thebarber
Im contemplating a mufflerectomy on my 06 tdi wagon, but I worry its going to be too loud
Anyone running a muffler-delete locally?
Ever go to the VW meet in Cambridge? Id be curious to hear it in person....yes, my blue '01 is driven daily from Kitchener to Cambridge. not too loud.
IIRC it every Monday at the Tim Horton's on holiday inn driveVW meet in Cambridge? where is this? Some of the TDI guys meet at Grand River Brewery.
You'll have nothing to worry about.Droning on the highway is my largest concern...
Would you suggest turn down or straight out the rear?You'll have nothing to worry about.
It's not going to matter, pick which ever you think looks the best.Would you suggest turn down or straight out the rear?
pm'd youI'm in South Kitchener. You're welcome to come hear my car sans muffler.
Pff. There's no such thing as high compression anymore.
Days if 22:1 are gone I think.
They killed the ratio in the 70s to knock NOx, and killed hp/tq too....
OK, rant over. Sorry.
Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
I am Kerma tuned ( Stage 2 eqiv) with nozzles, race pipe and SB Stage 2 clutch with stock turbo and haven't had any problems.Wow, I like the look!
However, I now have it on good authority that I should leave my exhaust alone as im going Malone stage 2 and id rather not have boost creep issues
You've got a completely different engine then the OP does.I am Kerma tuned ( Stage 2 eqiv) with nozzles, race pipe and SB Stage 2 clutch with stock turbo and haven't had any problems.
I try not to over boost thou (too much ) .
M
^^and different turbo.You've got a completely different engine then the OP does.
I have boost creep too I assume... straight piped and still boosts to 22.6 psi with new turbo, same thing as before with my old turbo which I thought was sticky vanes and over boost, I guess it could've been a mix, but at this point I don't know what else it could be... O well, I guess i'll it take it since the turbo can handle it
Yea I've been looking to get a new n75, will pick up one when I get the chance but timing belt next... What sort of difference should I expect with a new one and an adjustment? (sorry for the thread hijack)I would call that overbOOst, a new N75 and a little actuator adjustment and you'd be rockin. You should only be around 15psi on a stage 1 tune.
