tdihopeful
Where is a good source for that software? I'm gonna Google it.
You can get it here: Ross-TechWhere is a good source for that software? I'm gonna Google it.
I've not used that one, but it appears to be a knockoff. It doesn't state that it has the tdi timing tool like vag-com has. I've used other scan tools and all, but nothing beats the vag-com.Link has anyone used a tool like this?
VOLKSWAGEN VW AUDI DIAGNOSTIC SCANNER ABS SRS RESET TOOL iCarsoft VAWS 2.0 II | eBay
This tool is the newest version in the iCarsoft line of products and replaces the VAWSII. Features for the iCarsoft VAWS V2.0 include the following iCarsoft VAWS V2.0. The iCarsoft VAWS V2.0 is a professional fault diagnosis tool designed specifically for VOLKSWAGEN/AUDI vehicles.www.ebay.com
This one? https://www.etsy.com/listing/910587472/vcds-2020-diagnostics-laptop-diagnostic?gpla=1&gao=1&There is a sale on a laptop with VAG installed on etsy. 400$ it looks like a pretty nice laptop too. I need a laptop anyway. Could kill two birds with one stone.
Yes, you can adjust injector quantity on the alh. I just did that yesterday with my golf and vag-com. It really woke my awake car up. Now to stay out of it...Yeah I decided to go with a laptop separate and maybe a MacBook I think VAG-COM will run with through Bootcamp. Can anyone confirm this? One thing is I noted that VAG-COM cannot apply "tune" mods to the ecu ie injection timings quantities and those parameters. What do I want to do for those? I did order the Bentley thanks for the recommendation on that... Another thing I'm curious about is operating the engine sans computer systems. From what I understand this is possible with the ALH. Could someone provide links/direct me to where this is discussed on the forums.
HiI had asked the question of running the engine without ecu because I'm planning on developing one or more TDI engine models for use in aircraft. Through VAG-COM could I increase HP to Euro Spec 110hp as opposed to the what 95 stock US? Also can I manage the EGR system and fuel temperature sensor parameters?
You cannot increase the power merely through vag-com, you have to tune for that, though you can adjust fueling to a point. Your best bet for that would be to get it tuned, and you can go a lot more than merely 110 hp with only a tune. Swap turbos and injectors, as well as the map sensor and you get get even more. Then if you build an h-beam rod block, with other upgrades, you can get closer to the 300hp range.I had asked the question of running the engine without ecu because I'm planning on developing one or more TDI engine models for use in aircraft. Through VAG-COM could I increase HP to Euro Spec 110hp as opposed to the what 95 stock US? Also can I manage the EGR system and fuel temperature sensor parameters?
The basic mechanical function of the ve pump are the same between an m-tdi and e-tdi pump. I don't know all the differences, but I know that the basic mechanical part works the same, but the electronic tdi pump uses an electronic actuator to adjust fueling and timing, whereas the manual pump uses a mechanical lever for the quantity and timing adjustment is limited to mechanically adjusting the physical timing, or some had a "cold start cable" that would advance the timing when the engine was first started (that's how my old rabbits are)Hi
I think the ability to be able to run in "mechanical mode " would be nice from a hardcore reliability standpoint...
I'm a long distance delivery driver and often worried that if the computer or some important sensor decided to die at an inopportune time i could be stuck in the middle of nowhere or maybe the car could die in a bad place ( like in a busy construction area with fast moving traffic and nowhere to pull off etc).
I like the that electronics can make for more fuel efficiency and power but why cant a normal pump be used in both modes (electronic mode normally OR mechanical mode as a fail safe? ... even if it had to be "switched manually" but it would be nice if the pump could switch to mechanical mode automatically by itself and maybe have an indicator light pop on to let you know it happened so you. An fix it at your leisure..).
Just out of curiosity , what makes the pump stop working if the electronics craps out? The pump is mechanically driven but something small must keep it from working if it goes bad or doesn't receive a sensor signal but could that be bypassed in a pinch easily?
Example, on my cummins 5.9 which was 100% mechanical, the only thing that would stop the engine under normal scenarios was losing alternator power causing the battery to die and consequently unpowering the solenoid that allows fuel to flow Into the injection pump ( fuel shut off solenoid) .... removing the solenoid and installing a manual choke cable to pull the lever that shuts off the fuel to the pump makes the engine potentially more hardcore reliable)
Some of the same ideas could be used in the tdi pump maybe to make it more "mechanical" ?
What makes the pump not work without electronics and can it simply be bypassed in a pinch ( I had to get my 11 mm pump because the quantity adjuster or something that sounds like that decided to act up... I think it was something electronic and if that could have been worked around mechanically I could still be using that pump?
For 300hp, if you built it right, I'd say probably a 4.5-6. I have yet to dyno mine, but I believe it to be in the 150-200 hp range, that you can do with maybe a 8-9 on the reliability scale. Obviously how you drive and how you maintain would be a huge factor.Andy that dual system with having primary engine parameters being controlled via ecu and in advent of ecu failure or code that could cause engine to cease operating then being able to (at least in aircraft use) quickly or automatically default to mechanical operation would be perfect. For long distance ultra reliable operations on road use that would be pretty ideal I agree. As far as potential HP 300 from an ALH would be pretty amazing. Mozambiquer on a scale from 1-10 what would you think the reliability factor be on a 300 HP engine? I was thinking 200 would be pretty perfect.
Obviously if you did aircraft applications, you would want to do much better maintenance than for a car... You don't want to have any risks.Considering aircraft useage 4.5-6 would be unacceptable outside specific use such as a CAFE air race. 8-9 for 150-200 HP would be pretty excellent considering certified aircraft engines are only maybe a 10.
That's good! Had it run out, or did it have a leak?Had air in fuel system. I'm learning, learning.
HI,Considering aircraft useage 4.5-6 would be unacceptable outside specific use such as a CAFE air race. 8-9 for 150-200 HP would be pretty excellent considering certified aircraft engines are only maybe a 10.
Yeah, that would be great, but that's another dead horse that's been beat a lot. As far as I know, nobody has done it, and it would take a ton of work to make it work, then it would be better to use an engine that already has gear drive. My 1983 ford ranger diesel has the old gear driven 2.2 liter Perkins/Mazda engine, they last forever, but are very heavy...HI,
I may have made mention of this in another thread BUT to make a TDI (or other engine for that matter) more "bulletproof" , I think it would be nice to eliminate the timing belt and replace it with a timing gear set ..... Hard to beat the hard core reliability of heat treated gears in a bath (or stream) of oil.
Andrew
Yeah, the alh doesn't have an in tank lift pump, and if you get enough air, you have to crack the injector lines open to bleed the air out.That's pretty good to think about Andy I will keep that in mind. I feel that timing belt is pretty well known and failure modes and timespans for these well enough understood that they would work perfectly fine. Perhaps in a very high performance high HP engine where low maintenance interval is desired such an oil bathed gear driven cam would be the way to go. As for why there was air in the fuel system that's on me. I didn't realize the pump/fuel system wouldn't self purge. On to the next matter of importance... I would like to upgrade the suspension. Specifically for stiffness in the rear to haul cargo including large water and fuel containers. Perhaps 2-300 gallons if possible. Where should I discuss this?
If you look on Facebook, there's a group called "lifted air cooled vw's" that's where I've seen the Jeep spring deal. I'm getting ready to do the wagon springs on my golf to get a little bit more space.That's funny Jeep springs
