demagxc
I had the phase one fix done on Friday. I was on the highway tonight with cruise control set for 66, my Scanguage indicate the coolant temp was 215. The dash showed the temperature outside to be 38. Usually if there is a spike like that it is only momentary and the coolant temp drop back down to normal. Instead, it hovered between 213 and 215 for the next 15 minutes until I got off the highway. After getting off the highway the temp quickly dropped below 200 for the remainder of m drive home.
I do have both the upper and lower grill completely blocked off with a homemade winter front. It has been installed all winter and the coolant temp levels off no higher than 206 even when the temperature outside is in the upper 50s.
Has anyone else noticed higher coolant temperatures post fix? Other than the phase 1 fix nothing else has changed. Until tonight I have never seen sustained temps that high.
