gmcjetpilot
Edit How I did NOT clear CEL/MIL - Still Issues after replacing 03G 128 063T
I had these two faults (below) which triggered a flashing glow plug light (GP Lt) on
occasion, once every 3-6 months. This has been going on for almost two years,
only after a cold start. It would always reset once I shut down and restarted. I was
getting the GP Lt. flash more often and even during driving for a split second. Then
the MIL came on yesterday, stayed on. GP Lt. flash reset. I had already purchased
a new Anti-Shutter/Throttle Body. I installed it today, but the <MIL> would not go out.
I tried clearing codes with RossTech. I tried the 10 min battery disconnect. Then I
went for a drive, still MIL on solid. I connected RossTech and did a input/output
test of the throttle body. Not sure what it does, but it looks like it cycles it, open
and close. I did that a few times. I went to "Readiness" and MIL status was OFF?
Humm. Sure enough I rest the <MIL>. Just took it for test drive, all is good!!!
Does anyone know what I did? I think the "test" reset it. I know reading some
of the Ross Tech Wiki's there are some weird reset procedures.
2 Faults Found:
008449 - Throttle Valve Actuator Control System
P2101 - 000 - Malfunction - Intermittent
001592 - Throttle Body Actuator Bank 1 (J338)
P0638 - 000 - Implausible Signal - Intermittent - MIL ON
2 Faults Found:
