I've always wondered what the top speed is on a Touareg TDI. I never opened mine up but have had it a little over a 100 mph leaving a turd that was tailgating me. I know they have speed limiters but wonder what they are set at. Anyone know?
That is getting it done the road!You can set the cruise at 120.
Address 02: Auto Trans (0C8 927 750 CF)
12:53:09
IDE00024-ENG98981 ATF temperature-Transmission fluid temperature 35 °C
IDE02820 Transmission mileage 183928.0 km
IDE06881-ENG99951 Max. transmission fluid temperature over lifetime-Lifetime ATF Sensor Max Value 98 °C
IDE80036-ENG103596 Analysis 36-Max vehicle speed 198 km/h
Limits can be viewed\checked in the appropriate controllersPossibly 130 mph, but it could possibly be the 155 mph one. Some have been 120, too. It will be within the speed range of the factory tires. H rated tires are 130.
Years back, the EU imposed one for 250 kph (about 155 mph) because so many cars were getting so fast.... the territory north of triple digits was no longer just the domain of sports coupes and big sedans.
The T'reg may be lower due to the fact that it is technically classified as a truck or MPV or whatever.
I know the bigger Audi sedans have no problem using most of their 160 mph speedometer.
IDE02247,Static maximum speed limit,300.00, km/h
IDE02248,Individually adjustable top speed limit,300.00, km/h
Can you change the speed limiter using the VagCom?Limits can be viewed\checked in the appropriate controllers
Code:IDE02247,Static maximum speed limit,300.00, km/h IDE02248,Individually adjustable top speed limit,300.00, km/h
I’m not interested in going any faster on the highway. However, I could pay a few hundred more for the Z-rated rubber and really swing for the fences - if it weren’t for the damn governor!Check your tires. The speed limiter is set so that the tires won't explode. H-rated tires top out at 130 mph. That's why the speed limiter is set there.
I can't find my calculator.... does your alleged limiter you hit convert to what I'm showing?Can you change the speed limiter using the VagCom?
Our Treg stops accelerating at 130 mph. I reached the [governed] top speed once; but I’m pretty sure the Cayenne beside me had the same speed limitations![]()
So does stuff like EGT limiter and power reduction due to various other things which if left unchecked might allow a driver to damage stuff....Because it limits the speed.![]()
As a tire engineer, I appreciate you reiterating this.Check your tires. The speed limiter is set so that the tires won't explode. H-rated tires top out at 130 mph. That's why the speed limiter is set there.
