VelvetFoot
Just curious....
(PS: I didn't know where to put this thread since it spans a several platforms.)
The factory service interval on the DSG is every 40,000 miles. It's comprised of a fluid/filter change.jasonTDI said:Brad that's a pretty poor statement about the Mexican plant. They have a very good build quality compared to the rest of VW. They worked hard to get that and they are keeping it. Also the DSG is completely different than your automatic. Not even the same animal so no comparison.
Dan, The trans is out of my scope a bit yet as I have not worked on one but I do have the full technical schematics for it. I'd stay with service in your area as Z service isn't too hot. Most of their techs are students yet. Great sales and parts dept though. I'd highly recommend fluid changes on the transmission at least every 50K miles and 30K would be better especially for the first one since there is a quite a bit of break-in junk.
Pelican18TQA4 said:The factory service interval on the DSG is every 40,000 miles. It's comprised of a fluid/filter change.
Just FYI the first U.S. VWs to get the DSG were the '05 New Beetle TDIs. Then the Jetta followed when the MkV cars were introduced as '05.5 cars. If you're looking at a 2004, it's got the older torque converter auto.Any long-term updates on the reliability of the early DSG transmissions?
I'm considering purchase of a 2004 - 2005-ish New Beetle for my daughter who's definitely opposed to manual transmission. I've heard the horror stories about the earlier auto transmissions in MK4's but know the DSG is no relation to them. But, having no relation doesn't necessarily make it better.
So, how are your 2004 - 2006 DSGs doing after 100,000 - 200,000 miles?
Jim
(Love my 2013 Passat TDI with DSG at 25K miles)
Unlike a typical manual transmission, the clutches in the DSG are wet clutches. Meaning, they are bathed in oil and the oil is designed to wear rather than the clutches. Also, the same fluid lubricates and cools the entire transmission.Since the DSG is essentially a manual transmission, which is mechanically shifted, what's the deal with it needing such expensive oil, and frequent changes?
The manuals can go for 200,000+ miles, with no change in oil.....if one is a notch anal, like me, they change the oil - at a cost of about $18.
I mean - I do get that the DSG, due to mechanical shifitng, is much more complex - but still, the gears themselves should be relatively similar.
The New Beetle TDI was available just about since the beginning in the late-90s with the ALH engine and either a 5-speed manual or the old 4-speed slushbox. 2004 introduced the BEW engine (Pumpe-Duse [PD]). And I think you're right, when the PD100 came onboard, so did the DSG, which means the 2004 did have the DSG. The New Beetle moved to its second generation in 2006 with carryover PD100 and DSG through the end of that model year when the TDI was discontinued (for emissions reasons) until it was reintroduced with the third (and current) generation car.From what I understand, the dual, coaxial clutches are not much like a typical clutch, but pretty specialized units. At lease in this generation of DSGs, they operate in a fluid environment, not air like a traditional manual. I think it's this difference that requires the oh-so-special DSG fluid.
Also, I read that New Beetle TDIs were available in the USA in 2004, so my request for feedback on the DSG reliability might start in 2004 or 2005, depending on which vehicle model & engine one has.
Jim
