Ray Khan
I installed the USP HID kit for the B7 Passat in my wife's 2013 SEL last weekend. I used the tee taps included and got power and ground from the wires going into the factory headlight harness. I did the the passenger side first and everything seemed to work ok. I did the driver side the same way and the lights turned on briefly and then shut off giving the low beam out warning. I suspected a bad power connection so I redid the tee taps and the behavior was the same. So then I cut the low beam power wire and put on a new connector to directly attach to the HID power wire. I cut back the insulation on the factory harness ground wire and soldered on a second wire to connect to the HID ground. The lights work better but they still give problems intermittently. Even the passenger side occasionally goes out and gives a bulb warning. This side still uses the tee taps. I figure one next step is to make a direct power and ground connection on that side as well but the fact that the drivers side isn't perfect is making me hesitant to go that route before I get to the root cause of the issue.
So far I've done limited driving but when a light doesn't ignite, it fails right when the lights are turned on. Once the lights ignite they seem to stay on, but I haven't taken any drives more than a few minutes with the lights on so I'm sure if they will shut off once ignited. Some times a light fails to turn on and the dash warning light comes on, then the light ignites a second or 2 later and the dash warning light shuts off again. I tried both ballasts/bulbs directly attached to the battery and they seem to power up and stay on without any issues. It seems the parts are ok with full battery voltage. Also, there hasn't been a case of both lights not igniting during the same start up.
So what to do next? It seems others have done installs on the 2013 B7 with no issues and didn't need to make changes with VCDS. I thought the error eliminators built into each ballast I have should make everything work with the factory low beam power as it is. Should I turn off the bulb life extension feature or is there another logical next step? If this works I'll be happy, but I don't want to put a band aid on a problem that can be fixed either. I was thinking to measure the voltage coming to each ballast during startup and after the car has been on a few seconds. Is it possible the slow voltage ramp up caused by the bulb extension feature is the problem, are the USP ballasts error eliminators both defective, or is the kit not known to work well on our platform?
Looking forward to your feedback.
