eugene89us
Good morning.
Wanted to ask a question. Have noticed steering wheel started to shake from around 65 mph and gets worse closer to 80 mph. Recently replaced all brakes with the same problem persisting. Thought maybe the original OEM Conti's wearing out - they had 63,000 miles on them, so I had them replaced yesterday. However, the shaking persists. With Michelin tires being much more responsive, shaking also appears to be more pronounced. Rotating tires did not help - thinking maybe bad balance. Jacked up the car - there is absolutely no play in the wheels - both at 9-3 and 12-6 o'clock. Of note, I do hear a little "chaga-chaga" sound at high speeds over 50 mph, but only when I pass by the barriers where sound is more pronounced. I doubt it is brakes, because there is no vibration when braking and the braking is very smooth. Calipers were appropriately lubricated when I did the brake job.
Do you guys have any suggestions as to what to look for? I am completely at loss. Thank you.
Eugene
Eugene
