Hello,
I have been investigating this hissing, or whining that occurs when accelerating. I have been noticing that I don't have as much power as I should. I collected some information regarding VCDS that may help in diagnosing:
In Engine Measuring blocks, 010: Actual MAP:
Idle: 958 mbar
2000 rpm: 989
2600 rpm: 1000
I've noticed that the Specified Map is typically 50-70mbar higher than the actual.
Are these numbers correct? I searched under the car and can't see any hoses that aren't connected or broken. Can intercoolers break in the inside where it is not observable? Any test to confirm this?
Idle: 958 mbar
2000 rpm: 989
2600 rpm: 1000
