Help - what's that ticking sound?!
thechoochlyman
Campbellsville, Kentucky
1997 B4 Sedan
I'm pleased to say my cylinder bore is well within spec. Cylinder 4 measured right on 3.131, and my telescopic gauge rode up and down the wall of cylinder 3 making snug contact with the wall the entire time. At the very tippy top where I honed it the most it measured 3.132, which is well within the .004" out of round tolerance.
thechoochlyman
1997 B4 Sedan
Got the head reassembled yesterday after reaming the guides and lapping the valves.
Someone mentioned to me that perhaps the valve seats are too wide. I was unaware this could be a problem so I researched it a bit. I guess replacing/machining the seats would have been ideal, but I think it'll be fine for who's driving it.
ToddA1
NJ 08002
'96 B4V, '97 B4 (sold), '97 Jetta (scrapped)
Impressive…. I don’t have the patience for that, which is why I use the drill. I see no pitting… how long did that take to get all of them uniform, or did you only show only the best one?
-Todd
thechoochlyman
1997 B4 Sedan
-Todd
They all turned out the same. A couple of them only took one 30-second round of spinning, others took 2 or 3. But overall I was impressed with how little effort it took. The seats all appeared to be in great shape.
GTiTDi
Head is now off. Doesn't seem to be anything too fishy happening here, but here's a few photos.
All cylinders have some amount of cross hatch remaining. Cylinder 2 looks a little worn, but not severely.
Cylinder 1
This piston has a tiny dent on the front. None of them have any signs of cracking.
The head looks great. Just going off my dial Caliper all the valves seem to have the same amount of protrusion. Before I send the head off to anybody I want to remove the valves to inspect them and the guides for wear.
I just started reading this thread and could tell your tick was from wiping out #3 piston
thechoochlyman
1997 B4 Sedan
So I went ahead and bought the new piston from AutohausAZ. It got here quick and looks great. Now I'm primarily waiting on my connecting rod bushings to continue. I'm currently working on cleaning out the ring grooves on my other pistons, a couple of them were stuck REALLY hard.
GTiTDi
I'm just OCD like that. lol Somebody gave me a hint of doubt and I couldn't help but look while I was here.
ACTUALLY... it's probably a good thing I did, because I found something not so good in cylinder 3.
View attachment 127214 View attachment 127215
The oil ring on this piston is COMPLETELY stopped up. And you can tell just how badly scarred the side of the piston itself is. The cylinder wall doesn't look great, but it could certainly be worse. I can feel the ridge with my fingernail. I think a new piston and some time with a honing tool could correct this, but I'm not the expert here.
Tell me what you guys think.
1Z pistons don't have a wrist pin bushing or very deep oil channels. I have an identically damaged piston from my 1Z after a hard pull on the highway at 100-120mph, rocketchip stage 3 tune and stock GT15 teenyweeny heat pump(turdbo).
GTiTDi
NO NO NO you need to get a full set of matching pistons, the 1Z pistons should all be removed and discarded! Use ALH pistons! Even a good set of used ALH pistons are better than those crap 1Z pistons! When I melted my 1Z down I got used ALH pistons and dressed and polished the stock rods. https://forums.tdiclub.com/index.php?threads/how-to-prevent-meltdown.328936/post-3528343
burpod
teh stallionz!!1
cape cod, ma
i've been trying to suggest it would really be a mistake at this point to not just hone and re-do all 4.... :| it's so little work and you're right there
thechoochlyman
1997 B4 Sedan
So just out of curiosity I did a quick search on AutohausAZ. I'm getting the same part number for both AHU and ALH pistons. I've already determined that I have an AHU and not a 1Z, so it looks like I already have the better piston design. Anyone care to confirm this for me?
Steve Addy
Iowa
97 Mk3
Did you actually look at the block to verify that it was AHU? You may have only gotten a replacement cylinder head....
What about the original piston brand? AHU used either Malhe or Alcan pistons. ALH used only Mahle pistons. 1Z I don't remember looking for it.
Steve
thechoochlyman
1997 B4 Sedan
I
Steve
I haven't, but the new piston I bought is visually identical to the others. I've really been trying to find out what the actual difference is between the 1Z and AHU/ALH pistons but so far I'm having no luck.
Steve Addy
Iowa
97 Mk3
I
I would check the block to see what that says, that will be definitive on the issue of what engine you have. I would not base my assumption about what engine I have on the size of the valves unless that was confirmed by the engine code on the block.
As for the pistons, I had read years back on some source that's probably gone now, that the 1Z pistons were not as robust as the AHU pistons were. I can't recall the specifics, but it could have been related to that which was mentioned earlier by GTITDI.
As for finding evidence in the parts catalog I doubt that you will find any, the history of changes gets wiped out over time until there's only the most recent specification, so what may have originally been shipped installed in your engine, and the part number for it, might not be recorded anywhere anymore, who knows.
But I still would only accept that you have an AHU if your block says it, otherwise you have a 1Z with a replaced cylinder head would be my guess.
At any rate, there is some merit to getting some used ALH pistons and going that route.
Steve
GTiTDi
Well this is probably the only difference that can be found in the two types. Easiest way to tell would be looking for a wrist pin bushing in the piston.
I could tell yours lacked the wrist pin bushings and has small oil reliefs plus if yours has 8mm valve stems it is most definitely a 1Z
thechoochlyman
1997 B4 Sedan
Mine has 7mm valve stems.
he should also ditch the heat pump while he's at it
Heat pump? You mean the EGR system I immediately removed when I bought the car 8 years ago? lol
GTiTDi
definitely 1Z pistons...maybe the head was replaced somewhere along the line, maybe they slapped AHU heads on the last of the 1Z blocks in the early 97 Passats
thechoochlyman
1997 B4 Sedan
By the way, I'm curious to know what people are doing for torque spec on the connecting rod caps. Is it 22 ft/lbs only or 22 + 90 degrees? Coat lightly with engine oil before installing?
Also, is it common practice to oil the head bolts before torquing?
Connecting Rod Bolt:
- Always Replace.
- Tighten in two stages:
- First stage, tighten to: 30 Nm
- Second stage, turn: an additional 90° (1/4 turn).
- Oil threads and contact surfaces.
thechoochlyman
1997 B4 Sedan
Bottom end is back together and I got the head set back on the block last night.
I verified that the old pistons were the 1Z design with the smaller oil holes. They did manage to last 300,000 miles though, and with the amount of cleaning I did on them I'm sure they'll next until next time. At least the cylinder that DID give up on me has the newer design.
Here's connecting rods 1 and 3, you can see how much the bushing in #3 had worn from the piston being chewed up on the side.
I made a .010" undersized bushing at the shop to press the wrist pin bushings out.
First time honing a wrist pin bushing, but I did get them both within tolerance - at least in the center. It's a little more loose on the ends on the bushing, but I'm still gonna send it. No more than .001" total clearance. About .0005" clearance in the middle of the bushing. I think it will wear in fine over time.
I have no doubt that my engine is going to run better after cleaning the rings on the other three cylinders like I did. The middle rings were all stuck really bad on the thrust side and full of carbon buildup. I set them all 120 degrees apart with no gaps parallel to the wrist pins. Hopefully I'll get running again this weekend.
thechoochlyman
1997 B4 Sedan
After a solid 9-hour day (including picking up my kid from school and eating lunch) this saga is finally coming to a satisfactory end. I knew today would probably be pretty straightforward just because it was all final assembly, and fortunately I wasn't too far off base.
Made use of my brother-in-law's new Craftsman torque wrench for the head bolts.
Had a major "oopsie" that included a few choice swears while installing the injectors. For some reason the documents I had specified 52 ft/lbs for the bolts which is WAY too tight. Before I even got close the bolt broke clean off. Fortunately for me I used liberal amounts of anti-seize, and it easily backed out with nothing but a flat-head screwdriver.
As I arrive at the hardware store I'm on the verge of tears as I'm certain they won't have an M8x50 grade 8.8 bolt. But they did; relief washed over me in an awesome wave.
I found an old post from Frank06 (Thanks again Frank!) detailing how to seat the injector seals with a hammer and torque to 20 lbs, so that's what I did.
Glad to see that my prototype coolant flange is still holding up well after about seven years - with no leaking in the interim.
Because my original didn't have a circle milled around the overflow barb for a wrench, I EDM'd a hex in my barb to tighten it with. lol
For my next trick I laid down a towel to clear out the injector lines before hooking them to my clean, new injectors. (Thanks, Frank!)
With great anticipation I cranked my engine over again for the first time, and it fired right up sounding as good as it ever did. I only forgot two minor details - the spring clamp on one of the intake pipes, and the turbo feed oil line was loose.
I've gotta call my insurance tomorrow to have coverage reinstated (might as well save that $40 when possible), but so far everything seems great. Only time will tell I suppose, but I'm very happy to be up and running again! The V6 B5 is nice, but I really missed my baby.
