How long will a VNT15 last at 22psi?
Ookpic
London, ON - Port Huron, MI
2002 Golf 2Dr 5spd
I suspect not long. However I'm no authority. I believe they really don't like much more than 18psi. If I go from no throttle to the floor mine will spike to 20 but instantly goes back to 18 as per requested when I got my tune. Been running it that way for almost a year now.
PeterV
TDIClub Enthusiast, HO5G Doyen & Zen Master
So, NH.
2000 Jetta 5 sp.
Well I have 10 yr old 240 Kmi on the stock "15". I have had spikes to 32 PSI often.
Still a strong car. And also a 100% TDIfest participant...
KERMA
here
currently 99 beetle and 2011 335d
:eek:
Piranha
Malta (Europe)
golf 2000 Flash Red
How long will it take you to say "22psi boom"
You will say 22psi, but the turbo will say the BOOM
hehe
K.I.T.T.
Europe
PD75
Got a question that's been bugging me for a while and thought I'd chime in.
Does it also matter on engine capacity too? I know it's irrelavant for 99% of people on the site, but someone was running 1.65 bar on a 1422cc 3 cylinder TDi with what I thought was a GT1749VA, but apparently he was doing it using a PD115 turbo, which I think is a GT1749V :confused: I'm pretty sure VNT15 + 1.9 TDI + 1.65 bar = kaboom :D
Is flow rate capability of a compressor inversely proportional to engine size or am I thinking wrong?
Thanks,
Ash :)
nytoy
rochester, NY
1999.5 Jetta
Glad to hear!!
I ran 19 PSI on my Golf at the track, it regularly spiked to 24-26 PSI. Couldn't kill it.
Gary Miyakawa
Admin Emeritus
Roswell, Ga
1998 NB TDI
I've heard that Viagra pills in Diesel helps with the spikes.... :p :p :p
Cheers,
Gary M
diesel-dave
earth
2003 wagon TDI, 2003 wagon Tdi, 2013 Q7 Tdi
I believe that, but Peter I not sure if others do that, it will yield that same results!
You're right, it's in no way a prediction. I have yet to blow a turbo. Guess that's the benefit of driving like an old guy. ;)
shizzler
Ann Arbor MI
05 BEW Wagon
RC3 runs around 18.5 psi sustained, right? Never heard of anyone blowing up a VNT-15 shortly after getting tuned, lots of people running that.
I need to ask Charlie for more boost, lol.
A separate question is, at what boost pressure does a VNT-15's compressor efficiency fall off a cliff? i.e. turning more energy into heat vs. pressure.
TdiRacing
Baltimore, MD
2006 Jetta TDI Cup
My a$$...that car is was fast and that little turbo sure did work well...
I also run the 15 in my wifes beetle with about 20 PSI regularly and i am sure it spikes a bit on tip in as well. That 15 has really good response time, just lacks the top end flow.
diesel-dave
earth
Oliver that's correct "is" and "was" fast...;) Peter has good luck when he pushes stuff
FlyTDI Guy
PNW
'01 Jetta GLS
Clearly, it will last as long as it lasts... I would expect that to be not as long as one running 13.7 psi.
jeffpepin
canada
1.9 ALH jetta 2003
made 20 000km with used vnt15 never see over 25psi by 3 sec because my boost limit map put in limp mode , but always made him scream like demon (daily range 17 ~24.5 psi )
melted hexaust turbine after 20k km while a badly emotional ride ( floored like ,,,,) to be safe while surexploiting turbo maybe is , a shutoff manual valve on oil feed et voila au cas ou ahaha
Mongler98
COLORADO (SE of Denver)
A: that run on sentence of grammatical nightmares!
B: Ahh.... what?
C: leave it to these newbs to revive a 10 year old thread like this!
D: You're EGTs must have been stupid high to melt it like that.
I expected better from canada.
jwrb
Kent, United Kingdom
Caddy MK2 ALH, Cordoba Vario Cupra 1.9 High Power Build, 2011 Caddy 2.0 CR170
For a good bit of reference. I've been running my GT1749 (stock ALH/ASV turbo) in the UK at 21psi for the last 18 months without any issues. It holds 1.45bar of boost on the gauge (and in the logs) from around 1800rpm to 3500rpm.
Car gets abused and has covered over 70k in this configuration, it's finally showing some problems with an exhaust leak, but otherwise the VNT is still free and it is not consuming any oil.
It is important to note the turbo was in fantastic condition beforehand (however it was used with 180k miles on it iirc)
devon1996
Denver
08 A4 tdi swap
Depends on how your tuning is setup. I have been running 23 on my bv39 for like 10k miles and it's fine but I tuned it to go back to stock boost after 4200 rpm. High rpm+high boost= overspeeding the turbo.
