Judson
Hi folks -
I am cross-posting this, as I think maybe there will be more eyes and knowledge here than over in the MKIV TDI area.
Here's my post:
Basically, I have a GTD1752vrk installed, and the boost-to-intercooler hose blew off at around 20psi, and now won't stay on at all.
I believe the installer I hired didn't get it right, so I'm looking to replace this hose I have with a one-piece, 2" to 2 1/4" one.
The installer used a CF-style clamp, which isn't holding to the turbo outlet. Worse, when I attempted to ratchet it down more, it kept twisting (due to the torque) and would always come right off. I tried a standard hose clamp, and it too came right off under boost.
With all the custom fabbing going on in this forum, I'm hoping someone can help point me in the right direction.
Thanks!
Jud.
Here's my post:
What did you do to your MKIV today?
Well, the 1752 is on. Cost me an arm and a leg. Apparently the old turbo snapped its shaft at only half-throttle; it wasn't a WOT run. So, I had to pay for that cleanup, as well as a lot of custom fabrication. However, the boost tube they fashioned up to go from the outlet to the intercooler...
forums.tdiclub.com
Thanks!
Jud.
