IXLR8
You need between 4-5 quarts.. 2 gal will be plenty.. just make sure you got the synthetic Rotella for diesels. Wal-Mart also carries a Rotella that is for gassers.
I know I got the synthetic, not sure if say diesel. Will check once I go down to the car.IXLR8 said:You need between 4-5 quarts.. 2 gal will be plenty.. just make sure you got the synthetic Rotella for diesels. Wal-Mart also carries a Rotella that is for gassers.
I called him just now and still no answer. Let a message and sent a email. hopefully I will hear back soon.mrchill said:Tdiparts will send you bolts only if you like. He is very accomodating. I will call him today and let him know you are interested (we live only 10 miles apart).
Harbor freight baby!MOGolf said:I approve of the blue gloves!
(see timing belt CD pics above if you don't quite understand)
I've been trying...MikeS_18 said:I am envisioning a pit crew scene on this car whenever it arrives wherever it is that they are meeting. 5-6 TDI geeks attacking the oil, filters, timing, snowscreen, coolant sensor, etc...
rofl.
J-R, if you have an offer from Chill to "stop by", figure out how to take him up on this.
PObox just called... they got a package!!! YAY!!!
Can you give us a summary of the problems found?jessica_rabbit said:Many THANKS to TooRoundTDI who tirelessly worked on the car for 5 hours. The car drives better than ever and I am sure the mpg is going to be better than expected! The car is not shaking/vibrating any more and is much much smoother. I can't thank him enough for all he's done. I also want to thank you for all of your encouragements and help. I don't think I can ever live without the club any more... a TDI Club addict for life.
Jess
So what you are saying is that you had to suck start the car?TooRoundTDI said:It looked like whoever did the timing belt used the "mark and pray" method. The cam timing was a little off. The valve cover gasket had RTV on it and Jess peeled it all off. We changed the oil to the correct 5-40 diesel synthetic. Changed the oil and air filter but found out we had the wrong fuel filter. The injection timing was waaay off, it showed 0 when I first hooked up vag com. Fixed all that stuff and it ran great after. Had to prime the fuel pump with my mouth after I ran out of fuel since I had to put the old filter back in. Tasty diesel fumes! Also some of the valve cover bolts were torqued to about 300 ft/lbs, I was sweating stripping them. I think I lost 10 lbs in liquids today, it was HOT! I had fun though, Jess and Robert are cool people! Also Jess you left your oil at my house
It would have been a lot healthier for you if she was using B100TooRoundTDI said:Had to prime the fuel pump with my mouth after I ran out of fuel since I had to put the old filter back in. Tasty diesel fumes!
whitedog said:So what you are saying is that you had to suck start the car?
Suck starting is way more fun than it sounds. I was about 10 seconds away from getting a mouthful of diesel and I would have been a LOT better off if it was B100. Even if it was just for the better (relatively) taste. Too bad you didnt make it Chill, you missed all the suckingowr084 said:It would have been a lot healthier for you if she was using B100
Well, it sounds like he was doing some himself! Certainly he would have liked your kind better!!TooRoundTDI said:Too bad you didnt make it Chill, you missed all the sucking
Tim,TooRoundTDI said:It looked like whoever did the timing belt used the "mark and pray" method. The cam timing was a little off. The valve cover gasket had RTV on it and Jess peeled it all off. We changed the oil to the correct 5-40 diesel synthetic. Changed the oil and air filter but found out we had the wrong fuel filter. The injection timing was waaay off, it showed 0 when I first hooked up vag com. Fixed all that stuff and it ran great after. Had to prime the fuel pump with my mouth after I ran out of fuel since I had to put the old filter back in. Tasty diesel fumes! Also some of the valve cover bolts were torqued to about 300 ft/lbs, I was sweating stripping them. I think I lost 10 lbs in liquids today, it was HOT! I had fun though, Jess and Robert are cool people! Also Jess you left your oil at my house
yeah. Thanks.BTW, thanks FlyTDI for the avatar...
