Been having an odd problem since I did some work on my 2005 Beetle. I had some front wheel bearing issues, so I decided to do a bunch of stuff at the same time. I find out I needed new front wheel bearings, so I decided to do the whole steering knuckle, inner and outer the rods all at the same time (did the rear wheel bearings as well). After I did all the work, I've had some weird issues. There is a little noise in the steering at low RPMs, it also seems like the engine is running a bit rougher, like it had a little less power at idle.
The only thing I noticed when doing the work was that the old inner tie rods had a channel in the threads and the new ones didn't (the new inners also had a washer with them that I put on). From what I've found, though, there isn't any fluid flowing through there, so it shouldn't matter. I didn't have a tie rod tool, so I made one out of an old 3/4" drive socket, a piece of pipe, and a couple of bolts. When putting the new inners on, I don't remember if I put a wrench on the steering rack shaft or not. Could I have overtightened it and damaged the steering rack somehow? I also added some new fluid to the steering reservoir, but I had looked here before I did and got the Pentosin stuff.
Is it something I did, or could it be something totally unrelated? Seems odd that it started right after I got it all back together.
