How far can stock internals be pushed on mk4 bew?
Lewis98
United Sates, WI
04 Jetta Bew
Hey guys, newbie here, I bought me jetta little over a year ago and love this thing!!!!! the mpgs are great and I am starting to dip in to the thirst for more power, was tossing around the idea of get a GTB 2260 vk turbo but I think it might be to much for stock internals.....????? I will also be upgrading, injectors, intercooler, clutch again probably, and so on. I would love to learn more in any ways that I can :D All my buddys also have mk4 ALH's so any info on modding those would be great too. Will is hold up? 35psi of boost and close to 300bhp????:confused:
InfoSec
Brighton, MI
Anything over a GTB1756vk, or about 200hp would require (in order to sleep at night), rods and ARP Head Studs. There are many threads about this on this site, so I say check them out, go with a good tune, because many problems can be eliminated with a tune that doesn't bring on too much pressure too quickly. My car's tune/mods works great. At about 210hp, 370tq, it's hard to keep the wheels from spinning.
Lewis98
United Sates, WI
04 Jetta Bew
Alright I'll do some more looking. I am planing in apr head studs, just don't really want to do any internals at this time so you would say gtb 2260 what be a bit to much???? Also any recommendations on FMIC's or SMIC's?? was looking at getting Fraid 80%'s or the 783 pd race nozzles. opions???
InfoSec
Brighton, MI
Bosio Race 520's, balanced and pop-tested, with an 11mm pump, large smic, with a 1756 and a tune would get you around 200hp and about 350+tq... way better ride, spools nicely, and is a complete blast to drive... on stock internals. Malone stage 5 is what I have and it works very well. You can buy almost all of the parts you need from RyanP at Darkside. I bought my smic from Rodriguez. Lots of people have different stories/opinions, so I would definitely read as much as you can in order to make an informed decision. I would also contact RyanP and others to talk about what you can do w/out changing stock internals... My comments are my own opinions based on just my experience. Good luck!!
FYI, if you were close to Michigan, I'd let you take my car for a spin to see if you like my set-up. Plus it's for sale... (shameless plug!)
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
Lewis98, just contact a tuner and do what they recommend. tunemyeuro, kermatdi, rocketchip, darkside are all good tuners that won’t steer you wrong. Tell them the HP goal and they will tell what to do and not to do.
Lewis98
United Sates, WI
04 Jetta Bew
Alright I guess the next step for me is getting a hold of a tuner. I alright have an idea for what I am going to throw at it for parts. Gtb 2260vk turbo, on stock manifold, head studs, maybe a new intake,???? stage 4 clutch, was looking at firad 80% injector nozzles ( or injector swap at darkside), stage 3 colt cam, and inter cooler probably front mount, an upgraded map sensor bar 3 or 4. I will probably end up getting tuned by malone.
Nevada_TDI
Reno, sort of...
2001 Jetta TDI
A BEW with just a tune is a blast to drive. I don't remember the specifics torque and horsepower, but since a b e w already has larger injectors and turbo on it than an alh you might just be happy there. start in expensive and then work your way up.
Curious Chris
Pineview GA
Jetta Wagon 2003 RIP Rockford IL
I would get a Limited Slip Differential. As you go up on power the 1 wheel drive slips a lot. I have a Wavetrac and love it. If I had known how nice it would be I would have put that on before my big FMIC.
Lewis98
United Sates, WI
04 Jetta Bew
Alright I contacted darkside they gave me a list of parts, for the build and recommendations, they said stock internals would hold to 260-280bhp
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
When I contacted them for my alh they actually told me it would be better to start with a bew bottom end since they are stronger than alh. Good guys there.
Lewis98
United Sates, WI
04 Jetta Bew
Please see the list of parts below:
Engine:
GTB2260VK Turbo Kit with Tubular Stainless Manifold and 3" Downpipe - £2100 - http://www.darksidedevelopments.co.uk/products/darkside-gtb-turbo-kit-for-1-9-8v-tdi-engines.html
Race Injectors - £600 (Modifying your injectors) - http://www.darksidedevelopments.co....-8v-tdi-with-firad-50-80-120-160-nozzles.html
Injector Bolts - £65 - http://www.darksidedevelopments.co....-bolt-kits-for-1-9-2-0-8v-tdi-pd-engines.html
Intercooler - £400 - http://www.darksidedevelopments.co....tercooler-kit-fmic-for-1-9-tdi-pd130-asz.html
(Euro Crash Bar (Needed for Intercooler) - £50)
Alloy Radiator - £175 - https://www.darksidedevelopments.co...diator-for-vw-golf-mk4-platform-vehicles.html
Lower Temp Thermostat - £27.50 - https://www.darksidedevelopments.co...oolant-thermostat-for-1-9-8v-tdi-engines.html
Custom Inlet Manifold - £200 - http://www.darksidedevelopments.co....ustom-aluminum-1-9-tdi-8v-inlet-manifold.html
EGR Cooler Delete - £20 - http://www.darksidedevelopments.co....-us-alh-bew-pd100-egr-cooler-delete-pipe.html
4 BAR MAP Sensor - £35 - https://www.darksidedevelopments.co...p-manifold-pressure-sensor-0-281-006-059.html
Rocker Gasket - £12.50 - http://www.darksidedevelopments.co....ver-gasket-for-1-9-2-0-tdi-8v-pd-engines.html
These are the parts we can supply 'off the shelf'. Personally I would recommend a Single Pass setup, as large as possible with custom pipework. The Battery will need to go in the boot, and stock Air Box has to go.
Race Camshaft - £700 - http://www.darksidedevelopments.co....e-camshaft-kit-for-1-9-2-0-8v-pd-engines.html
Cam Cap Bolts - £20 - http://www.darksidedevelopments.co.uk/products/cam-cap-bolt-kit-for-1-9-2-0-8v-tdi-pd-engines.html
To get 300bhp+, you need a Ported Head and the GTD2872VK instead of the GTB2260VK. 120% Injectors would also be required.
Keeping everything safe, the Full Engine would need to be build. I would do it around a 2.0 Bottom End
Engine Build
Upgraded Valves - £340 - http://www.darksidedevelopments.co....ust-valves-for-1-9-2-0-tdi-8v-pd-engines.html
Valve Springs - £180 - http://www.darksidedevelopments.co....-retainers-for-1-9-2-0-tdi-8v-pd-engines.html
Ported Head and Assembly - £1300 - https://www.darksidedevelopments.co.uk/products/darkside-1-9-tdi-8v-pd-ported-head.html
Head Stud Kit - http://www.darksidedevelopments.co.uk/products/head-studs-for-vw-1-9-2-0-8v-tdi-pd-engines.html - £225
Head Gasket - http://www.darksidedevelopments.co....head-gasket-for-1-9-tdi-with-bhw-pistons.html - £40 - For this, you need to know the Piston Protrusion, so the bottom end will need to be assembled first to check 100%. 2 Hole is usually the right thickness
Head Set - £30 - http://www.darksidedevelopments.co.uk/products/head-set-for-1-9-tdi-8v-engines-mk4-platform.html
Pistons and rings - http://www.darksidedevelopments.co.uk/products/vw-2-0-bhw-pistons-for-1-9-8v-tdi.html - £500
Rosten Rods - http://www.darksidedevelopments.co....-for-1-9-pd130-pd150-2-0-tdi-pd140-pd170.html - £400
ARP Mains Studs - http://www.darksidedevelopments.co....ains-cap-stud-kit-for-all-vw-tdi-engines.html - £120
Crank Bearings - http://www.darksidedevelopments.co.uk/products/vw-1-9-2-0-tdi-complete-crankshaft-bearing-kit.html - £40
Rod Bearings - http://www.darksidedevelopments.co....lete-rod-bearing-kit-sputter-bearing-kit.html - £75
Thrust Bearings - http://www.darksidedevelopments.co.uk/products/1-9-2-0-tdi-complete-thrust-bearing-kit.html - £15
Rear Main Seal - http://www.darksidedevelopments.co....eal-for-1-9-8v-tdi-engines-06a-103-171-a.html - £40
Transmission - I would upgrade to a 6 Speed for sure. Usual prices are here
http://forums.tdiclub.com/showthread.php?t=373687
5 to 6 Speed Swap - £1250 GBP
Darkside HD SMF, Clutch Kit and Releaser - £700 extra - http://www.darksidedevelopments.co....ywheel-smf-clutch-kit-for-vw-02m-6-speed.html
LSD Installation including ARP Bolts, New Diff Bearings and Upgraded forks - £900 GBP extra - http://www.darksidedevelopments.co.uk/products/quaife-02m-2wd-atb-helical-limited-slip-diff-lsd.html
Hope this helps and gives and idea on costs.
This is what they gave me for a parts list.
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
That’s about the same as what they gave me for my ALH. I have around $6k between the engine build and turbo set up. It’s a steep hill to go down....
Lewis98
United Sates, WI
04 Jetta Bew
Yeah that is very true, but i've been doing some shopping and have found different places to get the same part @ way lower prices.
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
I found it was easier to just get it all from them myself. One stop shop and ship it all over one time. Some things I did have to source from the US but most I got from darkside.
