662.24,828,662.24,93.6,661.48,504,661.6,492,661.6,8,661.6,0,661.72,0xFF02,661.85,3,661.99,410,662.11,159,662.11,13.5,662.11,0.9,
,663.14,828,663.14,93.6,662.36,504,662.5,492,662.5,8,662.5,0,662.63,0xFF02,662.75,3,662.88,410,663.02,159,663.02,13.5,663.02,0.9,
,664.05,805,664.05,93.6,663.27,504,663.39,492,663.39,8,663.39,0,663.53,0xFF02,663.66,3,663.78,410,663.91,159,663.91,13.5,663.91,0.9,
,664.94,828,664.94,93.6,664.17,504,664.3,492,664.3,8,664.3,0,664.42,0xFF02,664.56,3,664.69,410,664.81,159,664.81,13.5,664.81,0.9,
,665.84,828,665.84,93.6,665.08,504,665.2,492,665.2,8,665.2,0,665.33,0xFF02,665.45,3,665.6,410,665.72,159,665.72,13.5,665.72,0.9,
,666.76,805,666.76,94.5,665.97,510,666.12,492,666.12,8,666.12,0,666.25,0xFF02,666.37,3,666.5,410,666.64,159,666.64,13.5,666.64,0.9,
,667.68,828,667.68,94.5,666.89,516,667.01,492,667.01,8,667.01,0,667.16,0xFF02,667.28,3,667.4,410,667.53,159,667.53,13.5,667.53,0.9,
,668.56,1081,668.56,94.5,667.79,516,667.93,492,667.93,8,667.93,0,668.04,0xFF02,668.19,3,668.31,410,668.44,159,668.44,13.5,668.44,0.9,
,669.47,1449,669.47,94.5,668.7,516,668.82,492,668.82,13,668.82,0,668.96,0xFF02,669.07,3,669.22,410,669.34,159,669.34,13.5,669.34,0.6,
,670.37,1541,670.37,94.5,669.58,522,669.73,492,669.73,26,669.73,0,669.85,0xFF02,669.98,3,670.1,410,670.25,159,670.25,13.5,670.25,0.6,
,671.27,1334,671.27,94.5,670.5,564,670.61,492,670.61,26,670.61,0,670.76,0xFF02,670.88,3,671.02,410,671.13,159,671.13,13.5,671.13,0.6,
,672.16,1035,672.16,94.5,671.4,594,671.53,492,671.53,23,671.53,0,671.64,0xFF02,671.79,3,671.91,410,672.04,159,672.04,13.5,672.04,0.6,
,673.07,989,673.07,94.5,672.3,582,672.43,492,672.43,15,672.43,0,672.56,0xFF02,672.67,3,672.81,410,672.94,159,672.94,13.5,672.94,0.6,
,673.97,966,673.97,94.5,673.19,558,673.33,492,673.33,13,673.33,0,673.46,0xFF02,673.58,3,673.7,410,673.84,159,673.84,13.5,673.84,0.6,
,674.88,943,674.88,94.5,674.1,534,674.22,492,674.22,13,674.22,0,674.36,0xFF02,674.49,3,674.61,410,674.73,159,674.73,13.5,674.73,0.6,
,675.76,943,675.76,94.5,675,522,675.12,492,675.12,13,675.12,0,675.25,0xFF02,675.39,3,675.51,410,675.64,159,675.64,13.5,675.64,0.6,
,676.67,943,676.67,94.5,675.9,516,676.03,492,676.03,13,676.03,0,676.15,0xFF02,676.28,3,676.42,410,676.54,159,676.54,13.5,676.54,0.6,
,677.58,943,677.58,95.4,676.79,510,676.93,492,676.93,13,676.93,0,677.06,0xFF02,677.18,3,677.31,410,677.45,159,677.45,13.5,677.45,0.6,
,678.48,943,678.48,95.4,677.7,504,677.82,492,677.82,13,677.82,0,677.96,0xFF02,678.09,3,678.21,410,678.34,159,678.34,13.5,678.34,0.6,
,679.37,920,679.37,95.4,678.6,504,678.73,492,678.73,13,678.73,0,678.85,0xFF02,678.99,3,679.12,410,679.24,159,679.24,13.5,679.24,0.6,
,680.28,943,680.28,95.4,679.51,498,679.63,486,679.63,13,679.63,0,679.76,0xFF02,679.88,3,680.02,410,680.15,159,680.15,13.5,680.15,0.6,
,681.18,943,681.18,95.4,680.4,504,680.54,486,680.54,13,680.54,0,680.66,0xFF02,680.79,3,680.92,410,681.05,159,681.05,13.5,681.05,0.6,
,682.08,943,682.08,95.4,681.3,504,681.44,486,681.44,13,681.44,0,681.57,0xFF02,681.7,3,681.82,410,681.95,159,681.95,13.5,681.95,0.6,
,682.98,943,682.98,95.4,682.22,504,682.33,486,682.33,13,682.33,0,682.46,0xFF02,682.6,3,682.73,410,682.84,159,682.84,13.5,682.84,0.6,
,683.88,943,683.88,95.4,683.11,504,683.24,486,683.24,10,683.24,0,683.36,0xFF02,683.5,3,683.63,410,683.76,159,683.76,13.5,683.76,0.6,
,684.79,943,684.79,95.4,684.01,504,684.14,486,684.14,13,684.14,0,684.28,0xFF02,684.39,3,684.52,410,684.66,159,684.66,13.5,684.66,0.6,
,685.69,943,685.69,95.4,684.9,510,685.04,486,685.04,13,685.04,0,685.17,0xFF02,685.3,3,685.42,410,685.55,159,685.55,13.5,685.55,0.6,
,686.58,943,686.58,95.4,685.82,516,685.93,486,685.93,13,685.93,0,686.06,0xFF02,686.2,3,686.32,410,686.45,159,686.45,13.5,686.45,0.6,
,687.48,943,687.48,95.4,686.72,516,686.84,486,686.84,13,686.84,0,686.96,0xFF02,687.09,3,687.23,410,687.35,159,687.35,13.5,687.35,0.6,
,688.38,943,688.38,95.4,687.6,516,687.74,486,687.74,13,687.74,0,687.87,0xFF02,687.99,3,688.12,410,688.26,159,688.26,13.5,688.26,0.6,
,689.29,943,689.29,95.4,688.51,522,688.63,486,688.63,13,688.63,0,688.78,0xFF02,688.9,3,689.02,410,689.15,159,689.15,13.5,689.15,0.6,
,690.18,943,690.18,95.4,689.41,522,689.54,480,689.54,10,689.54,0,689.66,0xFF02,689.8,3,689.93,410,690.05,159,690.05,13.5,690.05,0.6,
,691.08,943,691.08,95.4,690.32,522,690.44,480,690.44,13,690.44,0,690.57,0xFF02,690.69,3,690.84,410,690.96,159,690.96,13.5,690.96,0.6,
,691.99,943,691.99,95.4,691.21,528,691.35,480,691.35,10,691.35,0,691.48,0xFF02,691.6,3,691.72,410,691.86,159,691.86,13.5,691.86,0.6,
,692.89,943,692.89,95.4,692.11,528,692.24,480,692.24,13,692.24,0,692.38,0xFF02,692.5,3,692.63,410,692.75,159,692.75,13.5,692.75,0.6,
,693.78,943,693.78,95.4,693.02,528,693.14,480,693.14,10,693.14,0,693.27,0xFF02,693.42,3,693.53,410,693.66,159,693.66,13.5,693.66,0.6,
,694.7,943,694.7,95.4,693.93,528,694.05,474,694.05,10,694.05,0,694.18,0xFF02,694.3,3,694.45,410,694.56,159,694.56,13.5,694.56,0.6,
,695.6,943,695.6,95.4,694.81,528,694.96,474,694.96,13,694.96,0,695.08,0xFF02,695.21,3,695.33,410,695.47,159,695.47,13.5,695.47,0.6,
,696.5,943,696.5,95.4,695.72,528,695.84,474,695.84,13,695.84,0,695.99,0xFF02,696.11,3,696.24,410,696.36,159,696.36,13.5,696.36,0.6,
,697.39,943,697.39,95.4,696.62,528,696.76,474,696.76,13,696.76,0,696.87,0xFF02,697.01,3,697.13,410,697.27,159,697.27,13.5,697.27,0.6,
,698.3,943,698.3,95.4,697.53,528,697.65,474,697.65,13,697.65,0,697.77,0xFF02,697.9,3,698.04,410,698.17,159,698.17,13.5,698.17,0.6,
,699.2,943,699.2,95.4,698.42,528,698.56,474,698.56,13,698.56,0,698.68,0xFF02,698.8,3,698.93,410,699.07,159,699.07,13.5,699.07,0.6,
,700.1,943,700.1,95.4,699.32,528,699.44,474,699.44,13,699.44,0,699.59,0xFF02,699.71,3,699.84,410,699.96,159,699.96,13.5,699.96,0.6,
,700.99,943,700.99,95.4,700.22,528,700.35,474,700.35,13,700.35,0,700.48,0xFF02,700.62,3,700.74,410,700.86,159,700.86,13.5,700.86,0.6,
,701.89,943,701.89,95.4,701.13,528,701.26,474,701.26,13,701.26,0,701.38,0xFF02,701.5,3,701.64,410,701.77,159,701.77,13.5,701.77,0.6,
,702.8,943,702.8,95.4,702.02,528,702.16,474,702.16,13,702.16,0,702.28,0xFF02,702.41,3,702.54,410,702.68,159,702.68,13.5,702.68,0.6,
,703.7,943,703.7,96.3,702.92,528,703.05,474,703.05,13,703.05,0,703.19,0xFF02,703.31,3,703.44,410,703.56,159,703.56,13.5,703.56,0.6,
,704.6,943,704.6,96.3,703.83,534,703.96,474,703.96,13,703.96,0,704.08,0xFF02,704.22,3,704.34,410,704.47,159,704.47,13.5,704.47,0.6,
,705.5,943,705.5,96.3,704.73,534,704.86,474,704.86,13,704.86,0,704.98,0xFF02,705.11,3,705.25,410,705.38,159,705.38,13.5,705.38,0.6,
,706.4,943,706.4,96.3,705.62,534,705.76,474,705.76,13,705.76,0,705.89,0xFF02,706.01,3,706.14,410,706.28,159,706.28,13.5,706.28,0.6,
,707.31,943,707.31,96.3,706.53,534,706.65,474,706.65,13,706.65,0,706.8,0xFF02,706.92,3,707.04,410,707.18,159,707.18,13.5,707.18,0.6,
,708.21,943,708.21,96.3,707.43,534,707.56,468,707.56,13,707.56,0,707.69,0xFF02,707.82,3,707.96,410,708.07,159,708.07,13.5,708.07,0.6,
,709.12,943,709.12,96.3,708.34,534,708.48,468,708.48,13,708.48,0,708.6,0xFF02,708.74,3,708.87,410,708.99,159,708.99,13.5,708.99,0.6,
,710.03,943,710.03,96.3,709.25,534,709.38,468,709.38,13,709.38,0,709.52,0xFF02,709.63,3,709.76,410,709.9,159,709.9,13.5,709.9,0.6,
,710.92,943,710.92,96.3,710.14,534,710.28,468,710.28,13,710.28,0,710.41,0xFF02,710.55,3,710.66,410,710.79,159,710.79,13.5,710.79,0.6,
,711.81,1012,711.81,96.3,711.06,534,711.18,468,711.18,13,711.18,0,711.31,0xFF02,711.44,3,711.58,410,711.69,159,711.69,13.5,711.69,0.6,
,712.72,1035,712.72,96.3,711.95,534,712.09,468,712.09,15,712.09,0,712.21,0xFF02,712.34,3,712.48,410,712.6,159,712.6,13.5,712.6,0.6,
,713.63,1150,713.63,96.3,712.85,546,712.99,468,712.99,15,712.99,0,713.12,0xFF02,713.24,3,713.36,410,713.5,159,713.5,13.5,713.5,0.6,
,714.53,1219,714.53,96.3,713.75,564,713.87,468,713.87,18,713.87,0,714.02,0xFF02,714.14,3,714.26,410,714.39,159,714.39,13.5,714.39,0.6,
,715.42,1173,715.42,96.3,714.65,594,714.78,468,714.78,18,714.78,0,714.9,0xFF02,715.04,3,715.17,410,715.29,159,715.29,13.5,715.29,0.6,
,716.32,1035,716.32,96.3,715.56,612,715.68,468,715.68,18,715.68,0,715.81,0xFF02,715.93,3,716.08,410,716.2,159,716.2,13.5,716.2,0.3,
,717.23,989,717.23,96.3,716.45,606,716.59,468,716.59,13,716.59,0,716.71,0xFF02,716.84,3,716.96,410,717.1,159,717.1,13.5,717.1,0.3,
,718.13,1081,718.13,96.3,717.35,582,717.48,468,717.48,13,717.48,0,717.62,0xFF02,717.74,3,717.87,410,717.99,159,717.99,13.5,717.99,0.3,
,719.02,1150,719.02,96.3,718.26,552,718.38,468,718.38,15,718.38,0,718.51,0xFF02,718.65,3,718.78,410,718.9,159,718.9,13.2,718.9,0.3,
,719.93,1265,719.93,96.3,719.16,540,719.29,468,719.29,18,719.29,0,719.41,0xFF02,719.54,3,719.68,410,719.8,159,719.8,13.2,719.8,0.3,
,720.83,1357,720.83,96.3,720.05,534,720.19,468,720.19,21,720.19,0,720.32,0xFF02,720.44,3,720.57,410,720.71,159,720.71,13.2,720.71,0.3,
,721.75,1403,721.75,96.3,720.96,540,721.08,468,721.08,23,721.08,0,721.23,0xFF02,721.35,3,721.48,410,721.6,159,721.6,13.2,721.6,0.3,
,722.63,1334,722.63,96.3,721.86,558,722,468,722,23,722,0,722.11,0xFF02,722.26,3,722.38,410,722.51,159,722.51,13.2,722.51,0.3,
,723.54,1334,723.54,96.3,722.77,540,722.89,468,722.89,18,722.89,0,723.02,0xFF02,723.14,3,723.29,410,723.41,159,723.41,13.2,723.41,0.3,
,724.44,1472,724.44,96.3,723.66,504,723.8,468,723.8,23,723.8,0,723.92,0xFF02,724.06,3,724.17,410,724.31,159,724.31,13.2,724.31,0,
,725.34,1518,725.34,96.3,724.57,510,724.69,468,724.69,28,724.69,0,724.83,0xFF02,724.95,3,725.07,410,725.2,159,725.2,13.2,725.2,0,
,726.23,1518,726.23,96.3,725.47,564,725.6,468,725.6,26,725.6,0,725.71,0xFF02,725.85,3,725.98,410,726.1,159,726.1,13.2,726.1,0,
,727.13,1610,727.13,96.3,726.38,546,726.5,468,726.5,26,726.5,0,726.62,0xFF02,726.74,3,726.88,410,727.01,159,727.01,13.2,727.01,0,
,728.04,1725,728.04,96.3,727.26,534,727.4,468,727.4,31,727.4,0,727.52,0xFF02,727.65,3,727.77,410,727.91,159,727.91,13.2,727.91,0,
,728.94,1771,728.94,96.3,728.16,546,728.29,474,728.29,33,728.29,0,728.43,0xFF02,728.55,3,728.68,410,728.8,159,728.8,13.2,728.8,0,
,729.83,1817,729.83,96.3,729.07,570,729.19,474,729.19,33,729.19,0,729.32,0xFF02,729.46,3,729.58,410,729.71,159,729.71,13.2,729.71,0,
,730.74,1794,730.74,96.3,729.97,564,730.1,474,730.1,31,730.1,0,730.22,0xFF02,730.35,3,730.49,410,730.61,159,730.61,13.2,730.61,0,
,731.64,1794,731.64,96.3,730.86,516,731,474,731,28,731,0,731.13,0xFF02,731.25,3,731.38,410,731.52,159,731.52,13.2,731.52,0,
,732.55,1794,732.55,96.3,731.77,474,731.89,474,731.89,28,731.89,0,732.03,0xFF02,732.16,3,732.28,410,732.41,159,732.41,13.2,732.41,0,
,733.44,1771,733.44,96.3,732.67,456,732.8,474,732.8,28,732.8,0,732.92,0xFF02,733.06,3,733.19,410,733.31,159,733.31,13.2,733.31,0,
,734.34,1702,734.34,96.3,733.58,444,733.7,474,733.7,26,733.7,0,733.83,0xFF02,733.95,3,734.09,410,734.22,159,734.22,13.2,734.22,0,
,735.25,1702,735.25,96.3,734.47,396,734.61,474,734.61,26,734.61,0,734.73,0xFF02,734.85,3,734.99,410,735.12,159,735.12,13.2,735.12,0,
,736.15,1771,736.15,96.3,735.37,360,735.51,468,735.51,28,735.51,0,735.64,0xFF02,735.77,3,735.88,410,736.02,159,736.02,13.2,736.02,0,
,737.05,1886,737.05,96.3,736.29,360,736.4,468,736.4,38,736.4,0,736.54,0xFF02,736.67,3,736.8,410,736.91,159,736.91,13.2,736.91,0,
,737.94,1955,737.94,95.4,737.18,414,737.32,474,737.32,41,737.32,0,737.43,0xFF02,737.56,3,737.69,410,737.83,159,737.83,13.2,737.83,0,
,738.86,1311,738.86,95.4,738.08,468,738.21,474,738.21,41,738.21,0,738.34,0xFF02,738.46,3,738.58,410,738.72,159,738.72,13.2,738.72,0,
,739.75,1311,739.75,95.4,738.97,474,739.11,474,739.11,31,739.11,0,739.24,0xFF02,739.36,3,739.49,410,739.61,159,739.61,13.2,739.61,0,
,740.64,1265,740.64,95.4,739.89,462,740,474,740,21,740,0,740.13,0xFF02,740.27,3,740.39,410,740.52,159,740.52,13.2,740.52,0,
,741.55,1288,741.55,95.4,740.78,468,740.91,468,740.91,18,740.91,0,741.03,0xFF02,741.16,3,741.3,410,741.42,159,741.42,13.2,741.42,0,
,742.45,1265,742.45,95.4,741.67,450,741.81,468,741.81,15,741.81,0,741.94,0xFF02,742.06,3,742.19,410,742.33,159,742.33,13.2,742.33,0,
,743.36,1288,743.36,95.4,742.58,408,742.7,468,742.7,18,742.7,0,742.84,0xFF02,742.97,3,743.09,410,743.22,159,743.22,13.2,743.22,0,
,744.25,1334,744.25,94.5,743.48,384,743.61,468,743.61,21,743.61,0,743.73,0xFF02,743.87,3,744,410,744.12,159,744.12,13.2,744.12,0,
,745.15,1403,745.15,94.5,744.39,384,744.51,468,744.51,23,744.51,0,744.64,0xFF02,744.76,3,744.9,410,745.03,159,745.03,13.2,745.03,0,
,746.06,1426,746.06,94.5,745.28,426,745.42,468,745.42,26,745.42,0,745.54,0xFF02,745.67,3,745.79,410,745.93,159,745.93,13.2,745.93,0,
,746.96,1449,746.96,94.5,746.18,474,746.3,468,746.3,23,746.3,0,746.45,0xFF02,746.57,3,746.7,410,746.82,159,746.82,13.2,746.82,0,
,747.85,1426,747.85,94.5,747.09,492,747.21,468,747.21,23,747.21,0,747.33,0xFF02,747.49,3,747.6,410,747.72,159,747.72,12.9,747.72,0,
,748.76,1426,748.76,94.5,748,444,748.12,468,748.12,21,748.12,0,748.25,0xFF02,748.36,3,748.52,410,748.63,159,748.63,12.9,748.63,0,
,749.66,1426,749.66,94.5,748.88,414,749.03,462,749.03,21,749.03,0,749.15,0xFF02,749.28,3,749.4,410,749.54,159,749.54,12.9,749.54,0,
,750.57,1380,750.57,94.5,749.8,390,749.91,462,749.91,21,749.91,0,750.06,0xFF02,750.17,3,750.31,410,750.42,159,750.42,12.9,750.42,0,
,751.45,1334,751.45,94.5,750.69,354,750.82,462,750.82,18,750.82,0,750.94,0xFF02,751.08,3,751.21,410,751.34,159,751.34,12.9,751.34,0,
,752.37,1288,752.37,94.5,751.6,324,751.72,462,751.72,18,751.72,0,751.84,0xFF02,751.97,3,752.11,410,752.23,159,752.23,12.9,752.23,0,
,753.26,1265,753.26,93.6,752.48,300,752.62,462,752.62,18,752.62,0,752.75,0xFF02,752.87,3,753,410,753.14,159,753.14,12.9,753.14,0,
,754.17,1265,754.17,93.6,753.39,276,753.51,462,753.51,18,753.51,0,753.65,0xFF02,753.78,3,753.9,410,754.03,159,754.03,12.9,754.03,0,
,755.06,1265,755.06,93.6,754.29,264,754.42,462,754.42,18,754.42,0,754.54,0xFF02,754.68,3,754.81,410,754.93,159,754.93,12.9,754.93,0,
,755.96,1288,755.96,93.6,755.2,264,755.32,462,755.32,18,755.32,0,755.45,0xFF02,755.57,3,755.71,410,755.84,159,755.84,12.9,755.84,0,
,756.87,1311,756.87,93.6,756.09,282,756.23,462,756.23,18,756.23,0,756.35,0xFF02,756.48,3,756.6,410,756.74,159,756.74,12.9,756.74,0,
,757.77,1334,757.77,93.6,756.99,318,757.12,462,757.12,18,757.12,0,757.26,0xFF02,757.38,3,757.51,410,757.63,159,757.63,12.9,757.63,0,
,758.66,1334,758.66,93.6,757.9,354,758.02,462,758.02,18,758.02,0,758.15,0xFF02,758.29,3,758.41,410,758.54,159,758.54,12.9,758.54,0,
,759.57,1311,759.57,93.6,758.8,372,758.93,456,758.93,18,758.93,0,759.05,0xFF02,759.18,3,759.32,410,759.44,159,759.44,12.9,759.44,0,
,760.47,1311,760.47,93.6,759.69,342,759.83,456,759.83,18,759.83,0,759.96,0xFF02,760.08,3,760.21,410,760.35,159,760.35,12.9,760.35,0,
,761.38,1242,761.38,93.6,760.59,318,760.73,456,760.73,18,760.73,0,760.86,0xFF02,760.99,3,761.11,410,761.25,159,761.25,12.9,761.25,0,
,762.28,1219,762.28,93.6,761.51,306,761.62,456,761.62,18,761.62,0,761.76,0xFF02,761.89,3,762.03,410,762.14,159,762.14,12.9,762.14,0,
,763.17,1035,763.17,93.6,762.4,282,762.54,456,762.54,15,762.54,0,762.65,0xFF02,762.79,3,762.92,410,763.06,159,763.06,12.9,763.06,0,
,764.08,989,764.08,93.6,763.3,264,763.43,456,763.43,13,763.43,0,763.57,0xFF02,763.68,3,763.82,410,763.95,159,763.95,12.9,763.95,0,
,764.98,943,764.98,93.6,764.2,264,764.32,456,764.32,13,764.32,0,764.46,0xFF02,764.6,3,764.71,410,764.85,159,764.85,12.9,764.85,0,
,765.87,920,765.87,93.6,765.1,282,765.23,450,765.23,13,765.23,0,765.35,0xFF02,765.49,3,765.63,410,765.74,159,765.74,12.9,765.74,0,
,766.77,943,766.77,93.6,766.01,300,766.13,450,766.13,13,766.13,0,766.26,0xFF02,766.38,3,766.52,410,766.65,159,766.65,12.9,766.65,0,
,767.68,943,767.68,93.6,766.9,330,767.04,450,767.04,13,767.04,0,767.16,0xFF02,767.29,3,767.41,410,767.55,159,767.55,12.9,767.55,0,
,768.58,943,768.58,93.6,767.8,354,767.93,450,767.93,13,767.93,0,768.07,0xFF02,768.19,3,768.32,410,768.44,159,768.44,12.6,768.44,0,
,769.47,920,769.47,93.6,768.71,378,768.83,450,768.83,13,768.83,0,768.96,0xFF02,769.1,3,769.22,410,769.35,159,769.35,12.6,769.35,0,
,770.38,943,770.38,93.6,769.61,396,769.74,450,769.74,13,769.74,0,769.86,0xFF02,769.99,3,770.13,410,770.25,159,770.25,12.6,770.25,0,
,771.28,943,771.28,92.7,770.5,414,770.64,450,770.64,13,770.64,0,770.77,0xFF02,770.89,3,771.02,410,771.16,159,771.16,12.6,771.16,0,
,772.19,943,772.19,92.7,771.41,426,771.53,450,771.53,13,771.53,0,771.67,0xFF02,771.8,3,771.92,410,772.05,159,772.05,12.6,772.05,0,
,773.08,943,773.08,93.6,772.31,438,772.44,450,772.44,13,772.44,0,772.56,0xFF02,772.7,3,772.83,410,772.95,159,772.95,12.6,772.95,0,
,773.98,943,773.98,92.7,773.22,450,773.34,450,773.34,13,773.34,0,773.46,0xFF02,773.59,3,773.74,410,773.86,159,773.86,12.6,773.86,0,
,774.89,943,774.89,92.7,774.1,462,774.26,450,774.26,13,774.26,0,774.37,0xFF02,774.5,3,774.62,410,774.77,159,774.77,12.6,774.77,0,
,775.82,943,775.82,92.7,775.02,468,775.15,444,775.15,13,775.15,0,775.3,0xFF02,775.41,3,775.54,410,775.66,159,775.66,12.6,775.66,0,
,776.69,943,776.69,92.7,775.93,474,776.07,444,776.07,13,776.07,0,776.18,0xFF02,776.33,3,776.44,410,776.58,159,776.58,12.6,776.58,0,
,777.61,943,777.61,92.7,776.84,486,776.96,444,776.96,13,776.96,0,777.1,0xFF02,777.21,3,777.36,410,777.47,159,777.47,12.6,777.47,0,
,778.5,943,778.5,92.7,777.72,486,777.87,444,777.87,13,777.87,0,777.99,0xFF02,778.12,3,778.24,410,778.38,159,778.38,12.6,778.38,0,
,779.41,943,779.41,92.7,778.64,492,778.75,444,778.75,13,778.75,0,778.9,0xFF02,779.02,3,779.14,410,779.27,159,779.27,12.6,779.27,0,
,780.3,943,780.3,92.7,779.53,492,779.67,444,779.67,13,779.67,0,779.78,0xFF02,779.93,3,780.05,410,780.17,159,780.17,12.6,780.17,0,
,781.2,920,781.2,92.7,780.44,498,780.56,444,780.56,13,780.56,0,780.69,0xFF02,780.81,3,780.96,410,781.08,159,781.08,12.6,781.08,0,
,782.11,920,782.11,92.7,781.33,498,781.47,444,781.47,13,781.47,0,781.59,0xFF02,781.72,3,781.84,410,781.98,159,781.98,12.6,781.98,0,
,783.01,943,783.01,92.7,782.23,504,782.36,444,782.36,13,782.36,0,782.5,0xFF02,782.62,3,782.75,410,782.87,159,782.87,12.6,782.87,0,
,783.9,943,783.9,92.7,783.14,504,783.26,444,783.26,13,783.26,0,783.39,0xFF02,783.53,3,783.65,410,783.78,159,783.78,12.6,783.78,0,
,784.81,943,784.81,92.7,784.04,510,784.17,444,784.17,13,784.17,0,784.29,0xFF02,784.42,3,784.56,410,784.68,159,784.68,12.6,784.68,0,
,785.71,943,785.71,92.7,784.93,516,785.07,444,785.07,13,785.07,0,785.2,0xFF02,785.32,3,785.45,410,785.59,159,785.59,12.6,785.59,0,
,786.62,943,786.62,93.6,785.84,516,785.96,444,785.96,13,785.96,0,786.1,0xFF02,786.23,3,786.35,410,786.48,159,786.48,12.6,786.48,0,
,787.51,943,787.51,93.6,786.74,516,786.86,444,786.86,13,786.86,0,786.99,0xFF02,787.13,3,787.25,410,787.38,159,787.38,12.6,787.38,0,
,788.41,943,788.41,93.6,787.65,522,787.77,444,787.77,13,787.77,0,787.89,0xFF02,788.02,3,788.16,410,788.28,159,788.28,12.6,788.28,0,
,789.32,943,789.32,93.6,788.55,522,788.68,444,788.68,13,788.68,0,788.8,0xFF02,788.92,3,789.06,410,789.19,159,789.19,12.6,789.19,0,
,790.22,943,790.22,93.6,789.44,522,789.58,444,789.58,13,789.58,0,789.71,0xFF02,789.84,3,789.95,410,790.09,159,790.09,12.6,790.09,0,
,791.12,943,791.12,93.6,790.36,522,790.47,444,790.47,13,790.47,0,790.6,0xFF02,790.74,3,790.87,410,790.98,159,790.98,12.6,790.98,0,
,792.01,943,792.01,93.6,791.25,522,791.38,444,791.38,13,791.38,0,791.5,0xFF02,791.62,3,791.76,410,791.9,159,791.9,12.6,791.9,0,
,792.93,943,792.93,93.6,792.15,522,792.28,444,792.28,13,792.28,0,792.4,0xFF02,792.53,3,792.65,410,792.79,159,792.79,12.6,792.79,0,
,793.82,943,793.82,93.6,793.04,522,793.17,444,793.17,13,793.17,0,793.31,0xFF02,793.43,3,793.56,410,793.68,159,793.68,12.6,793.68,0,
,794.71,943,794.71,93.6,793.96,522,794.07,444,794.07,13,794.07,0,794.2,0xFF02,794.34,3,794.46,410,794.59,159,794.59,12.6,794.59,0,
,795.62,943,795.62,93.6,794.85,522,794.98,444,794.98,13,794.98,0,795.1,0xFF02,795.23,3,795.37,410,795.49,159,795.49,12.6,795.49,0,
,796.52,943,796.52,93.6,795.74,522,795.88,444,795.88,13,795.88,0,796.01,0xFF02,796.13,3,796.26,410,796.4,159,796.4,12.6,796.4,0,
,797.43,943,797.43,93.6,796.65,528,796.77,444,796.77,13,796.77,0,796.91,0xFF02,797.04,3,797.16,410,797.29,159,797.29,12.6,797.29,0,
,798.32,943,798.32,93.6,797.55,528,797.68,444,797.68,13,797.68,0,797.8,0xFF02,797.94,3,798.07,410,798.19,159,798.19,12.6,798.19,0,
,799.22,943,799.22,93.6,798.46,528,798.58,444,798.58,13,798.58,0,798.71,0xFF02,798.83,3,798.97,410,799.1,159,799.1,12.6,799.1,0,
,800.12,943,800.12,93.6,799.35,534,799.49,444,799.49,13,799.49,0,799.61,0xFF02,799.74,3,799.86,410,800,159,800,12.6,800,0,
,801.03,943,801.03,93.6,800.25,534,800.37,444,800.37,13,800.37,0,800.52,0xFF02,800.64,3,800.77,410,800.89,159,800.89,12.6,800.89,0,
,801.92,943,801.92,93.6,801.15,534,801.28,444,801.28,13,801.28,0,801.41,0xFF02,801.56,3,801.67,410,801.8,159,801.8,12.6,801.8,0,
,802.84,943,802.84,93.6,802.07,534,802.18,444,802.18,13,802.18,0,802.32,0xFF02,802.45,3,802.59,410,802.72,159,802.72,12.6,802.72,0,
,803.74,943,803.74,93.6,802.96,534,803.12,444,803.12,13,803.12,0,803.23,0xFF02,803.36,3,803.48,410,803.63,159,803.63,12.6,803.63,0,
,804.66,943,804.66,93.6,803.88,534,803.99,444,803.99,13,803.99,0,804.15,0xFF02,804.26,3,804.4,410,804.51,159,804.51,12.6,804.51,0,
,805.54,943,805.54,93.6,804.77,534,804.91,444,804.91,13,804.91,0,805.02,0xFF02,805.17,3,805.29,410,805.42,159,805.42,12.6,805.42,0,
,806.45,943,806.45,94.5,805.69,534,805.8,444,805.8,13,805.8,0,805.94,0xFF02,806.05,3,806.2,410,806.32,159,806.32,12.6,806.32,0,
,807.35,943,807.35,94.5,806.57,534,806.71,444,806.71,13,806.71,0,806.83,0xFF02,806.96,3,807.08,410,807.23,159,807.23,12.6,807.23,0,
,808.25,943,808.25,94.5,807.47,534,807.6,444,807.6,13,807.6,0,807.74,0xFF02,807.86,3,808,410,808.11,159,808.11,12.6,808.11,0,
,809.14,943,809.14,94.5,808.38,534,808.5,444,808.5,13,808.5,0,808.63,0xFF02,808.77,3,808.89,410,809.02,159,809.02,12.6,809.02,0,
,810.05,943,810.05,94.5,809.28,534,809.41,444,809.41,13,809.41,0,809.53,0xFF02,809.66,3,809.8,410,809.92,159,809.92,12.6,809.92,0,
,810.95,943,810.95,94.5,810.17,534,810.31,444,810.31,13,810.31,0,810.44,0xFF02,810.56,3,810.69,410,810.83,159,810.83,12.6,810.83,0,
,811.86,943,811.86,94.5,811.08,540,811.2,444,811.2,13,811.2,0,811.34,0xFF02,811.47,3,811.59,410,811.72,159,811.72,12.6,811.72,0,
,812.75,943,812.75,94.5,811.98,540,812.11,450,812.11,13,812.11,0,812.23,0xFF02,812.37,3,812.5,410,812.62,159,812.62,12.6,812.62,0,
,813.65,943,813.65,94.5,812.89,540,813.01,450,813.01,13,813.01,0,813.14,0xFF02,813.26,3,813.4,410,813.53,159,813.53,12.6,813.53,0,
,814.55,943,814.55,94.5,813.78,540,813.92,450,813.92,13,813.92,0,814.04,0xFF02,814.16,3,814.29,410,814.43,159,814.43,12.6,814.43,0,
,815.46,943,815.46,94.5,814.68,540,814.8,450,814.8,13,814.8,0,814.95,0xFF02,815.07,3,815.19,410,815.32,159,815.32,12.6,815.32,0,
,816.36,943,816.36,94.5,815.59,540,815.71,450,815.71,13,815.71,0,815.83,0xFF02,815.97,3,816.1,410,816.22,159,816.22,12.6,816.22,0,
,817.27,943,817.27,94.5,816.51,546,816.63,450,816.63,13,816.63,0,816.75,0xFF02,816.88,3,817.02,410,817.14,159,817.14,12.6,817.14,0,
,818.17,943,818.17,94.5,817.4,546,817.54,450,817.54,13,817.54,0,817.66,0xFF02,817.78,3,817.92,410,818.05,159,818.05,12.6,818.05,0,
,819.1,943,819.1,94.5,818.3,540,818.44,450,818.44,13,818.44,0,818.57,0xFF02,818.7,3,818.83,410,818.95,159,818.95,12.6,818.95,0,
,820,966,820,94.5,819.22,540,819.35,450,819.35,13,819.35,0,819.48,0xFF02,819.63,3,819.75,410,819.88,159,819.88,12.6,819.88,0,
,820.91,943,820.91,94.5,820.14,540,820.26,450,820.26,13,820.26,0,820.39,0xFF02,820.51,3,820.66,410,820.78,159,820.78,12.6,820.78,0,
,821.81,943,821.81,94.5,821.04,546,821.17,450,821.17,13,821.17,0,821.29,0xFF02,821.42,3,821.55,410,821.69,159,821.69,12.6,821.69,0,
,822.72,943,822.72,94.5,821.94,540,822.07,450,822.07,13,822.07,0,822.2,0xFF02,822.33,3,822.45,410,822.58,159,822.58,12.6,822.58,0,
,823.63,943,823.63,94.5,822.85,540,822.98,450,822.98,13,822.98,0,823.11,0xFF02,823.24,3,823.38,410,823.49,159,823.49,12.6,823.49,0,
,824.54,943,824.54,94.5,823.78,534,823.9,450,823.9,13,823.9,0,824.02,0xFF02,824.16,3,824.29,410,824.41,159,824.41,12.6,824.41,0,
,825.46,943,825.46,95.4,824.68,534,824.81,450,824.81,13,824.81,0,824.94,0xFF02,825.05,3,825.19,410,825.34,159,825.34,12.6,825.34,0,
,826.37,943,826.37,94.5,825.58,534,825.71,450,825.71,13,825.71,0,825.85,0xFF02,825.97,3,826.1,410,826.23,159,826.23,12.6,826.23,0,
,827.27,943,827.27,95.4,826.49,534,826.62,450,826.62,13,826.62,0,826.75,0xFF02,826.89,3,827.02,410,827.14,159,827.14,12.6,827.14,0,
,828.17,1196,828.17,95.4,827.41,534,827.54,450,827.54,13,827.54,0,827.66,0xFF02,827.8,3,827.92,410,828.05,159,828.05,12.6,828.05,0,
,829.09,1656,829.09,95.4,828.31,534,828.46,450,828.46,21,828.46,0,828.58,0xFF02,828.71,3,828.83,410,828.97,159,828.97,12.6,828.97,0,
,830.01,1748,830.01,95.4,829.22,552,829.35,456,829.35,36,829.35,0,829.48,0xFF02,829.61,3,829.73,410,829.87,159,829.87,12.6,829.87,0,
,830.91,1196,830.91,95.4,830.14,618,830.26,462,830.26,41,830.26,0,830.39,0xFF02,830.53,3,830.65,410,830.78,159,830.78,12.3,830.78,0,
,831.83,1127,831.83,95.4,831.04,666,831.17,468,831.17,26,831.17,0,831.29,0xFF02,831.43,3,831.58,410,831.7,159,831.7,12.3,831.7,0,
,832.73,1081,832.73,95.4,831.95,612,832.09,474,832.09,18,832.09,0,832.21,0xFF02,832.34,3,832.48,410,832.6,159,832.6,12.3,832.6,0,
,833.65,943,833.65,95.4,832.86,564,832.99,468,832.99,15,832.99,0,833.13,0xFF02,833.26,3,833.38,410,833.51,159,833.51,12.3,833.51,0,
,834.55,989,834.55,95.4,833.77,534,833.9,468,833.9,13,833.9,0,834.03,0xFF02,834.16,3,834.29,410,834.41,159,834.41,12.3,834.41,0,
,835.46,966,835.46,95.4,834.7,504,834.82,468,834.82,13,834.82,0,834.95,0xFF02,835.07,3,835.21,410,835.33,159,835.33,12.3,835.33,0,
,836.37,897,836.37,95.4,835.6,468,835.73,468,835.73,10,835.73,0,835.85,0xFF02,835.97,3,836.11,410,836.24,159,836.24,12.3,836.24,0,
,837.28,943,837.28,95.4,836.49,438,836.62,468,836.62,10,836.62,0,836.76,0xFF02,836.89,3,837.02,410,837.15,159,837.15,12.3,837.15,0,
,838.19,943,838.19,95.4,837.41,432,837.53,468,837.53,13,837.53,0,837.67,0xFF02,837.82,3,837.94,410,838.06,159,838.06,12.3,838.06,0,
,839.09,1058,839.09,95.4,838.33,432,838.45,468,838.45,13,838.45,0,838.58,0xFF02,838.72,3,838.85,410,838.97,159,838.97,12.3,838.97,0,
,840.01,966,840.01,95.4,839.23,444,839.38,468,839.38,13,839.38,0,839.5,0xFF02,839.63,3,839.75,410,839.89,159,839.89,12.3,839.89,0,
,840.93,1150,840.93,95.4,840.14,450,840.27,468,840.27,13,840.27,0,840.4,0xFF02,840.53,3,840.66,410,840.79,159,840.79,12.3,840.79,0,
,841.84,1334,841.84,95.4,841.06,468,841.18,468,841.18,15,841.18,0,841.31,0xFF02,841.45,3,841.57,410,841.7,159,841.7,12.3,841.7,0,
,842.74,1564,842.74,95.4,841.96,474,842.09,468,842.09,31,842.09,0,842.22,0xFF02,842.35,3,842.5,410,842.62,159,842.62,12.3,842.62,0,
,843.65,1564,843.65,95.4,842.87,528,843.01,474,843.01,31,843.01,0,843.13,0xFF02,843.26,3,843.4,410,843.53,159,843.53,12.3,843.53,0,
,844.56,1633,844.56,95.4,843.77,552,843.91,480,843.91,28,843.91,0,844.04,0xFF02,844.17,3,844.29,410,844.43,159,844.43,12.3,844.43,0,
,845.45,1656,845.45,95.4,844.69,546,844.8,486,844.8,28,844.8,0,844.94,0xFF02,845.07,3,845.2,410,845.32,159,845.32,12.3,845.32,0,
,846.35,1771,846.35,95.4,845.59,552,845.72,486,845.72,28,845.72,0,845.83,0xFF02,845.96,3,846.1,410,846.23,159,846.23,12.3,846.23,0,
,847.25,1955,847.25,95.4,846.47,552,846.62,486,846.62,41,846.62,0,846.74,0xFF02,846.86,3,847,410,847.13,159,847.13,12.3,847.13,0,
,848.16,2001,848.16,95.4,847.38,618,847.5,492,847.5,51,847.5,0,847.64,0xFF02,847.77,3,847.89,410,848.02,159,848.02,12.3,848.02,0,
,849.05,1380,849.05,95.4,848.28,696,848.41,498,848.41,51,848.41,0,848.53,0xFF02,848.68,3,848.79,410,848.92,159,848.92,12.3,848.92,0,
,849.95,1449,849.95,95.4,849.19,666,849.31,504,849.31,26,849.31,0,849.44,0xFF02,849.56,3,849.7,410,849.82,159,849.82,12.3,849.82,0,
,850.86,1518,850.86,95.4,850.08,624,850.22,504,850.22,26,850.22,0,850.34,0xFF02,850.47,3,850.59,410,850.73,159,850.73,12.3,850.73,0,
,851.76,1518,851.76,95.4,850.98,618,851.11,504,851.11,33,851.11,0,851.25,0xFF02,851.37,3,851.5,410,851.62,159,851.62,12.3,851.62,0,
,852.65,1564,852.65,95.4,851.89,618,852.01,504,852.01,26,852.01,0,852.14,0xFF02,852.28,3,852.4,410,852.53,159,852.53,12.3,852.53,0,
,853.56,1564,853.56,95.4,852.79,528,852.92,504,852.92,26,852.92,0,853.04,0xFF02,853.16,3,853.31,410,853.43,159,853.43,12,853.43,0,
,854.46,1587,854.46,94.5,853.68,516,853.82,504,853.82,26,853.82,0,853.94,0xFF02,854.07,3,854.19,410,854.33,159,854.33,12,854.33,0,
,855.37,1518,855.37,94.5,854.59,462,854.71,504,854.71,21,854.71,0,854.85,0xFF02,854.97,3,855.1,410,855.22,159,855.22,12,855.22,0,
,856.25,1449,856.25,94.5,855.49,396,855.62,504,855.62,21,855.62,0,855.74,0xFF02,855.89,3,856,410,856.13,159,856.13,12,856.13,0,
,857.17,1403,857.17,94.5,856.41,354,856.52,504,856.52,18,856.52,0,856.65,0xFF02,856.77,3,856.92,410,857.03,159,857.03,12,857.03,0,
,858.08,1311,858.08,94.5,857.3,318,857.44,504,857.44,18,857.44,0,857.56,0xFF02,857.69,3,857.81,410,857.96,159,857.96,12,857.96,0,
,859,1219,859,94.5,858.2,294,858.33,504,858.33,18,858.33,0,858.48,0xFF02,858.61,3,858.73,410,858.86,159,858.86,12,858.86,0,
,859.89,1196,859.89,94.5,859.12,270,859.25,498,859.25,15,859.25,0,859.38,0xFF02,859.53,3,859.64,410,859.76,159,859.76,12,859.76,0,
,860.81,1173,860.81,94.5,860.04,252,860.16,498,860.16,15,860.16,0,860.29,0xFF02,860.42,3,860.56,410,860.68,159,860.68,12,860.68,0,
,861.73,1104,861.73,94.5,860.93,246,861.08,498,861.08,15,861.08,0,861.2,0xFF02,861.33,3,861.45,410,861.6,159,861.6,12,861.6,0,
,862.65,966,862.65,94.5,861.85,234,861.98,498,861.98,13,861.98,0,862.12,0xFF02,862.24,3,862.37,410,862.5,159,862.5,12,862.5,0,
,863.54,943,863.54,94.5,862.76,228,862.88,492,862.88,13,862.88,0,863.01,0xFF02,863.16,3,863.27,410,863.41,159,863.41,12,863.41,0,
,864.44,943,864.44,94.5,863.68,222,863.8,492,863.8,13,863.8,0,863.93,0xFF02,864.05,3,864.21,410,864.32,159,864.32,12,864.32,0,
,865.36,1196,865.36,94.5,864.57,234,864.72,492,864.72,13,864.72,0,864.85,0xFF02,864.97,3,865.1,410,865.24,159,865.24,12,865.24,0,
,866.28,1541,866.28,94.5,865.49,246,865.61,492,865.61,18,865.61,0,865.77,0xFF02,865.88,3,866,410,866.13,159,866.13,12,866.13,0,
,867.17,1725,867.17,94.5,866.4,282,866.53,492,866.53,31,866.53,0,866.66,0xFF02,866.8,3,866.92,410,867.05,159,867.05,11.7,867.05,0,
,868.09,1955,868.09,94.5,867.32,378,867.44,492,867.44,41,867.44,0,867.57,0xFF02,867.69,3,867.84,410,867.97,159,867.97,11.7,867.97,0,
,869,2001,869,94.5,868.22,456,868.36,498,868.36,56,868.36,0,868.48,0xFF02,868.61,3,868.73,410,868.88,159,868.88,11.7,868.88,0,
,869.92,1587,869.92,93.6,869.12,546,869.25,504,869.25,67,869.25,0,869.4,0xFF02,869.53,3,869.66,410,869.78,159,869.78,11.7,869.78,0,
,870.81,1725,870.81,93.6,870.04,588,870.17,504,870.17,59,870.17,0,870.29,0xFF02,870.44,3,870.56,410,870.69,159,870.69,11.7,870.69,0,
,871.73,1863,871.73,93.6,870.96,606,871.07,510,871.07,54,871.07,0,871.21,0xFF02,871.34,3,871.48,410,871.61,159,871.61,11.7,871.61,0,
,872.65,1932,872.65,93.6,871.85,636,872,510,872,49,872,0,872.12,0xFF02,872.24,3,872.37,410,872.52,159,872.52,11.7,872.52,0,
,873.57,2093,873.57,93.6,872.77,648,872.9,516,872.9,51,872.9,0,873.04,0xFF02,873.16,3,873.29,410,873.41,159,873.41,11.7,873.41,0,
,874.46,2208,874.46,93.6,873.68,654,873.8,516,873.8,74,873.8,0,873.93,0xFF02,874.08,3,874.19,410,874.33,159,874.33,11.7,874.33,0,
,875.36,2277,875.36,93.6,874.6,666,874.72,516,874.72,74,874.72,0,874.85,0xFF02,874.97,3,875.12,410,875.24,159,875.24,11.7,875.24,0,
,876.28,2208,876.28,93.6,875.49,618,875.64,516,875.64,54,875.64,0,875.77,0xFF02,875.89,3,876.02,410,876.16,159,876.16,11.7,876.16,0,
,877.2,2208,877.2,93.6,876.41,552,876.54,516,876.54,41,876.54,0,876.68,0xFF02,876.8,3,876.92,410,877.05,159,877.05,11.7,877.05,0,
,878.09,2139,878.09,93.6,877.31,456,877.45,516,877.45,36,877.45,0,877.58,0xFF02,877.72,3,877.85,410,877.97,159,877.97,11.7,877.97,0,
,879.01,2070,879.01,93.6,878.24,384,878.36,516,878.36,36,878.36,0,878.49,0xFF02,878.61,3,878.76,410,878.89,159,878.89,11.4,878.89,0,
,879.92,1978,879.92,93.6,879.14,324,879.28,516,879.28,33,879.28,0,879.4,0xFF02,879.53,3,879.65,410,879.8,159,879.8,11.4,879.8,0,
,880.84,1863,880.84,93.6,880.04,282,880.17,516,880.17,31,880.17,0,880.32,0xFF02,880.43,3,880.57,410,880.7,159,880.7,11.4,880.7,0,
,881.73,1771,881.73,93.6,880.97,258,881.09,516,881.09,28,881.09,0,881.21,0xFF02,881.36,3,881.48,410,881.6,159,881.6,11.4,881.6,0,
,882.65,1679,882.65,93.6,881.88,240,882.01,510,882.01,26,882.01,0,882.13,0xFF02,882.26,3,882.4,410,882.52,159,882.52,11.4,882.52,0,
,883.55,1587,883.55,93.6,882.77,222,882.93,510,882.93,23,882.93,0,883.04,0xFF02,883.16,3,883.29,410,883.44,159,883.44,11.4,883.44,0,
,884.48,1334,884.48,93.6,883.69,210,883.82,504,883.82,23,883.82,0,883.96,0xFF02,884.08,3,884.21,410,884.33,159,884.33,11.4,884.33,0,
,885.38,1012,885.38,92.7,884.6,210,884.72,504,884.72,18,884.72,0,884.85,0xFF02,885,3,885.11,410,885.25,159,885.25,11.4,885.25,0,
,886.28,989,886.28,92.7,885.52,204,885.65,504,885.65,15,885.65,0,885.77,0xFF02,885.89,3,886.04,410,886.16,159,886.16,11.4,886.16,0,
,887.2,966,887.2,92.7,886.41,222,886.56,504,886.56,13,886.56,0,886.69,0xFF02,886.82,3,886.94,410,887.08,159,887.08,11.4,887.08,0,
,888.12,920,888.12,92.7,887.33,264,887.45,504,887.45,13,887.45,0,887.6,0xFF02,887.72,3,887.84,410,887.97,159,887.97,11.4,887.97,0,
,889.01,943,889.01,92.7,888.23,312,888.36,498,888.36,13,888.36,0,888.48,0xFF02,888.64,3,888.77,410,888.89,159,888.89,11.4,888.89,0,
,889.94,943,889.94,92.7,889.15,348,889.28,498,889.28,10,889.28,0,889.4,0xFF02,889.53,3,889.68,410,889.81,159,889.81,11.1,889.81,0,
,890.84,943,890.84,92.7,890.06,378,890.2,492,890.2,13,890.2,0,890.32,0xFF02,890.45,3,890.57,410,890.72,159,890.72,11.1,890.72,0,
,891.76,920,891.76,92.7,890.96,402,891.09,492,891.09,13,891.09,0,891.24,0xFF02,891.35,3,891.48,410,891.6,159,891.6,11.1,891.6,0,
,892.65,943,892.65,91.8,891.88,420,892.01,492,892.01,13,892.01,0,892.13,0xFF02,892.27,3,892.4,410,892.52,159,892.52,11.1,892.52,0,
,893.57,943,893.57,91.8,892.8,444,892.93,492,892.93,13,892.93,0,893.05,0xFF02,893.18,3,893.32,410,893.44,159,893.44,11.1,893.44,0,
,894.47,1288,894.47,91.8,893.69,462,893.83,492,893.83,10,893.83,0,893.96,0xFF02,894.08,3,894.21,410,894.35,159,894.35,11.1,894.35,0,
,895.39,1495,895.39,91.8,894.6,474,894.72,492,894.72,23,894.72,0,894.88,0xFF02,895,3,895.13,410,895.25,159,895.25,11.1,895.25,0,
,896.3,1587,896.3,91.8,895.52,522,895.64,492,895.64,31,895.64,0,895.77,0xFF02,895.92,3,896.05,410,896.17,159,896.17,11.1,896.17,0,
,897.2,1794,897.2,91.8,896.44,600,896.56,492,896.56,41,896.56,0,896.69,0xFF02,896.81,3,896.95,410,897.08,159,897.08,11.1,897.08,0,
,898.12,989,898.12,91.8,897.33,648,897.48,498,897.48,46,897.48,0,897.61,0xFF02,897.74,3,897.86,410,898,159,898,11.1,898,0,
,899.04,920,899.04,91.8,898.25,642,898.37,504,898.37,23,898.37,0,898.51,0xFF02,898.64,3,898.76,410,898.89,159,898.89,11.1,898.89,0,
,899.92,920,899.92,91.8,899.15,576,899.28,504,899.28,13,899.28,0,899.4,0xFF02,899.55,3,899.67,410,899.8,159,899.8,11.1,899.8,0,
,900.85,966,900.85,91.8,900.07,546,900.18,498,900.18,13,900.18,0,900.32,0xFF02,900.45,3,900.6,410,900.73,159,900.73,11.1,900.73,0,
,901.76,1886,901.76,91.8,900.98,534,901.12,498,901.12,18,901.12,0,901.24,0xFF02,901.37,3,901.49,410,901.63,159,901.63,11.1,901.63,0,
,902.68,2208,902.68,91.8,901.88,534,902.01,498,902.01,51,902.01,0,902.16,0xFF02,902.27,3,902.4,410,902.52,159,902.52,11.1,902.52,0,
,903.57,2277,903.57,91.8,902.79,582,902.93,504,902.93,74,902.93,0,903.04,0xFF02,903.19,3,903.32,410,903.44,159,903.44,11.1,903.44,0,
,904.49,1587,904.49,92.7,903.72,648,903.85,510,903.85,69,903.85,0,903.98,0xFF02,904.1,3,904.24,410,904.36,159,904.36,11.1,904.36,0,
,905.41,1702,905.41,91.8,904.61,630,904.76,516,904.76,46,904.76,0,904.88,0xFF02,905,3,905.13,410,905.28,159,905.28,11.1,905.28,0,
,906.31,1702,906.31,92.7,905.53,624,905.66,516,905.66,44,905.66,0,905.8,0xFF02,905.93,3,906.05,410,906.17,159,906.17,11.1,906.17,0,
,907.22,1587,907.22,92.7,906.44,624,906.56,516,906.56,33,906.56,0,906.69,0xFF02,906.84,3,906.97,410,907.09,159,907.09,10.8,907.09,0,
,908.12,1403,908.12,92.7,907.36,558,907.48,516,907.48,23,907.48,0,907.61,0xFF02,907.73,3,907.87,410,908,159,908,10.8,908,0,
,909.03,1196,909.03,92.7,908.25,486,908.4,516,908.4,18,908.4,0,908.51,0xFF02,908.64,3,908.76,410,908.91,159,908.91,10.8,908.91,0,
,909.96,989,909.96,92.7,909.16,426,909.28,516,909.28,15,909.28,0,909.43,0xFF02,909.54,3,909.68,410,909.81,159,909.81,10.8,909.81,0,
,910.85,1012,910.85,92.7,910.09,384,910.21,516,910.21,15,910.21,0,910.34,0xFF02,910.48,3,910.6,410,910.73,159,910.73,10.8,910.73,0,
,911.76,1150,911.76,92.7,911,384,911.12,516,911.12,15,911.12,0,911.24,0xFF02,911.37,3,911.52,410,911.63,159,911.63,10.8,911.63,0,
,912.68,1196,912.68,92.7,911.88,390,912.04,510,912.04,18,912.04,0,912.16,0xFF02,912.29,3,912.41,410,912.55,159,912.55,10.8,912.55,0,
,913.6,1242,913.6,92.7,912.8,420,912.93,510,912.93,18,912.93,0,913.08,0xFF02,913.21,3,913.33,410,913.46,159,913.46,10.8,913.46,0,
,914.49,1334,914.49,92.7,913.72,450,913.85,510,913.85,21,913.85,0,913.97,0xFF02,914.12,3,914.24,410,914.36,159,914.36,10.8,914.36,0,
,915.41,1403,915.41,92.7,914.64,474,914.77,510,914.77,26,914.77,0,914.89,0xFF02,915.02,3,915.16,410,915.28,159,915.28,10.8,915.28,0,
,916.31,1449,916.31,92.7,915.53,534,915.67,510,915.67,31,915.67,0,915.8,0xFF02,915.92,3,916.05,410,916.2,159,916.2,10.8,916.2,0,
,917.23,1449,917.23,92.7,916.44,618,916.56,516,916.56,33,916.56,0,916.71,0xFF02,916.83,3,916.96,410,917.08,159,917.08,10.8,917.08,0,
,918.14,1449,918.14,92.7,917.36,666,917.48,516,917.48,33,917.48,0,917.61,0xFF02,917.76,3,917.89,410,918.01,159,918.01,10.8,918.01,0,
,919.04,1426,919.04,92.7,918.28,666,918.4,516,918.4,33,918.4,0,918.53,0xFF02,918.65,3,918.8,410,918.92,159,918.92,10.8,918.92,0,
,919.95,1380,919.95,92.7,919.17,630,919.31,522,919.31,26,919.31,0,919.43,0xFF02,919.56,3,919.68,410,919.84,159,919.84,10.8,919.84,0,
,920.87,1334,920.87,92.7,920.07,594,920.2,522,920.2,23,920.2,0,920.35,0xFF02,920.48,3,920.6,410,920.73,159,920.73,10.5,920.73,0,
,921.76,1219,921.76,92.7,920.99,582,921.12,522,921.12,23,921.12,0,921.24,0xFF02,921.39,3,921.51,410,921.63,159,921.63,10.5,921.63,0,
,922.68,1150,922.68,93.6,921.91,558,922.04,522,922.04,18,922.04,0,922.16,0xFF02,922.29,3,922.43,410,922.55,159,922.55,10.5,922.55,0,
,923.58,1104,923.58,92.7,922.8,540,922.96,522,922.96,18,922.96,0,923.07,0xFF02,923.19,3,923.32,410,923.47,159,923.47,10.5,923.47,0,
,924.51,1104,924.51,93.6,923.72,534,923.85,516,923.85,18,923.85,0,923.99,0xFF02,924.11,3,924.24,410,924.36,159,924.36,10.5,924.36,0,
,925.41,1196,925.41,93.6,924.63,534,924.75,516,924.75,18,924.75,0,924.88,0xFF02,925.03,3,925.16,410,925.28,159,925.28,10.5,925.28,0,
,926.31,1311,926.31,93.6,925.55,546,925.67,516,925.67,21,925.67,0,925.8,0xFF02,925.92,3,926.07,410,926.19,159,926.19,10.5,926.19,0,
,927.23,1288,927.23,93.6,926.44,552,926.59,516,926.59,26,926.59,0,926.72,0xFF02,926.84,3,926.97,410,927.11,159,927.11,10.5,927.11,0,
,928.15,1196,928.15,93.6,927.36,576,927.48,516,927.48,21,927.48,0,927.63,0xFF02,927.75,3,927.87,410,928,159,928,10.5,928,0,
,929.04,1173,929.04,93.6,928.28,570,928.4,516,928.4,18,928.4,0,928.53,0xFF02,928.67,3,928.79,410,928.92,159,928.92,10.5,928.92,0,
,929.96,1242,929.96,93.6,929.2,558,929.31,516,929.31,18,929.31,0,929.43,0xFF02,929.56,3,929.71,410,929.84,159,929.84,10.5,929.84,0,
,930.87,1380,930.87,93.6,930.09,558,930.23,516,930.23,23,930.23,0,930.35,0xFF02,930.48,3,930.6,410,930.75,159,930.75,10.5,930.75,0,
,931.79,1449,931.79,93.6,930.99,564,931.12,516,931.12,31,931.12,0,931.27,0xFF02,931.38,3,931.52,410,931.65,159,931.65,10.5,931.65,0,
,932.68,1472,932.68,93.6,931.91,612,932.04,522,932.04,36,932.04,0,932.16,0xFF02,932.31,3,932.43,410,932.55,159,932.55,10.5,932.55,0,
,933.6,1472,933.6,93.6,932.83,654,932.96,522,932.96,38,932.96,0,933.08,0xFF02,933.21,3,933.35,410,933.47,159,933.47,10.5,933.47,0,
,934.52,1380,934.52,93.6,933.72,654,933.88,522,933.88,31,933.88,0,933.99,0xFF02,934.11,3,934.24,410,934.39,159,934.39,10.5,934.39,0,
,935.43,1380,935.43,93.6,934.64,606,934.77,522,934.77,23,934.77,0,934.91,0xFF02,935.03,3,935.16,410,935.28,159,935.28,10.2,935.28,0,
,936.33,1357,936.33,93.6,935.55,582,935.67,522,935.67,21,935.67,0,935.8,0xFF02,935.95,3,936.08,410,936.2,159,936.2,10.2,936.2,0,
,937.23,1173,937.23,93.6,936.47,564,936.59,522,936.59,21,936.59,0,936.72,0xFF02,936.84,3,937,410,937.11,159,937.11,10.2,937.11,0,
,938.15,1288,938.15,93.6,937.36,552,937.51,522,937.51,18,937.51,0,937.64,0xFF02,937.76,3,937.89,410,938.03,159,938.03,10.2,938.03,0,
,939.07,1104,939.07,94.5,938.28,546,938.4,522,938.4,21,938.4,0,938.55,0xFF02,938.67,3,938.79,410,938.92,159,938.92,10.2,938.92,0,
,939.96,943,939.96,94.5,939.2,546,939.32,522,939.32,18,939.32,0,939.45,0xFF02,939.59,3,939.71,410,939.84,159,939.84,10.2,939.84,0,
,940.86,943,940.86,94.5,940.11,540,940.23,522,940.23,13,940.23,0,940.35,0xFF02,940.47,3,940.59,410,940.73,159,940.73,10.2,940.73,0,
,941.76,943,941.76,94.5,940.98,534,941.11,522,941.11,13,941.11,0,941.24,0xFF02,941.38,3,941.49,410,941.62,159,941.62,10.2,941.62,0,
,942.65,920,942.65,94.5,941.89,528,942.01,516,942.01,13,942.01,0,942.13,0xFF02,942.27,3,942.4,410,942.52,159,942.52,10.2,942.52,0,
,943.55,851,943.55,94.5,942.79,528,942.91,516,942.91,13,942.91,0,943.04,0xFF02,943.16,3,943.3,410,943.43,159,943.43,10.2,943.43,0,
,944.45,897,944.45,94.5,943.67,522,943.82,516,943.82,13,943.82,0,943.94,0xFF02,944.06,3,944.19,410,944.33,159,944.33,10.2,944.33,0,
,945.36,1150,945.36,94.5,944.58,528,944.7,516,944.7,13,944.7,0,944.85,0xFF02,944.97,3,945.09,410,945.22,159,945.22,10.2,945.22,0,
,946.25,1679,946.25,94.5,945.48,534,945.61,516,945.61,18,945.61,0,945.73,0xFF02,945.88,3,946,410,946.12,159,946.12,10.2,946.12,0,
,947.15,1817,947.15,94.5,946.39,546,946.51,516,946.51,44,946.51,0,946.64,0xFF02,946.76,3,946.91,410,947.03,159,947.03,10.2,947.03,0,
,948.06,2070,948.06,94.5,947.28,582,947.42,516,947.42,59,947.42,0,947.54,0xFF02,947.67,3,947.79,410,947.93,159,947.93,10.2,947.93,0,
,948.96,1495,948.96,94.5,948.18,648,948.31,522,948.31,69,948.31,0,948.45,0xFF02,948.57,3,948.7,410,948.82,159,948.82,10.2,948.82,0,
,949.85,1748,949.85,94.5,949.09,642,949.21,528,949.21,54,949.21,0,949.34,0xFF02,949.48,3,949.6,410,949.73,159,949.73,9.9,949.73,0,
,950.76,1886,950.76,94.5,949.99,636,950.12,528,950.12,59,950.12,0,950.24,0xFF02,950.37,3,950.51,410,950.63,159,950.63,9.9,950.63,0,
,951.68,1311,951.68,94.5,950.88,648,951.02,534,951.02,54,951.02,0,951.15,0xFF02,951.27,3,951.4,410,951.55,159,951.55,9.9,951.55,0,
,952.58,1242,952.58,94.5,951.8,624,951.93,534,951.93,36,951.93,0,952.07,0xFF02,952.19,3,952.32,410,952.44,159,952.44,9.9,952.44,0,
,953.49,1334,953.49,94.5,952.71,600,952.83,534,952.83,33,952.83,0,952.96,0xFF02,953.11,3,953.24,410,953.36,159,953.36,9.9,953.36,0,
,954.39,1449,954.39,94.5,953.63,600,953.75,534,953.75,41,953.75,0,953.88,0xFF02,954,3,954.14,410,954.27,159,954.27,9.9,954.27,0,
,955.31,1564,955.31,94.5,954.52,606,954.67,534,954.67,46,954.67,0,954.8,0xFF02,954.92,3,955.05,410,955.19,159,955.19,9.9,955.19,0,
,956.23,1541,956.23,94.5,955.44,618,955.56,534,955.56,49,955.56,0,955.7,0xFF02,955.83,3,955.95,410,956.08,159,956.08,9.9,956.08,0,
,957.12,1541,957.12,95.4,956.36,630,956.48,534,956.48,44,956.48,0,956.61,0xFF02,956.75,3,956.87,410,957,159,957,9.9,957,0,
,958.04,1541,958.04,94.5,957.26,618,957.39,534,957.39,38,957.39,0,957.51,0xFF02,957.63,3,957.79,410,957.92,159,957.92,9.9,957.92,0,
,958.95,1518,958.95,94.5,958.17,618,958.31,534,958.31,38,958.31,0,958.43,0xFF02,958.56,3,958.68,410,958.82,159,958.82,9.9,958.82,0,
,959.86,1495,959.86,95.4,959.07,618,959.19,534,959.19,31,959.19,0,959.35,0xFF02,959.46,3,959.59,410,959.71,159,959.71,9.6,959.71,0,
,960.76,1472,960.76,95.4,959.98,582,960.11,534,960.11,31,960.11,0,960.22,0xFF02,960.38,3,960.51,410,960.63,159,960.63,9.6,960.63,0,
,961.68,1472,961.68,95.4,960.91,582,961.04,534,961.04,38,961.04,0,961.16,0xFF02,961.29,3,961.43,410,961.55,159,961.55,9.6,961.55,0,
,962.6,1357,962.6,95.4,961.8,606,961.94,534,961.94,33,961.94,0,962.07,0xFF02,962.19,3,962.31,410,962.47,159,962.47,9.6,962.47,0,
,963.5,1242,963.5,95.4,962.72,606,962.85,534,962.85,26,962.85,0,962.99,0xFF02,963.11,3,963.24,410,963.36,159,963.36,9.6,963.36,0,
,964.41,1196,964.41,95.4,963.63,582,963.75,534,963.75,18,963.75,0,963.88,0xFF02,964.03,3,964.16,410,964.28,159,964.28,9.6,964.28,0,
,965.31,1127,965.31,95.4,964.55,564,964.67,528,964.67,21,964.67,0,964.8,0xFF02,964.92,3,965.06,410,965.19,159,965.19,9.6,965.19,0,
,966.23,1081,966.23,95.4,965.43,558,965.59,528,965.59,21,965.59,0,965.72,0xFF02,965.84,3,965.97,410,966.11,159,966.11,9.6,966.11,0,
,967.15,1403,967.15,95.4,966.36,558,966.48,528,966.48,18,966.48,0,966.62,0xFF02,966.75,3,966.87,410,967,159,967,9.6,967,0,
,968.04,1495,968.04,95.4,967.28,564,967.4,522,967.4,26,967.4,0,967.53,0xFF02,967.67,3,967.79,410,967.92,159,967.92,9.6,967.92,0,
,968.96,1495,968.96,95.4,968.18,576,968.31,522,968.31,31,968.31,0,968.43,0xFF02,968.56,3,968.71,410,968.84,159,968.84,9.3,968.84,0,
,969.87,1495,969.87,95.4,969.09,594,969.23,528,969.23,33,969.23,0,969.35,0xFF02,969.48,3,969.6,410,969.74,159,969.74,9.3,969.74,0,
,970.79,1541,970.79,95.4,969.99,606,970.12,528,970.12,36,970.12,0,970.27,0xFF02,970.4,3,970.52,410,970.65,159,970.65,9.3,970.65,0,
,971.68,1633,971.68,95.4,970.91,612,971.04,528,971.04,38,971.04,0,971.16,0xFF02,971.3,3,971.43,410,971.55,159,971.55,9.3,971.55,0,
,972.6,1771,972.6,95.4,971.83,624,971.96,528,971.96,44,971.96,0,972.08,0xFF02,972.21,3,972.35,410,972.47,159,972.47,9.3,972.47,0,
,973.52,1840,973.52,95.4,972.72,630,972.86,534,972.86,46,972.86,0,972.99,0xFF02,973.11,3,973.24,410,973.39,159,973.39,9.3,973.39,0,
,974.42,1817,974.42,95.4,973.64,624,973.77,534,973.77,41,973.77,0,973.91,0xFF02,974.03,3,974.16,410,974.28,159,974.28,9.3,974.28,0,
,975.33,1794,975.33,95.4,974.55,594,974.67,534,974.67,33,974.67,0,974.8,0xFF02,974.95,3,975.08,410,975.2,159,975.2,9.3,975.2,0,
,976.23,1886,976.23,95.4,975.47,558,975.59,534,975.59,36,975.59,0,975.72,0xFF02,975.84,3,975.98,410,976.11,159,976.11,9,976.11,0,
,977.15,1909,977.15,95.4,976.36,558,976.51,534,976.51,38,976.51,0,976.64,0xFF02,976.76,3,976.89,410,977.03,159,977.03,9,977.03,0,
,978.07,1955,978.07,96.3,977.28,564,977.4,534,977.4,41,977.4,0,977.54,0xFF02,977.66,3,977.79,410,977.92,159,977.92,9,977.92,0,
,978.96,2001,978.96,96.3,978.2,570,978.32,534,978.32,41,978.32,0,978.45,0xFF02,978.59,3,978.71,410,978.84,159,978.84,9,978.84,0,
,979.88,2001,979.88,96.3,979.1,576,979.23,540,979.23,41,979.23,0,979.35,0xFF02,979.48,3,979.63,410,979.76,159,979.76,9,979.76,0,
,980.79,1265,980.79,95.4,980.01,582,980.15,540,980.15,44,980.15,0,980.27,0xFF02,980.4,3,980.52,410,980.66,159,980.66,9,980.66,0,
,981.71,1265,981.71,95.4,980.91,576,981.03,540,981.03,26,981.03,0,981.19,0xFF02,981.32,3,981.44,410,981.57,159,981.57,9,981.57,0,
,982.6,1242,982.6,95.4,981.83,564,981.96,540,981.96,21,981.96,0,982.08,0xFF02,982.22,3,982.35,410,982.47,159,982.47,9,982.47,0,
,983.5,1173,983.5,95.4,982.74,564,982.86,534,982.86,18,982.86,0,982.99,0xFF02,983.11,3,983.26,410,983.38,159,983.38,8.7,983.38,0,
,984.42,1012,984.42,95.4,983.63,534,983.78,534,983.78,13,983.78,0,983.91,0xFF02,984.03,3,984.16,410,984.3,159,984.3,8.7,984.3,0,
,985.34,897,985.34,95.4,984.55,474,984.67,534,984.67,13,984.67,0,984.82,0xFF02,984.94,3,985.06,410,985.18,159,985.18,8.7,985.18,0,
,986.23,943,986.23,95.4,985.47,438,985.59,534,985.59,13,985.59,0,985.72,0xFF02,985.86,3,985.98,410,986.11,159,986.11,8.7,986.11,0,
,987.15,920,987.15,95.4,986.38,438,986.5,528,986.5,13,986.5,0,986.62,0xFF02,986.75,3,986.9,410,987.01,159,987.01,8.7,987.01,0,
,988.04,1104,988.04,95.4,987.26,438,987.41,528,987.41,13,987.41,0,987.53,0xFF02,987.66,3,987.78,410,987.93,159,987.93,8.7,987.93,0,
,988.95,1403,988.95,95.4,988.18,444,988.29,528,988.29,18,988.29,0,988.44,0xFF02,988.56,3,988.69,410,988.81,159,988.81,8.7,988.81,0,
,989.84,1564,989.84,95.4,989.07,462,989.2,528,989.2,33,989.2,0,989.32,0xFF02,989.47,3,989.58,410,989.72,159,989.72,8.7,989.72,0,
,990.74,1587,990.74,95.4,989.98,522,990.1,528,990.1,46,990.1,0,990.23,0xFF02,990.35,3,990.5,410,990.62,159,990.62,8.7,990.62,0,
,991.64,1610,991.64,95.4,990.86,600,991.01,534,991.01,46,991.01,0,991.13,0xFF02,991.26,3,991.38,410,991.52,159,991.52,8.7,991.52,0,
,992.55,1610,992.55,95.4,991.77,666,991.89,540,991.89,38,991.89,0,992.04,0xFF02,992.16,3,992.28,410,992.41,159,992.41,8.7,992.41,0,
,993.44,1633,993.44,95.4,992.67,630,992.8,546,992.8,33,992.8,0,992.92,0xFF02,993.06,3,993.19,410,993.31,159,993.31,8.4,993.31,0,
,994.34,1633,994.34,95.4,993.58,600,993.7,546,993.7,31,993.7,0,993.83,0xFF02,993.95,3,994.09,410,994.22,159,994.22,8.4,994.22,0,
,995.25,1656,995.25,95.4,994.47,582,994.61,546,994.61,31,994.61,0,994.73,0xFF01,994.86,2,994.98,0,995.12,159,995.12,8.4,995.12,0,
,996.15,1702,996.15,95.4,995.37,552,995.5,546,995.5,33,995.5,0,995.64,0xFF01,995.76,2,995.89,0,996.01,159,996.01,8.4,996.01,0,
,997.04,1748,997.04,95.4,996.28,510,996.4,546,996.4,44,996.4,0,996.53,0xFF01,996.67,2,996.79,0,996.92,159,996.92,8.4,996.92,0,
,997.95,1725,997.95,95.4,997.18,468,997.31,552,997.31,46,997.31,0,997.43,0xFF01,997.56,2,997.7,0,997.82,159,997.82,8.4,997.82,0,
,998.85,1679,998.85,95.4,998.07,420,998.21,558,998.21,38,998.21,0,998.34,0xFF01,998.46,2,998.59,0,998.73,159,998.73,8.4,998.73,0,
,999.76,1518,999.76,95.4,998.97,384,999.1,558,999.1,36,999.1,0,999.24,0xFF01,999.37,2,999.49,0,999.63,159,999.63,8.4,999.63,0,
,1000.66,1334,1000.66,95.4,999.88,342,1000,558,1000,28,1000,0,1000.14,0xFF01,1000.27,2,1000.4,0,1000.52,159,1000.52,8.1,1000.52,0,
,1001.55,1288,1001.55,95.4,1000.79,300,1000.92,558,1000.92,23,1000.92,0,1001.04,0xFF01,1001.17,2,1001.3,0,1001.44,159,1001.44,8.1,1001.44,0,
,1002.46,1196,1002.46,95.4,1001.68,288,1001.82,558,1001.82,21,1001.82,0,1001.95,0xFF01,1002.06,2,1002.2,0,1002.33,159,1002.33,8.1,1002.33,0,
,1003.36,1104,1003.36,95.4,1002.58,282,1002.71,558,1002.71,21,1002.71,0,1002.84,0xFF01,1002.98,2,1003.1,0,1003.22,159,1003.22,8.1,1003.22,0,
,1004.25,1058,1004.25,95.4,1003.49,282,1003.61,558,1003.61,18,1003.61,0,1003.75,0xFF01,1003.87,2,1004,0,1004.12,159,1004.12,8.1,1004.12,0,
,1005.15,1035,1005.15,95.4,1004.39,288,1004.53,558,1004.53,23,1004.53,0,1004.64,0xFF01,1004.76,2,1004.9,0,1005.03,159,1005.03,8.1,1005.03,0,
,1006.06,920,1006.06,95.4,1005.28,294,1005.42,558,1005.42,23,1005.42,0,1005.54,0xFF01,1005.67,2,1005.79,0,1005.93,159,1005.93,8.1,1005.93,0,
,1006.96,989,1006.96,95.4,1006.18,306,1006.31,558,1006.31,13,1006.31,0,1006.45,0xFF01,1006.57,2,1006.7,0,1006.82,159,1006.82,8.1,1006.82,0,
,1007.85,1058,1007.85,94.5,1007.09,300,1007.21,558,1007.21,15,1007.21,0,1007.34,0xFF01,1007.48,2,1007.6,0,1007.73,159,1007.73,8.1,1007.73,0,
,1008.76,1150,1008.76,95.4,1007.99,300,1008.12,558,1008.12,21,1008.12,0,1008.24,0xFF01,1008.37,2,1008.51,0,1008.63,159,1008.63,7.8,1008.63,0,
,1009.66,1058,1009.66,94.5,1008.88,312,1009.02,558,1009.02,23,1009.02,0,1009.15,0xFF01,1009.27,2,1009.4,0,1009.54,159,1009.54,7.8,1009.54,0,
,1010.57,1058,1010.57,94.5,1009.79,312,1009.91,558,1009.91,18,1009.91,0,1010.05,0xFF01,1010.18,2,1010.3,0,1010.43,159,1010.43,7.8,1010.43,0,
,1011.46,1104,1011.46,94.5,1010.69,306,1010.81,558,1010.81,21,1010.81,0,1010.92,0xFF01,1011.08,2,1011.21,0,1011.33,159,1011.33,7.8,1011.33,0,
,1012.36,966,1012.36,94.5,1011.6,300,1011.72,558,1011.72,21,1011.72,0,1011.84,0xFF01,1011.97,2,1012.12,0,1012.24,159,1012.24,7.8,1012.24,0,
,1013.28,989,1013.28,94.5,1012.49,300,1012.64,558,1012.64,15,1012.64,0,1012.77,0xFF01,1012.89,2,1013.01,0,1013.16,159,1013.16,7.8,1013.16,0,
,1014.2,1035,1014.2,94.5,1013.41,288,1013.53,558,1013.53,18,1013.53,0,1013.67,0xFF01,1013.8,2,1013.92,0,1014.04,159,1014.04,7.8,1014.04,0,
,1015.09,1081,1015.09,94.5,1014.33,288,1014.45,558,1014.45,21,1014.45,0,1014.58,0xFF01,1014.72,2,1014.84,0,1014.97,159,1014.97,7.8,1014.97,0,
,1016.01,851,1016.01,94.5,1015.23,294,1015.35,558,1015.35,18,1015.35,0,1015.48,0xFF01,1015.61,2,1015.76,0,1015.89,159,1015.89,7.8,1015.89,0,
,1016.92,897,1016.92,94.5,1016.13,288,1016.28,558,1016.28,10,1016.28,0,1016.4,0xFF01,1016.53,2,1016.65,0,1016.79,159,1016.79,7.5,1016.79,0,
,1017.84,805,1017.84,94.5,1017.04,276,1017.16,558,1017.16,8,1017.16,0,1017.32,0xFF01,1017.44,2,1017.57,0,1017.7,159,1017.7,7.5,1017.7,0,
,1018.73,897,1018.73,94.5,1017.96,264,1018.08,558,1018.08,8,1018.08,0,1018.21,0xFF01,1018.35,2,1018.47,0,1018.6,159,1018.6,7.5,1018.6,0,
,1019.65,851,1019.65,94.5,1018.88,258,1019,552,1019,13,1019,0,1019.13,0xFF01,1019.25,2,1019.4,0,1019.52,159,1019.52,7.5,1019.52,0,
,1020.57,828,1020.57,94.5,1019.77,264,1019.91,552,1019.91,13,1019.91,0,1020.03,0xFF01,1020.16,2,1020.28,0,1020.44,159,1020.44,7.5,1020.44,0,
,1021.47,828,1021.47,94.5,1020.69,264,1020.82,552,1020.82,8,1020.82,0,1020.96,0xFF01,1021.08,2,1021.2,0,1021.33,159,1021.33,7.5,1021.33,0,
,1022.38,851,1022.38,94.5,1021.6,264,1021.72,552,1021.72,8,1021.72,0,1021.85,0xFF01,1022,2,1022.12,0,1022.25,159,1022.25,7.5,1022.25,0,
,1023.28,989,1023.28,94.5,1022.52,264,1022.64,546,1022.64,8,1022.64,0,1022.77,0xFF01,1022.89,2,1023.03,0,1023.15,159,1023.15,7.5,1023.15,0,
,1024.2,1334,1024.2,94.5,1023.4,270,1023.56,546,1023.56,13,1023.56,0,1023.69,0xFF01,1023.81,2,1023.93,0,1024.08,159,1024.08,7.5,1024.08,0,
,1025.12,1656,1025.12,94.5,1024.32,276,1024.45,546,1024.45,26,1024.45,0,1024.59,0xFF01,1024.72,2,1024.84,0,1024.96,159,1024.96,7.5,1024.96,0,
,1025.99,1840,1025.99,94.5,1025.23,324,1025.35,552,1025.35,41,1025.35,0,1025.48,0xFF01,1025.63,2,1025.75,0,1025.88,159,1025.88,7.5,1025.88,0,
,1026.91,1288,1026.91,94.5,1026.15,366,1026.27,558,1026.27,51,1026.27,0,1026.4,0xFF01,1026.53,2,1026.68,0,1026.79,159,1026.79,7.5,1026.79,0,
,1027.84,1150,1027.84,94.5,1027.04,372,1027.19,564,1027.19,36,1027.19,0,1027.31,0xFF01,1027.44,2,1027.56,0,1027.71,159,1027.71,7.5,1027.71,0,
,1028.76,920,1028.76,94.5,1027.96,348,1028.08,564,1028.08,23,1028.08,0,1028.24,0xFF01,1028.37,2,1028.49,0,1028.62,159,1028.62,7.2,1028.62,0,
,1029.65,828,1029.65,94.5,1028.88,318,1029.01,564,1029.01,10,1029.01,0,1029.13,0xFF01,1029.27,2,1029.4,0,1029.52,159,1029.52,7.2,1029.52,0,
,1030.57,828,1030.57,94.5,1029.8,300,1029.92,564,1029.92,8,1029.92,0,1030.05,0xFF01,1030.17,2,1030.32,0,1030.44,159,1030.44,7.2,1030.44,0,
,1031.49,805,1031.49,94.5,1030.69,294,1030.83,564,1030.83,8,1030.83,0,1030.96,0xFF01,1031.08,2,1031.2,0,1031.36,159,1031.36,7.2,1031.36,0,
,1032.39,1242,1032.39,94.5,1031.61,288,1031.74,558,1031.74,8,1031.74,0,1031.88,0xFF01,1032,2,1032.13,0,1032.25,159,1032.25,7.2,1032.25,0,
,1033.28,1380,1033.28,94.5,1032.52,288,1032.64,558,1032.64,18,1032.64,0,1032.77,0xFF01,1032.92,2,1033.03,0,1033.15,159,1033.15,7.2,1033.15,0,
,1034.2,1357,1034.2,94.5,1033.43,306,1033.55,558,1033.55,26,1033.55,0,1033.68,0xFF01,1033.8,2,1033.95,0,1034.06,159,1034.06,7.2,1034.06,0,
,1035.09,1403,1035.09,94.5,1034.31,324,1034.46,564,1034.46,31,1034.46,0,1034.58,0xFF01,1034.71,2,1034.83,0,1034.97,159,1034.97,7.2,1034.97,0,
,1035.99,1403,1035.99,94.5,1035.22,342,1035.34,564,1035.34,33,1035.34,0,1035.48,0xFF01,1035.61,2,1035.74,0,1035.85,159,1035.85,7.2,1035.85,0,
,1036.88,1426,1036.88,94.5,1036.12,354,1036.25,570,1036.25,33,1036.25,0,1036.37,0xFF01,1036.52,2,1036.63,0,1036.76,159,1036.76,7.2,1036.76,0,
,1037.79,1472,1037.79,94.5,1037.02,354,1037.15,576,1037.15,33,1037.15,0,1037.28,0xFF01,1037.4,2,1037.54,0,1037.66,159,1037.66,7.2,1037.66,0,
,1038.69,1426,1038.69,94.5,1037.91,360,1038.05,576,1038.05,38,1038.05,0,1038.18,0xFF01,1038.3,2,1038.43,0,1038.57,159,1038.57,7.2,1038.57,0,
,1039.6,1104,1039.6,94.5,1038.82,360,1038.94,582,1038.94,26,1038.94,0,1039.08,0xFF01,1039.21,2,1039.33,0,1039.46,159,1039.46,7.2,1039.46,0,
AGOODHI
NorCal
MKVII GSW, MKVI Golf
before the mandatory flash here in CA, i used to interrupt regens regularly (high idle, turn off car, fans come on). after the flash, now regens happen almost every time i start up the car from cold. it never used to do that. now, i never interrupt regens (normal idle, turn off car, no fans). they seem to all happen earlier in my drive cycle (15 miles city traffic). i can tell because it idles a bit higher and the car has more pep (more torque).
gmcjetpilot
Memphis TN
2010 JSW TDI DSG Matalic Grey
Sorry to slightly hijack the thread, but what is the MAX EGT you all (with OBDII gauges) see during REGEN... I am seeing well over 1200F (turbo out EGT or DPF in EGT... the high one). I was on the highway and had to come to a stop during a Regen and got a flashing glow plug light. It kept flashing even thought REGEN ended. It went away after I got home and shut down. Drove it today, no issue. I have not checked the codes with my cable, but I am guessing it got an error, like EGT probe error... due to the high EGT...
ATR
Baltimore
2011 Golf TDI 6MT
see below I cut out a few boring rows, but after a single blank line the whole DPF regen is shown.
Engine Speed - (G28)
Coolant - Temperature (G62)
Temperature prior - Turbo Charger
Temperature prior - Particle Filter
Particle Filter - Different. Pressure
Particle Filter Offset - Different. Pressure
0xFF02=Done,STAMP,Requested - Regenerations
Mileage - Since last Regen
Particle Filter - Oil Ash Volume
Soot Load(g) - Calculated
Soot Load(g) - Measured
Thanks for the info!
Sorry to slightly hijack the thread, but what is the MAX EGT you all (with OBDII gauges) see during REGEN... I am seeing over 1200F (turbo out or DPF in... the high EGT).
I'd say that's a good question to expand on the OP's subject :cool:
I watch the regen temps like a hawk with PolarFIS Advanced...
DPF IN and OUT I see about 1000-1200 or so.
EGT I see range between 1000-1500.
meerschm
Fairfax county VA
2009 Jetta wagon DSG 08/08 205k buyback 1/8/18; replaced with 2017 Golf Wagon 4mo 1.8l CXBB
always a risk to just guess at why the ecu is not happy.
a VCDS will let you see exactly what was logged. may have nothing to do with the DPF or sensors.
I looked at the logged data set shared above, and see a few samples at 750C (1382 f) before the turbo.
the highest I see on my polar fis plus is around 1500, at the end of a longer deSOX regen.
Diesl
Chicago
'78 Golf Diesel (long gone); 2012 Jetta Sportwagen TDI w/ DSG
Mike, thanks a lot. I know it's extra work, but if you log this again, could you include the VCDS equivalent to the OBD 'exhaust pressure' variable? Its PID is 0173. I'm actually not sure where exactly it is measured, but I'm hoping that the ratio of DPF differential pressure to exhaust pressure tells us something about the loading of the DPF. I'm not sure I need the regeneration itself, but just some lines of a log before and after would help.
meerschm
Fairfax county VA
I do not know where to start to look to convert/find the PID as measuring block. it could just be that differential pressure.
what kind of values do you see at idle, and at speed, just after a regen, and a little before?
I could get my scangauge back out and program it, and try to find a measuring block that acts the same. but it is an either/or choice. they do not play well connected at the same time. (even if I had an OBD Y connector)
the 2.0 self study program says the measured soot value is calculated using the DPF differential pressure, mass flow and temperature. seems like it is the right measure of how clogged up the DPF is.
http://www.natef.org/NATEF/media/NATEFMedia/VW%20Files/2-0-TDI-SSP.pdf
page 62
Another soot load model is the flow resistance of the particulate filter. It is calculated from the signals of Exhaust Pressure Sensor 1 G450, Exhaust GasTemperature (EGT) Sensor 3 G495, and Mass Air Flow (MAF) Sensor G70​
Diesl
Chicago
I haven't looked at mass air flow. I tried to compute exhaust flow from rpm and boost pressure, correcting for exhaust gas temperature, but that product does not correlate well with the dpf differential pressure. Boost alone (or rather, manifold pressure) surprisingly correlates better, but the ratio still shows a lot of variation. What seems to be fairly constant is DPF diff.pressure divided by that exhaust pressure variable. That ratio is quite steady over a range of boost and RPM.
So, is there any other exhaust related pressure in one of the VCDS groups? The one I'm looking for is about 1.5 times the DPFdiff.pressure after a regen while driving , and closer to 1 times DPF before a regen. But I could also be imagining that; just knowing what VW/VCDS calls that pressure would help.
gmcjetpilot
Memphis TN
Thanks I feel better. Reading the info on the web the published REGEN temp is 600C to 650C... (pre turbo or at DPF not sure).
That is about 1200F.... So what I am seeing is about right turbo inlet EGT... (That thing must be glowing).
huntdi
Lodi,NJ
2003 JETTA TDI 5 speed,1978 PEUGEOT 504D 4 speed,1997 AUDI A4 Avent TDI 5 speed TDI(IN EUROPE)
Mine does it 100 - 120 miles:(
