Have a 2013 reprogrammed TDI Passat. Recently hesitates when cold on acceleration, sometimes with a rhythmic pattern. Does anyone else have this since reprogramming? I'd like to figure out the cause.
I believe others have called it a stumble. I have not noticed it very much on mine but from what I've read in the section specifically for our Passats http://forums.tdiclub.com/forumdisplay.php?f=86 it is the reprogramming. The new program places an emphasis on warming the engine and exhaust system. To do this they restrict the exhaust flow to heat the other components faster. While this is being done performance is impacted. You should be good to drive, after a couple miles it should be warmed up enough so the program stops doing this.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
