coolusername
I have a 2012 Jetta Sportwagen TDI with about 73,000 miles on it. It's completely up to date on maintenance. Timing belt was replaced at 70k as a preventative measure, along with oil change, fuel filter, etc. DSG fluid also done. The car throws no codes and gets up to operating temperature perfectly fine. I have a PolarFIS, and from looking at it, everything seems to be behaving. The DPF is regenerating properly, with semi-frequent minor regens, and a full regen happening every 400 miles or so. The car drives absolutely perfectly, super smoothly. However, on a 200 mile drive of nothing but highway (live in CA, went to AZ border to pick up a 1996 B4 Passat Wagon TDI), going about 75 - 80 MPH, I only got 31 MPG, hand calculated with the trip meter. 31! All the little tricks in this forum don't explain why a clean, (relatively) new-ish TDI is getting 11 MPG below rated. Does anyone have any ideas what could be causing this? I talked to an ex VW tech and he said that it could be either my DPF or my CP4 pump is on its way out, but there were no metal shavings in my fuel filter bowl. I also get poor city mileage. Last fillup of all city driving (it's a hilly area so I don't expect the best) I got 24 MPG. Would really appreciate your guys' help.
