use the VCDS to pre-charge the fuel system after a fuel filter change on a late model 2011 MK6 TDI? I'm new to the VCDS & TDI's so any help or link to this topic would be appreciated.
With us here at the dealer there is a test plan that does this. Hopefully Ewe (sp?) will jump in and tell you which Basic setting group or adaption channel will do this. Wonder if you could at least do an output test and the fuel pump to pre-charge the filter?
