thechoochlyman
I just pulled a B4V home over the weekend and this tick seemed to have popped-up during the trip. I just got done pulling several hills, topping out at 208F and holding about 1000-1200 (pre-turbo) EGTs for a couple of minutes at a time. We stopped for lunch before descending the other side of the mountain and I noticed the tick when I fired it back up.
There was nothing unusual on the rest of the way home. I've driven to work two days since then and it hasn't changed as far as I can tell. It stays in-sync with engine RPM at any speed. There is no change in how the engine runs and it's still smooth as ever. I can only barely hear it from inside the car. I used a stethoscope to do some poking around, but couldn't really narrow it down other than it seems to be coming from the back side of the engine. I dosed it heavy with injector cleaner and changed the fuel filter with no affect. I broke all the injector lines loose while it was running and it didn't go away, so it doesn't seem to be an injector.
My theory is that I got the exhaust manifold hot enough to blow out part of the gasket or crack the manifold. Haven't had the ability to really inspect it yet, but I do know that an exhaust can sound an awful lot like lifter tick. I have 5,000 miles before my timing belt is due and would really prefer to wait until then before I take off the valve cover for further inspection. But if it seems to get worse before then, of course I'll tear it down early.
video.
video.
