I turn wrenches for a living and have always done all my own maintenance. That being said, I am questioning the honesty of my dealership in regards to the "3 year free oil changes". My Jetta is a 2013. I took it in for its 1st annual service in September 2013. The car had 5,688 miles. That invoice appears to indicate the oil and filter were changed. I few days later I checked the oil level and though it was a touch low, I notice the oil on the dip stick being much darker than I would have expected it to be.
This week I took the car in for its 2nd annual service at 10,134 miles. The invoice again appears to indicate new oil and a filter. This morning I checked the oil level and it was a bit low and seems to be darker than what it was last year after the 1st oil change. I have no love for dealerships and anticipated the same issue, so I took a photo of the oil level on the dipstick before the oil change and compared it to what it looks like this morning. The level and color look identical.
When I purchased the car it appeared the correct spec oil was a little tough to find and decided to just let VW change is for free. Mistake?? I actually dread the day I do my 1st oil change on this car. Will I find a stripped oil pan bolt or other surprise?
A couple of questions: What is the color or clarity of the new 5W-40 supposed to look like? Is it the normal amber color? Has anybody else had the same issue?
As a side note about my luck with dealerships in general, I'd asked them to adjust the drivers door at the 1st annual maintenance. The door required a heavy hand to get it to close properly. The other three doors shut and latch normally when closed. The drivers take much more effort or it will not catch the second latch. You can look down the at the gap between the left front and rear doors and clearly see that when closed, the drivers door sits in further than the rear door. The dealership said there was no problem with the door. The colder the weather the stiffer the rubber seals and more effort to close. I had to move the striker out about 2mm myself to adjust the door correctly.
