shizzler
Just wondering if anyone has any insight to a strange problem my TDI developed today. Had been running perfect for about as long as I can remember, until just this afternoon. I usually do a wide open throttle pull on my highway onramps during my commute so I can definitely say its been performing great even as of very lately. However snow and ice on the roads have kept me from running wide open a bit less often though.
Today however when I go WOT, the engine pulls normally at lower rpm and hits a wall around 3000-3500 rpms where the acceleration dies. Boost is normal (17 psi), not spiking too bad (nothing over 20 psi). However the injection timing is falling wayy off. Basically reverting back to around 0 deg. I even saw a 5 degrees after TDC reading at one point around 4k WOT in 4th gear. As one would expect, a nice cloud of smoke and EGTs not too happy about it. No CEL or code.
Checked the most obvious thing by unplugging the MAF sensor. Exact same performance!
So I was wondering if anyone knows of anything obvious that could crop up all of a sudden, that would cause the upper rpm injection timing to retard so much? Could not find anything like this in a quick forum search.
Thanks for any help. I now have a vag-com, so tomorrow I plan to take some logs Anyone know which channel(s) I need to log for requested vs actual injection timing?
Many thanks in advance.
