Hotter ambient temps cause regen to cycle more?
ApriliaNut
SoCal
06 pkg 1 Jetta 191k w/Malone Stage 2
I've had my NMS since early November and recently the outside temperature here in the lower desert have risen to the 90's, though \the last 2 days it's only been in the high 70s low 80s.
When it was hotter I did notice the regen cycling more. Off hand I'd say 50% more often.
Is this normal?
Just curious.
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
Unless you drive over 200 miles per day, you shouldn't be seeing that many regens. For me, it's approx every 300 miles.
740GLE
NH
Also don't confuse "fans on" with regens, our '12 at 80K ran coolant very hot before buyback even when not running a regen, quite frequently parking in the garage fans would be on but it had def not been regenning. I marked it up to the horrible coolant system of the Gen2 system and possible radiator clogging.
06bluebeetletdi
Middlesex, NC
Mine is also 300-350 miles. But it will run the fans at a lower speed whenever I turn off the car if the air temperature is over 70 degrees. Any place I drive is at least 20 miles away.
740GLE
NH
monitor the coolant via ODBII port, it's prob 220-230F and the fans will run when shut down.
jjblbi
lbi, nj
2014 Passat SEL TDI
IMHO a ScanGauge II is must for these cars, I added mine early on. Water temp, boost, EGT, dpf temps are displayed at all times. I typically take it easy for a mile or two before reaching my destinations and then idle until egts come down and drop below 275F, ~ 1-2 minutes.
