Drewser
- Joined
- Jul 19, 2002
- Location
- Mesa, AZ USA
- TDI
- '04 Jetta TDI Wagon, '04 Passat TDI, '03 Jetta TDI Wagon, several more in past
Starting a new thread for this and not making any assumptions. Bought a project car from someone I found through a mechanic friend. Mechanic said it needs a new engine. All I know for certain is that the dipstick tube melted and exhaust was seen in the coolant bottle. And has just over 300k (EDIT: actually 235k) miles on the odometer. It's actually only a 2 owner car...spent its first 12 years in Colorado with one person then down here in Northern AZ for a few years before the guy's sister drove it in Phoenix for a few years. Aside from copious amounts of cigarette ash, the interior and leather is in surprisingly good condition.
Picking it up on a trailer tonight and going to dig into it. Based on the partial gallon of gold GM coolant in the trunk, I'm guessing maintenance was pretty bad. I need to determine if it's worth putting money into this this engine (new EGR cooler, timing belt, water pump, extensive coolant flush, double oil change, etc.) or put a used motor in. Used motor would probably still get the timing belt changed, coolant flush, oil change, etc. I suppose. I've got $300 into the entire purchase so far so have some room to "play".
TL;DR: What's the best way to determine if it's worth putting money into diagnosing and fixing this engine? Compression check? Coolant system pressure check? Where would you start troubleshooting?
