325_Guy
It took a little over 462,000 miles, but I finally ran into some unexpected engine trouble yesterday that I'm in the process of narrowing down to simple injector replacement or something worse.
Yesterday my BRM developed a serious shake and intermittent white smoke at idle. It drives fine, although I feel that there's less power, but I'm also not going to floor it at this point to check. I had to drive it about 200 miles after the symptoms began in order to make it home.
CEL is lit, VCDS reports Cylinder 2 misfire. IQ Deviation is:
2.99 Cyl 1
2.99 Cyl 2
-3.01 Cyl 3
-3.01 Cyl 4
I'm going to perform compression test once I get home to see where the block is at. In the meantime, my two questions are:
What would I look at to refresh the head? I have what I think is a small head gasket leak as well, so the head will be coming off. What needs replacing to bring the head back to new condition? Is it worth it to do the parts individually? Or should I look into a replacement head from Franko6 if he has them?
Injector / nozzle recommendations? I'm currently running a GTB1749V from Darkside Developments along with a Malone Stage 4, the 3 bar MAP, mated to a South Bend stage 2. I'm not looking to push too far past my current power levels, but if I understand right the stock injectors are just about maxed out with my tune.
Thanks!
2.99 Cyl 1
2.99 Cyl 2
-3.01 Cyl 3
-3.01 Cyl 4
Thanks!
