Andrei Rinea
- Joined
- Jan 21, 2002
- Location
- Europe, Romania, Bucharest
- TDI
- VW Tiguan 4Motion 2.0 TDI 170HP (engine CBBB)
Minimal data:
Car: 1994 B4 Passat Variant TDI 90 HP 1Z engine 5speed manual, not EGR-equipped, CCV unfiltered
Garret GT15 turbo, Pierburg MAF no DTCs
no air bubbles in fuel lines!
Info (may be skipped): Car will not exceed 140 kph no matter what gear (4 or 5 only as 3 is not enough). Accelerates very vigurous till then and then.... flat! No smoke, no hick-ups, no nothing.
I need to know the following things:
1) Having LanduytG's 42$ kit interface and VAG-COM on a laptop how do I log a limpy B4? I mean the car doesn't want over 140 kph (~90mph) no matter what I do. Now I have the tool to diagnose it but I don't know how to use it ... I would appreciate a step-by-step procedure as VAG-COM software is very new to me. And what should I log to determine what is wrong? what fields in what blocks or stuff like that?
2) How do I check my N75 valve (with a multi-metre) to make sure it is functioning or not? Should I take it off the car and see if crud is inside?
Anyway I hear I should measure its resistance but what is the typical range? Just measure its resistance? No vacuum applied? or ?
3) Step-by-step using VAG-COM how do I check my injection timing? That with shaded areas as I hear but I have only one graph JPEG and am not sure it is useful to me. After I read some fields (#2 and #9 as I recall) I have to check them on the graph but I don't know how to get to the screen where I read them.
I know I know! I read the FAQ but it doesn't really help here as I don't have the Bentley
(and also can't afford it - not even a 4 users group buy)
I hooked up the VAG-COM and went to Measuring Blocks, Group 004 and read:
945 / 924 RPM, 0.1 deg (spec to start), 0.1 deg (actual), 45-46% Cold start valve
To me (using TDI FAQ) it seems retarded. Is it?
4) I cannot afford a new N75 valve and am not sure I would need one so I would like to take other things into consideration.
I will change ALL small rubber hoses (ECU to intake, all 3 hoses to N75), but it is possible to have oil into the turbo actuator? I dunno how is that built and functions but I would like to know what can I change / clean and how. Let's say I change all hoses (removing the sh_t inside them along) I clean the N75 valve (with what exactly?)
WHAT IS LEFT TO CLEAN? I MEAN all those lines from N75 come from somewhere where it could be accumulated sh_tty oil / crud. I need to clean ALL I CAN CLEAN.
What the FAQ says:
"that when you floor it at 2500 rpm, the turbo boost pressure rises to a peak and then drops to about 0.8 - 0.9 bar (12 - 14 psi). Sometimes the wastegate diaphragm gets clogged up with oil from the crankcase ventilation system, and some owners have had success by replacing the red and blue hoses with new clean hoses and cleaning gunk out of the diaphragm housing as best as possible.You're on your own for doing this procedure."
5) I set the idle rpm to 930 or close. The RPM needle went up and stayed there. Saved, closed, unhooked, shut engine off and then left home. Then I saw the idle rpm on the tach back to old indicated value but the sound of the engine is the new sound. Is it in my head? Is it normal?
6) I am forced to take into account a maybe clogged intake. There must be a way (I've seen it before but I can't find the proc.) to log the air flow (actual and requested) and determine if it's true or not (clogged intake).
Thank you in advance for help in any of these 6 matters!
Till now I bothered you with these problems not being able to diagnose them well 'cause I lacked a software and an interface. Now I have them and dunno how to use'em... help?
[ February 20, 2003, 15:54: Message edited by: Andrei Rinea ]
What the FAQ says:
